If statement & PopUp window in React
In summary: Left: '55%' }} /> Yes </label> } position="right center" > <div> <h3>Why</h3> <label>
  • #36
pbuk said:
Well I'd be inclined to flatten the tree in the response into an object with the id as the key:
JavaScript:
  'id-1234': {
    title: '...',
    children: [
      'id-2345',
      'id-9876',
  'id-2345': {
which will make it much easier to use, but otherwise, yes.
I haven't understood what you mean. Could you explain that further to me?
Technology news on Phys.org
  • #37
Do you mean how to store the tree in a redux tree or what do you mean by the above?
  • #38
Well here is the beginning of the response:
JavaScript:
    "tree_structure": [
        "TypeDefinition": "Namespace",
        "IndexName": "0:Objects",
        "URI": "http://opcfoundation.org/UA/",
        "Nodes": [
            "DisplayName": "Objects",
            "Attributes": [
                "NodeId": "i=85",
                "NodeClass": "Object",
                "BrowseName": "Objects",
                "Description": null,
                "WriteMask": null,
                "UserWriteMask": null,
                "EventNotifier": null
            "Nodes": [
                "DisplayName": "Server",
                "Attributes": [
                    "NodeId": "i=2253",
                    "BrowseName": "Server",
                    "WriteMask": null,
                    "EventNotifier": ["SubscribeToEvents"]
                "Nodes": [
                    "DisplayName": "ServerStatus",
                    "Attributes": [
                        "NodeId": "i=2256",
                        "NodeClass": "Variable",
                        "BrowseName": "ServerStatus",
                        "WriteMask": null,
                        "Value": "ServerStatusDataType(StartTime=datetime.datetime(2022, 9, 27, 7, 45, 53, 181000), CurrentTime=datetime.datetime(2022, 9, 27, 14, 57, 5, 827000), State=<ServerState.Running: 0>, BuildInfo_=BuildInfo(ProductUri='urn:prosysopc.com:OPCUA:SimulationServer', ManufacturerName='Prosys OPC Ltd.', ProductName='SimulationServer@DESKTOP-VN3GQ4Q', SoftwareVersion='5.3.0', BuildNumber='64', BuildDate=datetime.datetime(1970, 1, 1, 0, 0)), SecondsTillShutdown=0, ShutdownReason=LocalizedText(Locale='', Text=''))",
                        "DataType": "ExtensionObject",
                        "ValueRank": "Scalar",
                        "AccessLevel": ["CurrentRead"],
                        "UserAccessLevel": ["CurrentRead"],
                        "MinimumSamplingInterval": 1000.0,
                        "Historizing": false
Let's say you want to display the minumum sampling interval for the node with id "i=2256": this is not going to be easy. If instead you parse this tree into a flat structure:
JavaScript:
  "tree_structure": {
    // Note the change from an array to a POJO.
    "Nodes": {
      "i=85" : {
        "Attributes": [
            "NodeId": "i=85",
            "WriteMask": null,
        parent: null,
        children: [
          "i=2253",
      "i-2253": {
        "Attributes": [
            "NodeId": "i=2253",
            "WriteMask": null,
        parent: "i=85",
        children: [
          "i=2256",
      "i=2256": {
        "Attributes": [
            "NodeId": "i=2256",
            "WriteMask": null,
        parent: "i=2253",
        children: [
      // More nodes.
it's going to be much easier, it's just data.tree_structure.Nodes['i=2253'].Attributes[0].MinimumSamplingInterval
Likes mathmari
  • #39
And using the redux store this is possible?
  • #40
For the beginning I tried to do that with a non elegant way, to get all data by for loops, I used 3 for loops. I am not reallt sure if I print it correctly with the <TreeView>, could you take a look at it ?
