Aafia
- 70
- 1
Cuticle is the waxy layer on epidermis which prevents loss of water from leaves but some of the transpiration also occurs through cuticle. If cuticle is wax then it should prevent the water loss completely.
Aafia said:Cuticle is the waxy layer on epidermis which prevents loss of water from leaves but some of the transpiration also occurs through cuticle. If cuticle is wax then it should prevent the water loss completely.
But cuticle is just a layer, it is not opening. I want to know how some of the water is lost through cuticle if it repel water.Fervent Freyja said:Yes, it should prevent most water loss. Gas exchange is regulated by stomata located on the epidermis, they also open during transpiration.
If some transpiration occurs then it is fairly obvious that the cuticle does NOT prevent some water loss.Aafia said:Cuticle is the waxy layer on epidermis which prevents loss of water from leaves but some of the transpiration also occurs through cuticle. If cuticle is wax then it should prevent the water loss completely.
Aafia said:But cuticle is just a layer, it is not opening. I want to know how some of the water is lost through cuticle if it repel water.
Cuticular transpiration is the process by which plants lose water through the cuticle, a layer of waxy substance that covers the leaves and stems of plants. This process is essential for the regulation of water balance in plants and is a necessary component of photosynthesis.
Cuticular transpiration occurs through small openings called stomata, which are present on the surface of the leaves and stems. These stomata open and close to allow for gas exchange and water loss. The cuticle acts as a barrier, preventing excess water loss while still allowing for necessary gas exchange.
The rate of cuticular transpiration is affected by various environmental factors such as temperature, humidity, wind, and light intensity. It is also influenced by the size and density of stomata, as well as the thickness and composition of the cuticle.
Cuticular transpiration is essential for the survival of plants as it helps to regulate their water balance. It also plays a role in the absorption of nutrients and minerals from the soil and in the transport of these substances throughout the plant. Additionally, cuticular transpiration helps to cool the plant by evaporating water from its surface.
In some cases, excessive cuticular transpiration can be harmful to plants. If the rate of transpiration exceeds the rate of water uptake, it can lead to wilting and dehydration. This is especially true in hot and dry environments. However, the cuticle helps to regulate the rate of transpiration and prevent excess water loss, making it a crucial adaptation for plant survival.
