How to understand it inituitively?
  • Thread starter eraserxp
In summary, the determinant of a matrix is a way of measuring the scale of a linear transformation. If the transformation has a lower dimension than the space in which it exists, then the determinant of the matrix will be zero.
eraserxp
I have come across a theorem which says that det(A)=0 if and only if the row (or column) vectors of A are linearly dependent.
I can understand the proof for it, but fails to figure out what's the essential meaning of this theorem. Can someone provide me a simple intuitutive understanding of this theorem? By intitutive understanding, I mean something that one can assure himself of some result without doing much derivation.
Thanks in advance!
One way of looking at the determinants is that they are simply the factor of contraction/expansion that a transformation matrix exerts on a n-dimensional volume on a n-dimensional space. If that transformation has a lower dimension that the space in which it exists (it's vectors are not linearly independent), then it won't do anything to that n-volume.
Depending on what you are working, you can't take a lot more of information from the determinant of a linear transformation, like the implicit function theorem for example.
I personally like this geometric interpretation: you can view the n x m matrix A as a linear transformation from U = Rn to V = Rm.
Then the i-th column, for example, gives the coordinates of a basis vector in V expressed in some set of basis vectors in U. The determinant det(A) is some measure of scale, for example the scale factor of a parallelogram spanned by two vectors.
Then det(A) = 0 means that the parallelogram is collapsed to something one-dimensional. In a suitable choice of basis then, two basis vectors are mapped to the same image, up to a rescaling. Thus, two of the colums will be multiples of one another. This property itself is not preserved when you choose a different basis, but still there will be some column which is a linear combination of the others.
Since column and row space are related by transposition, the same argument holds for row space.
Thanks guys! I understand the theorem now.
Thanks guys.
After reading about your posts, I came up with the following understanding:
Suppose Matrix(A) transforms the geometrical shape whose edges are row vectors of identity matrix I. The edges of resulted geometrical shape are the column vectors of Matrix(A).
For the geometrical ratio to be zero, the resulted geometrical shape after the linear transformation must have lower dimensions than the original geometrical shape, therefore, at least one edge must lie in the plane of other two edges. So one column vector of Matrix(A) must be a linear combination of other two column vectors.
The way I sort of see this to be true is to do with row reduction. You know that if you add a multiple of one row or column to another then you don't change the determinant. You also know that if the rows or columns are dependent then you will be able to get a row of zeros by doing this.
And you know that the determinant of any matrix with a row or column of zeros MUST be zero due to the way its computed... so...
More intuitively I guess in the 3 by 3 case its sort of like asking what the volume is of a subset of a plane... Think of the definition of the volume of a paralellpiped (scalar triple product of the 3 vectors), ie the determinant of the matrix with each of the 3 vectors a row. If this set of 3 vectors is dependent then the paralellpiped (well it won't be a paralellpiped in this case) will be on a plane (or a line), and its volume will naturally be 0
The determinant computes the hyper-volume of ihe parallelopiped spanned by its rows.
It is an exercise in Euclidean coordinate geometry that its algebraic formula is the formula for the volume.
Related to How to understand it inituitively?
1. What does it mean to understand something intuitively?
To understand something intuitively means to have a deep, innate understanding of a concept or idea without needing to explicitly analyze or explain it. It is a gut feeling or natural sense of understanding that allows one to grasp complex ideas without relying on logical reasoning or external information.
2. How can one develop intuitive understanding?
Intuitive understanding can be developed through practice and experience. By actively engaging with a concept or idea, and learning to trust your instincts and gut feelings, you can develop a stronger sense of intuition and understanding.
3. Is intuitive understanding the same as critical thinking?
No, intuitive understanding and critical thinking are different. Critical thinking involves analyzing and evaluating information to form a logical conclusion, while intuitive understanding relies on gut feelings and innate understanding.
4. Can everyone develop intuitive understanding?
Yes, everyone has the ability to develop intuitive understanding. Some individuals may have a stronger natural sense of intuition, but with practice and experience, anyone can develop their intuitive understanding skills.
5. How can intuitive understanding be applied in scientific research?
Intuitive understanding can be applied in scientific research by allowing scientists to make connections and see patterns that may not be apparent through traditional analytical methods. It can also help guide decision making and problem solving in complex research projects.
  • Linear and Abstract Algebra
