How to 1/4x + 2/9 - 14 = 100
  • Thread starter kyphysics
In summary, Mastermind said that 1/4 is a coefficent of x and that x is NOT in the denominator of the first fraction.
kyphysics
676
436
Solve equation for x above.
See title.
Step 1: add 14 to both sides
1/4x + 2/9 = 114
Step 2: This is where my memory is a bit fuzzy.
I know we can obtain like bases between 1/4x and 2/9, but that wouldn't seem super helpful, because they aren't like terms is that correct? I figured 1/4 and 2/9 would be like terms, but 1/4x and 2/9 aren't and cannot be combined.
If that's the case, then it seems I'd have to deal with each fraction in both terms separately and one-by-one.
I chose to "get rid" of the 2/9 fraction first by multiplying it by 9/1 (as well as ever other term on both sides by the same 9/1) and got:
9/4x + 2 = 1026
Step 3: Subtract 2 from both sides
9/4x = 1024
Step 4: Get rid of fraction by multiplying both sides by 4/1 and this yields:
9x = 4096
Step 5: Divide both sides by 9 to isolate the x and get:
x = 455.11111111...
Not 100% sure I did this correctly. And wondering also if there was a different or easier way?
You're main object is to get ##x## by itself. Regarding step #2, you can treat ##\frac{2}{9}## the same way you treated ##-14##. They are like terms, after all.
Is your equation [itex]\frac{1}{4x}[/itex] or [itex]\frac{x}{4}[/itex] ? If it's the former then you have done it incorrectly
I believe that he was implying the former.
Then his last step his wrong , if he multiplies both sides by 4/1 he would get [itex]\frac{9}{x} = 4096[/itex] . Not the other way.
Likes ProfuselyQuarky
Hi, Mastermind
1/4 is a coefficent of x. Apologies, b/c I don't know how to use the symbols stuff here yet. So, the x is NOT in the denominator of the first fraction.
kyphysics said:
Hi, Mastermind
In that case, I believe that you're correct.
Likes Mastermind01
kyphysics said:
Hi, Mastermind
Right. You have done it correctly then.
P.S : Here's a guide to Latex which implements the math symbols here: https://www.physicsforums.com/threads/introducing-latex-math-typesetting.8997/ This will help avoid future confusion.
Oh, good to know I'm correct. Very rusty with certain topics that I'm trying to plug leaks in this summer.
I am aware of LaTex, but haven't had time to really delve into learning it yet. I want to do so this summer though! I believe it will help me tremendously next year.
Likes Mastermind01
Good luck then!
Wait!
Did you mean my last step was wrong even IF I meant 1/4 as the coefficient of x, instead of x being in the denominator?
The two options you presented earlier weren't what I had meant. So just double checking one last time! Thanks again!
kyphysics said:
Wait!
No worries. Your last step is wrong only if x is in the denominator. Else it's correct.
gotcha, thx
kyphysics said:
Hi, Mastermind
Then use parentheses to remove all doubt.
What you wrote, 1/4x , literally means (1/4)x and is what you intended. However, if you include the parentheses, you remove all doubt regarding what you intended.
1. What is the first step in solving "1/4x + 2/9 - 14 = 100"?
The first step is to simplify the equation by finding a common denominator for 1/4 and 2/9. In this case, the common denominator is 36. So the equation becomes 9/36x + 8/36 - 14 = 100.
2. How do you isolate the variable in "1/4x + 2/9 - 14 = 100"?
To isolate the variable, you need to get rid of all the other terms on the same side of the equation. In this case, you can start by subtracting 8/36 from both sides, which gives you 9/36x - 14 = 92. Then, you can add 14 to both sides, which gives you 9/36x = 106. Finally, you can multiply both sides by 36 to get rid of the fraction, giving you x = 954.
3. Can the equation "1/4x + 2/9 - 14 = 100" be solved without a calculator?
Yes, it can be solved without a calculator. You can use mental math or paper and pencil to simplify the equation and solve for x.
4. Is there more than one possible solution for "1/4x + 2/9 - 14 = 100"?
No, there is only one possible solution for this equation. Once you have simplified the equation and isolated the variable, there is only one value for x that will make the equation true.
5. Can you check your answer for "1/4x + 2/9 - 14 = 100"?
Yes, you can plug your answer back into the original equation to check if it is correct. In this case, plugging in x = 954 gives you 1/4(954) + 2/9 - 14 = 100, which simplifies to 238.5 + 8/9 - 14 = 100. After finding a common denominator and simplifying, you will see that the equation is true, confirming that x = 954 is the correct solution.