JavaScript:
    const [dataObj, setDataObj] = useState([]);
    useEffect(() => {
        fetch('https://giant-db-connection.onrender.com/opc_ua_tree/')
            .then((res) => res.json())
            .then((data) => {
                setDataObj(data[0]['tree_structure'][0].Nodes[0]);
                console.log(data[0]['tree_structure'][0].Nodes[0].DisplayName);
                <TreeView
                    aria-label="file system navigator"
                    sx={{ flexGrow: 1, overflowY: 'auto' }}
                    style={{ height: '34vh', width: '100%' }}
                    <TreeItem nodeId={data[0]['tree_structure'][0].Nodes[0].DisplayName} label={data[0]['tree_structure'][0].Nodes[0].DisplayName}>
                        for (let i = 0; i < data[0]['tree_structure'][0].Nodes[0].Nodes.length; i++) {
                            console.log(data[0]['tree_structure'][0].Nodes[0].Nodes[i].DisplayName);
                            <TreeItem nodeId={data[0]['tree_structure'][0].Nodes[0].Nodes[i].DisplayName} label={data[0]['tree_structure'][0].Nodes[0].Nodes[i].DisplayName}>
                                for (let j = 0; j < data[0]['tree_structure'][0].Nodes[0].Nodes[i].Nodes.length; j++) {
                                    console.log(data[0]['tree_structure'][0].Nodes[0].Nodes[i].Nodes[j].DisplayName);
                                    <TreeItem nodeId={data[0]['tree_structure'][0].Nodes[0].Nodes[i].Nodes[j].DisplayName} label={data[0]['tree_structure'][0].Nodes[0].Nodes[i].Nodes[j].DisplayName} />
                            </TreeItem>
                    </TreeItem>
                </TreeView>
  • #41
Or isn't it possible to use a for-loop inside the TreeView? Do we maybe have to use an extra function for that? 🤔
  • #42
That won't work. You need to build it recursively, something like this:
JavaScript:
  const tree = {
    server: null,
    treeId: null,
    rootNodeId: null,
    nodes: {},
  const loadTree = async () => {
    const data = await fetchTree();
    tree.server = data[0].server;
    tree.treeId = data[0].tree_id;
    tree.nodes = {};
    const { id } = parseNode(data[0].tree_structure[0].Nodes[0], tree.nodes);
    tree.rootNodeId = id;
  const parseNode = (rawNode, nodes) => {
    // Recursively parse the child nodes, adding to this nodes children.
    const children = [];
    (rawNode.Nodes ?? []).forEach((item) => {
      const { id } = parseNode(item, nodes);
      children.push(id);
    // Create this node.
    const node = {
      title: rawNode.DisplayName,
      children,
      attributes: rawNode.Attributes,
    // Save this node to the dictionary.
    nodes[id] = node;
    // Return the node so the caller can get the id.
    return node;
Likes mathmari
  • #43
JavaScript:
  const tree = {
    server: null,
    treeId: null,
    rootNodeId: null,
    nodes: {},
    tree.nodes = {};
      children.push(id);
    const node = {
      children,
    nodes[id] = node;
    return node;
When we initialize the tree, the keys are the one of the first level of the endpoint ? I mean the following :
Could you explain to me the function loadTree ? According to the picture I loaded above we have :
tree.server = data[0].server = 41
tree.treeId = data[0].tree_id = 19
Or not? Could you explain to me the following part?
tree.nodes = {};
tree.rootNodeId = id;With the function parseNode do we parse through all children nodes?
  • #44
Is the idea to buid the tree that we get from the API again from scratch? 🤔
  • #45
Yes. Working with a nested tree is practically impossible so this is standard practice.
Rather than explain every element I have created a basic but fully working application in plain JavaScript with no dependencies. You can see the code as a GitHub gist and you can see it working below. Note that sometimes the API does not respond first time, I guess this is due to some limitations on the, possibly free, cloud service.
The code doesn't have many comments in, that is deliberate so you can work through it and see how it all works, and then convert it to React.js using your component libraries of choice, and if you wish Redux (although if all you are going to do is display the data you fetch there is no need to use Redux for this).
  • #46
Of course if whoever had designed the API had done a better job we wouldn't have to do this.
There are some other odd things about the API response, for instance why is Attributes an array with a single element? Why do the id's not have a regular form: many start with "i=" but some look like e.g. "ns=1;s=79f4049c-8266-4758-9c5a-0013e39273d7/0:SessionDiagnostics/0:ActualSessionTimeout"? Why do some nodes exist at more than one point in the tree (hopefully with the same values) e.g. i=2341?
These are rhetorical questions, I think I'm done here.
  • Electrical Engineering
  • STEM Academic Advising
