How the power of the voltage supply can be calculated?
In summary: The OP needs to provide his definition of "power" for the voltage source, and the specifics of the particle.The power of the voltage supply can be found by multiplying the voltage by the current through the supply.
requied
98
What should be the power of the voltage supply below that we use for producing electric field .
P=IV = IR^2 =V^2/R
I know only these relevant equations for power. But here there is a different situation, we have a parallel plates which we don't have to know I current. How should I think of about this? I wonder if it can be thought of a capasitor or something?
Assume that also we know E, B and velocity .
Likes Delta2
Did you give the complete statement of the problem? In your drawing you show a magnetic field and a particle moving through the E and B fields. But, the problem statement doesn't mention anything about these.
Are you supposed to find the power of the voltage supply or are you supposed to find the voltage of the power supply?
From what you have shown, it looks to be a simple capacitor, so no current is flowing. If I=0, then what is the power?
I am guessing that the OP is troubled by the following fact:
As the particle accelerates under the influence of electric field, if this accelerated movement corresponds to some sort of current, and where the energy comes from that increases the kinetic energy of the particle.
My answer to this is that though this movement is indeed a current, still this current is not drawn from the voltage source, and the energy that increases the kinetic energy of the particle does not come from the source but from the initial potential energy of the particle inside the field.
The energy to produce the E-field is drawn from the voltage source and it is $$E=\frac{1}{2}CV^2$$ where C the capacitance of the capacitor. This energy is drawn when capacitor is charged.
requied said:
Relevant Equations:: P=IV = IR^2 =V^2/R
You might want to verify those for future use, one of them is incorrect.
I spesified it on the homework statement.
It's that easy really? I supposed that I would do some complex calculations :/
I didn't ask the question for anything about the kinetic energy of the particle. You misunderstood me . I just wondered that what is the voltage supply's power.
No power is required to maintain the electric field in isolation. The moving particle, which you did not mention in the problem description, must be relevant.
Would I be right in thinking there is a stream of such particles? Whatever, please post the entire question as given to you.
This looks suspiciously like the sort of problem where one should calculate the potential difference between the deflection plates that will result in a linear trajectory for a given charged particle passing through a fixed magnetic field.
This is a piece of a spectrometer question and this region above is the velocity selector region. The question says "What should be the power of the voltage supply that we will use in velocity selector region?".
I think it is not a problem to just take this area about the question. I assumed that we already know the values I found in other regions
That will occur on spectrometer
Likes Delta2
Related to How the power of the voltage supply can be calculated?
1. How is voltage supply calculated?
Voltage supply is calculated by dividing the power (in watts) by the current (in amps). This equation is known as Ohm's Law: V = P/I.
2. What factors affect the calculation of voltage supply?
The calculation of voltage supply is affected by the resistance of the circuit, the amount of current flowing through the circuit, and the type of power source being used (e.g. AC or DC).
3. Can the voltage supply be calculated for both AC and DC circuits?
Yes, the equation for calculating voltage supply (V = P/I) can be used for both AC and DC circuits. However, the values for power and current may differ depending on the type of circuit.
4. How can the power of the voltage supply be measured?
The power of the voltage supply can be measured using a voltmeter and an ammeter. The voltmeter measures the voltage (in volts) and the ammeter measures the current (in amps). The power can then be calculated using the equation P = VI.
5. What are some practical applications of calculating voltage supply?
Calculating voltage supply is important in various fields such as electrical engineering, physics, and electronics. It is used to design and troubleshoot circuits, determine the efficiency of power sources, and ensure safety in electrical systems.
  • Electrical Engineering
