How many cycles of time should be measured for the most accurate T?
In summary, the conversation discusses the best method for measuring the period of a sine wave using an oscilloscope for maximum accuracy. The proposed solution is to measure multiple cycles and use the error propagation formula to determine the overall error. However, this method assumes that the clock used to measure the cycles is accurate. If the clock is drifting, then measuring only one cycle may be a better option to account for potential variability. More context is needed to determine the most accurate method.
merrypark3
30
Measuring the period of a sine wave using oscilloscope, for the best accuracy, is it better to measure only one cycle?
Let [itex]t=T_{1}+T_{2}+\cdots + T_{n}[/itex] (Measuring n cycle)
From error propagation formula,
[itex]\delta t = \sqrt{(T_{1})^2+(T_{2})^2+\cdots + (T_{n})^2}[/itex] (or [itex]\delta t= n \delta T_{1} [/itex] ?)
but as [itex] T_{1}, T_{2}, \cdots , T_{n}[/itex] are independent so the value of each [itex]\delta T_{n} [/itex] is same. So, let [itex] \delta T= \delta T_{1} = \delta T_{2}= \cdots = \delta T_{n} [/itex]
This [itex] \delta T [/itex] is a error for a period.
Therefore,
[itex] \delta t= \sqrt{n(\delta T)^{2}}=\sqrt{n} \delta T[/itex]
But, [itex] \delta t \propto n[/itex] (as n increases, the scale for one div the screen become smaller,
which increase your error)
So [itex] \delta t = \sqrt{n} \delta T \propto n [/itex]
So, [itex] \delta T \propto \sqrt{n} [/itex]
Therefore, measuring the least number of cycle is best
Is it correct?
Common logic tells me measuring once length of several cycles should yield a better result (as the measurement error is effectively divided by the number of cycles, which in an exact number).
Caveat: if the cycles are not identical, this way you will lose the information about variability (variance).
Measuring multiple cycles gives better accuracy if your clock is accurate. If the clock itself is drifting, then it is a nasty question. I think we need more context here.
I would say that it depends on the specific circumstances and goals of the measurement. In general, measuring more cycles of a sine wave can improve the accuracy of the measurement, but it also increases the potential for error. If the goal is to get a rough estimate of the period, then measuring only one cycle may be sufficient. However, if a more precise measurement is needed, it may be beneficial to measure multiple cycles and take an average. Ultimately, the number of cycles to measure should be determined based on the desired level of accuracy and the potential sources of error in the measurement.
Related to How many cycles of time should be measured for the most accurate T?
1. How many cycles of time should be measured for the most accurate T?
The number of cycles of time that should be measured for the most accurate T depends on the specific experiment and the level of precision required. Generally, the more cycles that are measured, the more accurate the T measurement will be. However, it is important to balance the number of cycles with the resources and time available for the experiment.
2. What factors can affect the accuracy of T measurements?
Several factors can affect the accuracy of T measurements, including the quality and precision of the measuring equipment, the environmental conditions in which the experiment is conducted, and the skill and experience of the person conducting the measurements.
3. Is there a minimum number of cycles that should be measured for T?
There is no specific minimum number of cycles that should be measured for T. However, it is generally recommended to measure at least three to five cycles to obtain a reliable average. This can vary depending on the experiment and the level of precision required.
4. How can I ensure the accuracy of my T measurements?
To ensure the accuracy of T measurements, it is important to use high-quality and precise measuring equipment, carefully control and monitor environmental conditions, and follow standardized measurement procedures. It is also helpful to repeat measurements multiple times and calculate an average to account for any potential errors.
5. Can the number of cycles measured for T affect the outcome of my experiment?
The number of cycles measured for T can potentially affect the outcome of an experiment, especially if the T measurement is a critical factor in the experiment. In general, the more cycles that are measured, the more accurate the T measurement will be, which can lead to more reliable and consistent results.
  • Differential Equations
  • Classical Physics
