How do I calculate the power output of the lightbulb?
In summary: V in the question, the resistance would be 240Ohms.In summary, The battery has an Emf of 12 volts and an internal resistance of 35 ohms. The ammeter measures a current of 75 mA. The battery is now disconnected from the resistor and connected to a light bulb. The actual power output of the light bulb is 0.703 watts.
jawhnay
37
How do I find the answer for part C?
3) A battery with an Emf of 12 volts is hooked up to a 125 ohm resistor and an ammeter. The ammeter measures a current of 75 mA.
a) Calculate the internal resistance of the battery and the actual voltage across the battery.
b) Calculate the power dissipated in the resistor and the power generated by the battery.
c) The battery is now disconnected from the 125 ohm resistor and connected to a 60 watt light bulb.
What will be the actual power output of the light bulb?
Vbattery = Emf - IRinternal
V = IR = I2R
P = iV
a) Vbattery = .075(125) = 9.375
Rinternal = (9.375 - 12) / -0.075 = 35ohms
b) Presistor = (0.075)2125 = 0.703 watts
Pbattery = 0.075(9.375) = 0.703 watts
c)I thought the power supplied to the lightbulb would be 0.703 watts, but it isn't... can anyone explain why?
I think you are assuming that the internal resistance of the light bulb is also 125 ohms.
The voltage of the battery and the internal resistance of it doesn't change right? So wouldn't the current be the same regardless if the 125 ohm resistor is gone? I tried to use P = IV to calculate the power output for the lightbulb
What if the 125 ohm resistor were replaced with a 50 ohm resistor? How would that change the current?
The current would increase to .188 amps to make up for the decrease in resistance if the voltage of the battery is the same.
If the 125 was replaced by a 50 Ohm the current becomes... 12/(35+50)=0.14A
For c) If the nominal specification for the bulb is 12V 60W then what will it's resistance be?
the resistance would be R = (12)^2/60 = 2.4 ohms?
So replace the 125R with 2.4R. Calculate the current and then the power in the 2.4 ohm resistor/bulb.
So, I get I = 12/(2.4+35) = 0.321 amps. P = I^2R = (.321)^2(2.4) = 0.247 watts. I got the wrong answer. The answer is actually 0.46 watts.
I agree with your figure for the power (eg 0.247W). I can't see how they get 0.46W.
Anyone else want to comment?
Edit: Does the question mention the nominal voltage rating of the bulb? I can't see how to solve it unless you assume it's a 12V bulb.
I'd take a guess at 120 V rating for the bulb after U.S. standard - gives a nice round number for its resistance and my napkin math shows an output of around 0.46 W.
Have just run the numbers and I agree...
Bulb resistance = 1202/60 = 240 Ohms
Current would be..
12/(35+240) = 43.6mA
Power would be
(43.6 * 10-3)2 * 240 = 0.457W
It's a badly worded question when the answer depends on which country you live in :-)
how would I have known that the voltage rating of the lightbulb is 120 V if it isn't stated in the question? Is there no other way to solve part c given what is in the question?
Since 120 V is what's used for AC mains electricity (i.e. wall power) in North America, usually when a bulb has a "60 W rating", it's meant that if you plug it into wall power, it will consume 60 W of power. From this you can infer its resistance. That's why 120 V was meant to be assumed. Obviously if you plugged it into a supply at some other voltage, a different amount of power would be drawn. That having been said, I totally agree that problems in which you are meant to assume information that isn't given are BAD.
jawhnay - out of interest what country are you in?
@cwatters I'm from the united states.
Related to How do I calculate the power output of the lightbulb?
1. How do I determine the power rating of the lightbulb?
The power rating of a lightbulb, measured in watts (W), can typically be found on the packaging or on the bulb itself. If not, you can calculate it by dividing the voltage (V) by the current (A) using the formula P = V x I.
2. Can I use a regular household voltage to calculate power output?
Yes, for most lightbulbs, the standard household voltage of 120V can be used to calculate power output. However, it is always best to check the specific voltage requirements for your lightbulb to ensure accuracy.
3. What if the lightbulb has a range of wattages listed?
If the lightbulb has a range of wattages listed, you can calculate the average power output by adding the minimum and maximum wattages and dividing by 2. This will give you an estimate of the average power output.
4. Can I use a multimeter to measure the power output of a lightbulb?
Yes, you can use a multimeter to measure the voltage and current of a lightbulb and then use the formula P = V x I to calculate the power output. However, keep in mind that the power output may vary slightly due to fluctuations in voltage and current.
5. How does the power output of a lightbulb affect its brightness?
The power output of a lightbulb is directly proportional to its brightness, meaning the higher the power output, the brighter the lightbulb will be. However, other factors such as the type of bulb and its efficiency can also affect the brightness.
