Integrals as the area under a curve
In summary: The area of a circle of radius r.In summary, the conversation discusses the concept of integrals in different coordinate systems and the confusion surrounding the fact that a single integral in polar coordinates does not yield the area of a circle. The reason for this is that the integral does not take into account the underlying geometry and must be adjusted to get the correct result. The integral from 0 to 2π of rdθ will give the length of the circumference of a circle, not the area. However, by considering the geometry and adjusting the integral, the correct result can be obtained.
aaaa202
1,169
I have always seen the integral as the area under a curve. So for instance, if you integrated over the upper arc of a circle you would get ½[itex]\pi[/itex]R2.
But then, I learned to do integrals in spherical coordinates and something confuses me. If you do the integral from 0 to 2[itex]\pi[/itex], you don't get the area of a circle - you get the length of the circumference. Why is that? Certainly you are integrating over the arc of a circle? I can see, that you would need to integrate from 0 to R to actually get the formula for the area of a circle, but then you do a double integral, whereas in cartesian coordinates you would only integrate over y = ±√(R2-x2). Isn't there some sort of mismatch here?
Edit: Yes, indeed when thinking of it, I am surprised that you do surface integrals as double integrals, when a single integral already yields and area?
If you do the integral from 0 to [itex]2\pi[/itex]
The integral of what?
Well just ∫rdθ from 0:2[itex]\pi[/itex]
The reason you don't get an area can be shown on dimensional grounds. When you integrate [itex]\int y(x) \; dx[/itex], you get an area because [itex]y,x[/itex] both have the same dimensions (usually length).
When you integrate [itex]\int r \; d\theta[/itex], you don't get an area because while [itex]r[/itex] has dimensions of length, [itex]\theta[/itex] does not. The problem is that when you write an integral, it doesn't know what the underlying geometry is. For all it knows, [itex]r,\theta[/itex] belong to a rectangular coordinate system. To get the right result, you have to consider the geometry in question and put in something physically sensible.
Alternatively, you could say that integerals really don't spit out areas unless they're double integrals, and really what you've done when you integrate is
[itex]\int_a^b \int_0^{y(x)} 1 \; dy \; dx[/itex]
Setting up the polar coordinates integral the same way should get the correct result without having to stop and think about it in a fuzzy way.
Certainly integrals can be used to find "area under a curve" but that is only an application- it is not what the integral is. You are very much over simplifying to think of the integral as being automatically "area".
As far as [itex]\int_0^{2\pi} r d\theta[/itex] is concerned, it is, of course, [itex]2\pi r[/itex], the circumference of the circle. That's because, if we were to divide the entire circle, of radius r, into very thin sectors, with base angle [itex]d\theta[/itex], the lenth of the arc would be [itex]r d\theta[/itex]. I don't understand why you would think it would be the area.
If you divide a circle, of radius r, into very thin sectors, with base angle [itex]d\theta[/itex], we can approximate each sector by as triangle with base [itex]rd\theta[/itex] , as before, and height r. Such a triangle has area "1/2 base times height" or [itex](1/2)(r d\theta)(r)= (1/2)r^2 d\theta[/itex]. We can approximate the area of the entire circle by [itex]\sum (1/2)r^2 d\theta= (1/2)r^2 \sum(d\theta)[/itex] since "1/2" and "r" are constants. Of course, [itex]\sum d\theta= 2\pi[/itex] so the are is [itex](1/2)r^2(2\pi)= \pi r^2[/itex].
Related to Integrals as the area under a curve
1. What is the concept of integrals as the area under a curve?
The concept of integrals as the area under a curve is a fundamental concept in calculus. It refers to the calculation of the area between a curve and the x-axis on a graph. This is done by dividing the area into smaller sections and using the formula for the area of a rectangle to approximate the total area. As the number of sections increases, the approximation becomes more accurate, approaching the actual area under the curve.
2. How are integrals used in real-world applications?
Integrals are used in various real-world applications, particularly in fields such as physics, engineering, and economics. For example, they can be used to calculate the distance traveled by an object with varying velocity, the amount of work done by a force, or the total cost of production for a company.
3. What is the difference between definite and indefinite integrals?
A definite integral has specific limits of integration, meaning that the area under the curve is being calculated within a specific range. On the other hand, an indefinite integral does not have limits of integration and represents the general antiderivative of a function. In other words, a definite integral gives a numerical value, while an indefinite integral gives a function that can be used to calculate the definite integral at any point within its range.
4. What are some common methods for evaluating integrals?
Some common methods for evaluating integrals include the use of integration by substitution, integration by parts, and partial fraction decomposition. These methods involve manipulating the integrand (the function being integrated) into a form that is easier to integrate using basic integration rules.
5. What is the relationship between derivatives and integrals?
The relationship between derivatives and integrals is known as the fundamental theorem of calculus. It states that the derivative of an integral is equal to the original function, and the integral of a derivative is equal to the original function plus a constant. This relationship allows us to use derivatives to find integrals and vice versa, making it a powerful tool in solving various mathematical problems.
