How does a buffer actually work?
In summary, Buffer is a solution of weak acid and its conjugate base that maintains a stable pH when strong acid or base is added. This is achieved through the Le Chatelier's principle, where the equilibrium reaction shifts to the left or right depending on the added substance, ensuring that the concentration of the weak acid and its conjugate base remains relatively constant.
Kaushik
282
TL;DR Summary
Buffer is a solution of weak acid and its conjugate base which resists the change in pH when strong acid/base is added to the solution.
But how does it work?
Consider,
HA + H2O ⇄ H3O+ + A-
When we add strong acid, the H+ from the strong acid reacts with the conjugate base A- to for HA. Hence, the concentration of HA increases while the concentration of A- decreases. According to Le Chatelier's principle the equilibrium reaction shifts to the right. So then won't the H3O+ concentration increase further? We want it to shift to the left right?
When we add strong base, the OH- reacts with H+ from the weak acid to form H2O. So concentration of HA decreases while the concentration of A- increases hence the reaction should shift towards the left, am I correct? It was given it shifts towards the right. How?Thanks!
Chemistry news on Phys.org
No, it shifts to the left and stops there.
Related to How does a buffer actually work?
1. How does a buffer actually work?
A buffer is a solution that helps maintain a stable pH level in a system by resisting changes in pH when an acid or base is added. It does this by containing both a weak acid and its conjugate base, which can react with any added acid or base to prevent large changes in pH.
2. What is the role of a weak acid in a buffer solution?
A weak acid in a buffer solution can donate or accept protons, which helps maintain a stable pH. When an acid is added, the weak acid in the buffer will react with it, preventing a significant change in pH. Similarly, when a base is added, the weak acid will accept protons, preventing a drastic increase in pH.
3. How does a buffer resist changes in pH?
A buffer resists changes in pH because it contains both a weak acid and its conjugate base. These components can react with any added acid or base, keeping the pH of the solution relatively stable. Additionally, buffers are able to maintain their pH over a wide range of acid and base concentrations.
4. Can a buffer work with any acid or base?
A buffer can work with any acid or base as long as the acid is weak and the base is its conjugate. This is because a weak acid and its conjugate base have similar strengths, allowing them to react and maintain a stable pH. Strong acids and bases, on the other hand, can easily disrupt the balance of a buffer solution.
5. How do I prepare a buffer solution?
To prepare a buffer solution, you will need to mix a weak acid and its conjugate base in specific proportions. The ratio of the two components will depend on the desired pH of the buffer solution. It is important to note that the concentrations of the weak acid and its conjugate base must be high enough to effectively resist changes in pH.
  • Chemistry
  • Chemistry
  • Chemistry
  • Chemistry
10K
