How does a mist spray bottle affect scent molecules?
In summary, the conversation discusses the use of a water mist spray bottle to combat bad smells, and whether or not the water and essential oil mixture can affect the scent molecules in the same way as store-bought air fresheners. The conclusion is that air fresheners simply mask the smell with a stronger scent, while the water mist does not have a significant impact on the scent molecules.
larry909
Say you use a water mist spray bottle against a egg smell, do the water molecules crash into the scent molecules and bring them down?
What about if the water has mixed into it essential oil? How does the spray interact and affect the scent molecules?
Does a air freshener that you can buy in the store act on the scent molecules differently than water?
Chemistry news on Phys.org
larry909 said:
essential oil
Air "fresheners" do not "freshen" air --- they at most mask it.
If it's just a water mist you're spraying, how/does it affect the scent molecules?
It doesn't.
What they really do is they add another scent, strong enough so that you stop smelling the initial stink.
Related to How does a mist spray bottle affect scent molecules?
1. How does a mist spray bottle affect the distribution of scent molecules?
A mist spray bottle creates tiny droplets of liquid that are dispersed into the air. These droplets carry the scent molecules with them, allowing for a wider and more even distribution of the scent compared to simply pouring the liquid onto a surface.
2. Does using a mist spray bottle affect the strength of the scent?
Using a mist spray bottle can actually enhance the strength of a scent. The smaller droplets created by the sprayer have a larger surface area, which allows for more of the scent molecules to be released into the air. This can result in a stronger and longer-lasting scent.
3. Can a mist spray bottle affect the composition of the scent molecules?
No, a mist spray bottle does not change the chemical composition of the scent molecules. It simply helps to distribute them more effectively into the air, without altering their properties.
4. Is there a specific type of mist spray bottle that works best for scent distribution?
While any mist spray bottle can be used, it is recommended to use one with a fine mist nozzle. This creates smaller droplets that will disperse more evenly and effectively carry the scent molecules into the air.
5. Does the material of the mist spray bottle matter?
The material of the mist spray bottle does not affect the distribution of scent molecules. However, if the scent is sensitive to certain materials, it is important to choose a spray bottle made from a compatible material to avoid any unwanted reactions that could alter the scent.
  • Chemistry
  • Classical Physics
  • Mechanical Engineering
  • Other Physics Topics
10K
  • Classical Physics
