How many LEDs from fixed supply
In summary, a resistor dropping 27.5 volts with 20 mA flowing in it would have a resistance of 1375 ohms.
John1397
188
How many led's 20ma at 3 volt can one run from a fixed supply voltage of 110 volt dc and a maximum supply of 20ma? I come up with 36.
You can power more, but then they'll be dimmer.
You would have to include the voltage drop across a series resistor.
A rule of thumb is to allow 25% of the supply for a resistor.
So 25% of 110 volts is 27.5 volts.
A resistor dropping 27.5 volts with 20 mA flowing in it would have a resistance of 1375 ohms.
You can't buy these, so you could use 1500 ohms.
Assuming 1375 ohms, this leaves 82.5 volts for the LEDs.
Divide by 3 to get 27.5 LEDs.
Call it 27 LEDs in series with a 1500 ohm resistor.
If you decided to try this, beware of high voltages. You can use them, but obviously the wires and connections must be covered before you apply power.
Also 110 volts DC is not the same as 110 volts AC which comes from wall outlets in some countries.
1. saying 110VDC makes me suspicious. What is the source of your 110VDC, and have you measured it. (just checking)
WHy 110VDC and a single series string rather than a lower voltage and multiple strings? (safer, etc)
2. The voltage drop across each diode can be very different. That is, not all devices are identical. And not all will be the same brightness.
The spec sheet may have typical and worst case numbers which illustrates the issue. Across 30 LEDs this can be significant.
3. A series resistor (as vk6kro said) or other current limiting device is important because of the device variation. 20ma * 27.5V = 0.55W, so get a 1 watt resistor.
Here is a current source example: http://www.instructables.com/id/Power-LED-s---simplest-light-with-constant-current/
4. There are switching LED string driver IC's. http://cds.linear.com/docs/en/design-note/dn461f.pdf, for example
+1 to that.
Are you sure the power supply isn't really a 20mA current source that will work up to 100V ?
Related to How many LEDs from fixed supply
1. How many LEDs can I power with a fixed supply of voltage?
The number of LEDs that can be powered with a fixed supply of voltage depends on the voltage and current requirements of the LEDs. Each LED has a specific voltage and current requirement, and the total current requirement for all the LEDs should not exceed the maximum current output of the power supply. To determine the number of LEDs that can be powered, divide the maximum current output of the power supply by the current requirement of each LED.
2. Can I connect multiple LEDs in series or parallel with a fixed supply?
Yes, you can connect multiple LEDs in series or parallel with a fixed supply. However, it is important to ensure that the total voltage drop of the LEDs in series does not exceed the supply voltage. In parallel, the total current requirement should not exceed the maximum current output of the power supply.
3. How do I calculate the resistor value for my LEDs with a fixed supply?
To calculate the resistor value for your LEDs with a fixed supply, you will need to know the supply voltage, LED voltage, and LED current. Use Ohm's law (V=IR) to determine the resistor value needed. Subtract the LED voltage from the supply voltage, and then divide that by the LED current to get the resistor value in ohms.
4. Can I use a voltage regulator to power my LEDs with a fixed supply?
Yes, you can use a voltage regulator to power your LEDs with a fixed supply. A voltage regulator will ensure that the supply voltage remains constant, even if the demand for current changes. This can be useful if you are using a fixed supply with a high current output.
5. What is the maximum number of LEDs I can power with a fixed supply?
The maximum number of LEDs that can be powered with a fixed supply will depend on the voltage and current requirements of the LEDs, as well as the maximum current output of the power supply. To determine the maximum number of LEDs, divide the maximum current output of the power supply by the current requirement of each LED. However, it is important to always check the data sheet of your power supply and LEDs to ensure safe operation.
  • Electrical Engineering
