How to deal with this Neumann boundary conditions?
In summary: Firstly, we need to find phi(t). This is easy enough, we just solve for u(z,t) using the initial condition and the known phi. Next, we need to find h(z,t). This is a little bit more difficult. We need to find a function h such that v(z,t) = u(z,t) - h(z,t) for all z. However, we don't know what h is at z=0. So we need to solve for h at z=0. To do this, we need to solve for u(z,0), and then use that to solve for h at z=0. In summary, In
daz71
hi all,
I am trying to solve this PDE by separation of variables, it goes like this:
[tex]\frac{\partial u}{\partial t} = \alpha\frac{\partial ^2 u}{\partial z^2} [/tex] for [tex]0\leq z\leq infty[/tex]
the initial condition I have is: t=0; u = uo.
the boundary condtions:
z=0; [tex]\frac{\partial u}{\partial z}\right\rfloor_{z=0} = k\left(u-u_{b}\right) ... ...(1)[/tex]
z= [tex]\infty[/tex]; [tex]\frac{\partial u}{\partial z}\right\rfloor_{z=\infty} = 0...(2)[/tex]
where, uo, [tex]k[/tex],[tex]u_{b}[/tex], and h are constants.
I write:
u(z,t) = F(z)G(t),
with the subsitition I got:
[tex]\frac{1}{G}\frac{\partial G}{\partial t} = \frac{\alpha}{F}\frac{\partial ^2 F}{\partial Z^2}[/tex]
Setting this to some constant: [tex]omega^2[/tex], I can have the two ODEs.
The problem is when I try to use the first boundary condition, bcos of the second term in the parenthesis of the RHS, I seem to have [tex]\frac{u_{b}}{G}[/tex], which I have no clue how to deal with.
pls could some one point to me how i can go about this?
thanks in advance.
I'm not sure if I understand your first boundary condition:
[tex]
[/tex]
Is that u = u(0,t)?
Maybe its my fault, for not understanding what that u is. If u is a constant also (like ub), then your approach is right. You need to find the eigenfunction of z, F(Z). Once you do that, use the Boundary conditions to find omega^2. Once you do this, you can solve for G(t).
If its not constant, then you need to define a new function v(z,t)= u(z-t)- h(z), such that v has a PDE of the same form as u. However, v will have homogeneous BC's.
Hence, I personally need to have a better understanding of the first BC to help you. Good Luck!
Hi aq1q,
Pardon me for the messy representation of the equations,
the bcs should read:
1) [tex]\ z = 0[/tex]; [tex]\left[\frac{\partial u}{\partial z}\right]_{z=0}= k\left(u - u_{b}\right)[/tex]
2) z = [tex]\infty[/tex]; [tex]\left[\frac{\partial u}{\partial z}\right]_{\infty} = 0[/tex]
where k, and ub are constants
daz71 said:
Hi aq1q,
what about u (on the left side of the parenthesis)? is that constant? Is it a function of t? Is that u(z,t)? what does that stand for?
Hi aq1q,
In the RHS of bc 1, u is not a constant but rather the dependant variable(the u in the derivative). so I guess your second suggestion will be the option for me, but could u pls tell me more abt this step:
'v(z,t)= u(z-t)- h(z)'
do you mean u(z,t) as in the orginal problem?
daz71 said:
Hi aq1q,
So which variable is it dependent of? t?
Hi aq1q,
I apologised, the first condition is actually convective boundary.
so the u on the left is actually the same u in the derivative: u(z,t).
ahh, no, no its not your fault. It's mine. I was a bit confused because I thought it was a form of neuman boundary.
In that case, I'm lost. I'll try to figure it out. Sorry I couldn't be of more help. It doesn't make sense how Uz(0,t)= K(U(z,t)- Ub) on the boundary (excuse my capitalization of u). Anyhow, I doubt that's the case. Would you mind me asking if this is a problem from a textbook? I looked through my PDE textbook and couldn't find anything on convective boundary conditions.
If it is u(0,t), then I can probably help
Hi aq1q,
the problem is getting me stirred up as well that I can't figure out this error, yes certainly you are right it should read u(0,t) because it is the temperature at z = 0 that we are dealing with at any point in time as we implement the bc. So any suggestions in that case?
thanks.
Hello aq1q,
No the problem is not from a textbook, I set it up myself. But I can asure is no home work as well :)
thanks.
ahh ok. So, i'll just tell you up front. I'm still a second year undergrad student. Obviously, I'm NOTHING compared to some of the people here. So please excuse me if I have bit of a difficulty with it. Nonetheless, this looks like an interesting problem! Let's attempt it together.
Ok, going back to what I was saying earlier. Let u(0,t)= [tex]\phi[/tex](t). Hence, we have to define a h(z,t) such that v(z,t)= u(z,t) - h(z,t). This is important because we want V to have homogeneous boundary conditions; hence, when we solve V using separation of variables we won't get stuck on the boundary conditions.
So let's try solving for this h(z,t). I'll try it also
I think this approach will work. I could be wrong, of course. Also, we might need to make some assumptions about Ub (we will get to that later)
daz71 said:
Hello aq1q,
thanks.
well yes, i didn't think this was a homework. Normally for non-trivial homeworks you would be given a hint. You set this yourself?! Then you should be able to answer my questions about "u"? So, obviously the "u" can't be u(z,t) for the first boundary condition... you understand that right?
hi aq1q,
OK, that very encouraging, we do it together as you said. I am sure you are very capable to guide me through.
thanks alot.
Understand that when you make up your own problem (what is this for btw? for a research? or just for fun?) you have to check for uniqueness. We can't assume uniqueness for u, this would have to be proven (and I highly doubt its unique). Hence, h(z,t) is not unique either, and you might have infinite solutions (this is a possibility).
