PainterGuy
- 940
- 69
Hi,
Suppose I need to cite some information from a source. I think it'd be easier to explain using an example.
In the text below titled "Example Text", I have added the sentences, "Hall effect encoders are also called magnetic encoders. They are very popular with hobbyists these days and have many Arduino libraries readily available.", but the rest of text is exactly taken from reference #1.
The reader might think that only the second paragraph is taken from reference #1 and the paragraph #1 is my own words. How do I clarify it to the reader?
I would prefer to keep the as it is in two paragraphs.Example Text:
Hall effect encoders are also called magnetic encoders. They are very popular with hobbyists these days and have many Arduino libraries readily available. Magnetic encoders use a combination of permanent magnets and magnetic sensors to detect movement and position. A typical construction uses magnets placed around the edge of a rotor disc attached to a shaft and positioned so the sensor detects changes in the magnetic field as the alternating poles of the magnet pass over it.
The simplest configuration would have a single magnet, with its north and south poles on opposite edges of the rotor, and a single sensor. Such a device would produce a sine wave output with a frequency equal to the rotational speed of the shaft. [1]
REFERENCES
[1] G. Monari, "Understanding Resolution In Optical And Magnetic Encoders," [Online]. Available: https://www.electronicdesign.com/te...ng-resolution-in-optical-and-magneticencoders.
[November 18 11 2021].
REFERENCES
