How Does Inductance Affect Light Dimming in AC Circuits?
In summary, the conversation discusses the use of a "light dimmer" in a theater to adjust the brightness of stage lights. The circuit consists of a variable inductor and a lightbulb connected in series, with an electrical supply of 240 V (rms) at 50.0 Hz. The lightbulb is rated as "240 V, 1000 W." The question at hand is determining the required value of Lmax to vary the energy dissipation in the lightbulb by a factor of 5, assuming the resistance of the lightbulb is independent of temperature. The conversation mentions using the formula for power, resistance, and current to calculate the necessary rms current through the lightbulb, but the inclusion
Sefrez
126
I cannot seem to solve this problem:
A typical "light dimmer" used to dim the stage lights in a theater consists of a variable inductor L (whose inductance is adjustable between zero and Lmax) connected in series with the lightbulb B as shown in Figure 31-36. The electrical supply is 240 V (rms) at 50.0 Hz; the lightbulb is rated as "240 V, 1000 W."
What Lmax is required if the rate of energy dissipation in the lightbulb is to be varied by a factor of 5 from its upper limit of 1000 W? Assume that the resistance of the lightbulb is independent of its temperature.
It seems like this is an RL circuit with ac current, but my book seems to speak nothing of them. I figure if you want the light bulb to draw a minimum of 200W that the rms current through it must be ~1.863A. That is I found the resistance of the bulb to be 57.6 ohms with the given (240V, 1000W) and for there to be a 200W output 200W = Irms^2 * 57.6 ohms => Irms = ~1.863A.
But I have no idea how to incorporate the inductor.
Have you learned about the impedance of ac circuits?
ehild
Related to How Does Inductance Affect Light Dimming in AC Circuits?
1. What is an inductor lightbulb circuit?
An inductor lightbulb circuit is a type of electric circuit that contains both an inductor and a lightbulb. The inductor is a passive electronic component that stores energy in the form of a magnetic field, while the lightbulb is a device that converts electrical energy into light. When connected together in a circuit, the inductor can regulate the flow of electricity to the lightbulb, resulting in a steady and controlled amount of light.
2. How does an inductor lightbulb circuit work?
In an inductor lightbulb circuit, the inductor acts as a resistor and limits the flow of electricity to the lightbulb. This is due to the inductor's ability to generate a magnetic field when electricity passes through it. As the current passes through the inductor, the magnetic field grows, which in turn creates an opposing force to the flow of electricity. This results in a steady and controlled flow of electricity to the lightbulb, allowing it to illuminate without being overloaded.
3. What are the advantages of using an inductor lightbulb circuit?
There are several advantages to using an inductor lightbulb circuit. Firstly, the inductor helps to regulate the flow of electricity, resulting in a steady and consistent amount of light. Secondly, the use of an inductor can also help to prolong the lifespan of the lightbulb as it prevents it from being overloaded. Additionally, inductor lightbulb circuits are efficient and can help to reduce energy consumption, making them environmentally friendly.
4. What are the common applications of inductor lightbulb circuits?
Inductor lightbulb circuits are commonly used in various electronic devices and appliances. They are often found in household light fixtures, as well as in industrial and commercial settings. They are also used in electronic devices such as radios, televisions, and computers to regulate the flow of electricity and prevent damage to the components.
5. Are there any limitations to using an inductor lightbulb circuit?
There are a few limitations to using an inductor lightbulb circuit. One limitation is that inductors can only regulate the flow of AC (alternating current) electricity, so they cannot be used in circuits that require DC (direct current) electricity. Additionally, inductors can only store a limited amount of energy, so they may not be suitable for high-powered devices or appliances.
  • Classical Physics