Anyway, I got something like this for h(z,t).
let u(0,t)= [tex]\phi(t)[/tex]
h(z,t)= [tex] e^{-k(\phi(t)-u_b)z} [/tex]
do you see why this works? (assume [tex]\phi(t) >= u_b [/tex]
we set v(z,t)= u(z,t) - h(z,t). Find Vz(0,t) and Vz(inf, t). what do you get?
Hi aq1q,
yes to experment research possibilities, so I need to have some kind of solution for the heat equation (which is standard) , but imposing these bcs.
But you are faster than I thought though, cos I you got the h(z,t) even b4 I figure out how to go about it.
daz71 said:
Hi aq1q,
Ignore what i got for h(z,t), it doesn't work for the given PDE. Vt does not equal to (alpha)*Vzz. However, its still important to realize u(z,t) is probably not unique, and uniqueness is important.
Hm its about 2:15 am in my time. I'm really tired and sleepy, but I have a feeling you will need to modify your PDE or your boundary conditions. Otherwise, it might not be solvable. I'll promise to help tomorrow, but I really need to sleep now.. I can't think straight haha. Good Luck!
hi aq1q,
My line of thinking is that I am to use the soln for u(z,t) which is for the case at hand wll be of the form:
Aexp(wt) + Bexpt(-wt).
where A and B are to be determined.
so if we introduce h(z,t)
V(z,t) = Aexpt(wt) + Bexpt(-wt) - expt(-k(phi -ub)z)
right?
aq1q said:
Ignore my previous post, it doesn't work for the given PDE. Vt does not equal to (alpha)*Vzz. Hm its about 2:15 am in my time. I'm really tired and sleepy. I'll help you tomorrow. Good luck!
Hi aq1q,
Thank you very much, you have been absolutely amazing for your kind assistance.
I guess you should go and rest, I shall meet you up tomorrow hopefully with some leeway.
Thank you alot!
hey daz71,
Have you made any progress? So, obviously I'm getting stuck on the bounds you imposed. I'm guessing that you reached those bounds through experimentation, which is why I am not questioning it. Moreover, I don't have much experience with experimentation. How sure are you of the second boundary condition for z= infinity?
Here's what I think: your PDE might need some modification. How sure are you that you are dealing with a homogeneous diffusion equation. It is a possibility that you have a source function. Example: [tex] u_t - \alpha u_{zz} = f(z,t) [/tex]. If you don't think this is the case, let me know.
Sorry, I know I am not actually helping with these questions but your PDE and the boundary values must agree with each other.
Hello aq1q,
thank you for your reply, I am afraid I did not make any break through. Apart from a paper I have seen that have a similar problem formulation, the only diffrence is that the boundary condition they have at z = infinity is a Dritchlet condition i.e, u(infinity, t) = uc, where uc is a constant temperature. I did not see their general solution, but they reported an expression for the u(0,t) as:
[tex] u(0,t) = u_{b} + (u0 - u_{b})exp(k^2\alpha t)erf(k\sqrt{\alpha t}[/tex])
can you help figure ouit how they arrive at this? I have no clue at all!
thanks in advance.
daz71 said:
Hello aq1q,
thanks in advance.
It is very likely that they used wolfram alpha, Mathematica, or MATLAB to solve for the two ODE's: F(z) and G(t). You can let u(0,t) = h(t). Then once u(z,t) is solved for, its not hard to find something like that. But again, I would need to see what their PDE was, and the boundary conditions. I am starting to think that your the PDE :
[tex]
u_{tt} = \alpha u_{zz} [/tex] is NOT homogeneous... [tex] \Rightarrow
\frac{\partial u}{\partial t} \neq \alpha\frac{\partial ^2 u}{\partial z^2} [/tex]
hi aq1q,
As I have said, their PDE is exactly like mine, their boundary condition at z = 0 is also same as mine, the only difference is their bc at z = infinity, in which they have:
u(infnity, t) = uc (a constant), and I have du/dz = 0 instaed. But let me remark that they did not claim to have used separtion of variables to solve the equation in the paper, so we are free to think of other methods as well.
thanks
Related to How to deal with this Neumann boundary conditions?
1. What are Neumann boundary conditions?
Neumann boundary conditions are a type of boundary condition often used in mathematical and scientific contexts. They specify the value of the derivative of a function at the boundary of a domain, rather than the value of the function itself.
2. How do Neumann boundary conditions differ from Dirichlet boundary conditions?
Neumann boundary conditions specify the value of the derivative at the boundary, while Dirichlet boundary conditions specify the value of the function at the boundary. In other words, Neumann boundary conditions involve the slope of a function at the boundary, while Dirichlet boundary conditions involve the value of the function at the boundary.
3. How do I apply Neumann boundary conditions in my scientific research?
The application of Neumann boundary conditions depends on the specific problem you are trying to solve. In general, it involves incorporating the specified derivative value into your mathematical model and solving for the function using techniques such as differential equations or numerical methods.
4. What are some common challenges in dealing with Neumann boundary conditions?
One common challenge is determining the appropriate value for the specified derivative at the boundary. This often requires a thorough understanding of the physical or mathematical problem at hand. Another challenge is accurately incorporating the boundary conditions into the mathematical model, which may require advanced techniques and computational resources.
5. Are there any limitations or assumptions associated with Neumann boundary conditions?
Neumann boundary conditions assume that the derivative of the function at the boundary is constant. This may not always be the case in real-world scenarios, and in these cases, Neumann boundary conditions may not accurately represent the behavior of the system. Additionally, Neumann boundary conditions may not be suitable for certain types of problems, such as those with discontinuous or non-differentiable solutions.
  • Differential Equations
