- #36
sophiecentaur
- 6,936
That's a really good example of how an alternative, personal model of Electrical Circuit Operation really doesn't help. If you want to talk about electrons in this context then you have to talk Quantum Mechanics and Statistics. This is why EE is taught in terms of Charge and Current. Only when you are fully conversant with the standard approach to EE theory can you afford to get into the questions you seem to be wanting to ask for starters.Gerry Rzeppa said:Okay, let's try this one:
I charge up a capacitor (value discussed below) to 1 volt and then insert it as shown in the circuit above. The resistor is 1 ohm, so the current is initially 1 amp. A larger capacitor will maintain the flow longer, but will not increase the voltage. The voltmeter shows the voltage starting at 1 volt and dropping from there. It seems to me:
1. That the voltage between A and B is directly related to the ratio of excess/deficit electrons on the top/bottom of this circuit. Yes?
2. That the number of excess/deficit electrons may be substantial. For example, if the capacitor is large enough to sustain a 1-amp flow for 1 second, then the number of excess electrons must have been at least 6.2e18 at the start. Yes?
3. That a larger capacitor can maintain the 1-volt reading longer, not because the ratio of excess/deficit electrons is different, but simply because it takes longer to move enough electrons to significantly change that ratio. Yes?
So far so good? I hope so. Now for the $64,000 question:
4. What's the relationship between the various ratios of excess/deficit electrons that exist in this circuit at various points in time, and the voltage readings we see on the meter?
