Hydrostatic Pressure Question?
In summary, a diving bell was used to rescue trapped crewmen from a sunken submarine. When the diving bell was lowered to the bottom of the sea, the water rose to a certain height inside the bell before stopping. This is due to changes in pressure and specific gravity, which is affected by temperature. It is not necessary to know the radius of the diving bell in order to solve for the height of the water inside.
Jason Onwenu
During a test dive in 1939, prior to being accepted by the U.S. Navy, the submarine Squalus sank at a point where the depth of water was 73.0 m. The temperature at the surface was 27.0 ∘C and at the bottom it was 7.0 ∘C. The density of seawater is 1030 kg/m3. A diving bell was used to rescue 33 trapped crewmen from the Squalus. The diving bell was in the form of a circular cylinder 2.30 m high, open at the bottom and closed at the top. When the diving bell was lowered to the bottom of the sea, to what height did water rise within the diving bell? (Hint: You may ignore the relatively small variation in water pressure between the bottom of the bell and the surface of the water within the bell.)
P = rho * g * height
PV = nRT
P1V1/T1 = P2V2/T2
V = pi * radius^2 * height
P(bottom) = 101325 + (1030*9.8*73) = 838137 Pa
V2 = ? (The radius wasn't given...)
T2 = 280.15 K
P(top) = 101325
V1 = ? (The radius wasn't given...)
T1 = 303.15K
At this point, I couldn't really proceed with my calculations because a radius wasn't given. I'm wondering if I could solve for the radius with the information given or if the radius is even needed at all.
You should ask yourself this question: Why does the water stop rising inside the diving bell when it is lowered onto the submarine?
Once you answer this question, think about whether you need to know the radius of the cylinder.
I'm guessing it has something to do with (specific) gravity? Since there is a difference in temperature?
Jason Onwenu said:
I'm thinking it has something to do with (specific) gravity?
Why would specific gravity stop water from rising inside the diving bell?
Isn't the specific gravity of the water inside the diving bell the same as the specific gravity of the water outside?
Hint: Think about what is changing inside the bell as the water rises.
Pressure changes...
Is specific gravity a constant value for a specific substance? Or does it vary with temperature?
Do calculations until the end and then ask if you need the radius.
Related to Hydrostatic Pressure Question?
1. What is hydrostatic pressure?
Hydrostatic pressure is the force exerted by a fluid at rest due to the weight of the fluid above it. It is a result of the gravitational pull on the fluid and is directly proportional to the density of the fluid.
2. How is hydrostatic pressure calculated?
Hydrostatic pressure can be calculated using the formula P = ρgh, where P is the pressure, ρ is the density of the fluid, g is the acceleration due to gravity, and h is the height of the fluid column.
3. What is the difference between hydrostatic pressure and atmospheric pressure?
Hydrostatic pressure is the pressure exerted by a fluid due to its weight, while atmospheric pressure is the pressure exerted by the Earth's atmosphere. Hydrostatic pressure varies with depth, while atmospheric pressure decreases with increasing altitude.
4. What are the applications of hydrostatic pressure?
Hydrostatic pressure is used in various fields such as engineering, medicine, and geology. It is used in hydraulic systems to lift heavy objects, in scuba diving to regulate depth, and in studying the Earth's crust and its movements.
5. How does hydrostatic pressure affect the human body?
Hydrostatic pressure can have significant effects on the human body, especially at high depths. It can cause discomfort, pain, and even injury to the ears and sinuses. At extreme depths, it can lead to nitrogen narcosis and decompression sickness in scuba divers.
