Internal Forces and External Forces
In summary, the conversation discusses the concept of work and energy in the context of a car accelerating along a path without air resistance. It is noted that when the car is modeled as a particle, the work done by the engine is not included in the equation, but rather the external nonconservative forces such as friction and air resistance. The confusion arises when switching between different levels of detail, leading to discussions about the source of the car's kinetic energy and the role of friction in this process. It is concluded that while friction does not technically do work, it is still considered an external force and can affect the car's kinetic energy.
PFuser1232
479
Consider a scenario where a car accelerates along a path, with no air resistance. If we model the car as a particle, we have the following equation:
##ΣW_{ext} = ΔK + ΔU##
By question is with regard to the LHS of the equation. It i my understanding that since the engine is a part of the system, "work done by the engine" is not supposed to be a part of the equation. What then causes an increase in the total energy of the system, the system being the car?
When I thought about it, there are really two external nonconservative opposing forces acting on the car: friction and air resistance. Is frictoon the "driving force", for the lack of a better term? And when we talk about "work done by the engine", is it really "work done by friction"?
MohammedRady97 said:
If we model the car as a particle ..."work done by the engine"
If you model the car as a particle, then there is no engine or work done by the engine in your model. Switching between different models (levels of detail) always leads to this kind of confusion about work done.
How do we go about analyzing work and energy if we model the car as a particle?
Well this is a good question, as it relates to modeling the car as a car and not a particle.. When accelerating, the air resistance and rolling resistance forces oppose the direction of motion, but it is the static friction force between the driving wheels and the ground that is the driving or traction force that acts in the direction of the acceleration, that is, opposite to the drag and rolling resistance forces. Funny thing is, however, that the friction force, being static, does not do any work. It's called 'pseudo' work, since it is really the engine that delivers the power to turn the wheels and do the work. Using the external work as work done by friction works fine here, even though it really doesn't do work in a real sense of the term. No friction means no acceleration, so it must exist in order for the car to translationally accelerate, regardless of the power delivered by the engine.
Likes PFuser1232
PhanthomJay is exactly right. You can calculate the "work" (pseudowork) done by friction like so:
$$F_{net}\Delta x_{cm}=\Delta (\frac{1}{2}m v_{cm}^2)$$
But don't be fooled into thinking that the friction is a source of energy. The above equation is a consequence of Newton's 2nd law, not conservation of energy.
Likes PFuser1232
So while friction does not really "do work", we talk about work done by friction as it is an external force in this example, right? Pseudowork, that is.
Yes. While static friction does no real work (in the thermodynamic sense) it is common to talk about the "work done by friction".
Thanks!
I'm curious to know more about A.T.'s statement though. When we switch to a different level of detail, how does our analysis of forces, work and energy change?
What is the actual source of the car's kinetic energy? (At least to the next level of detail.)
Chemical reactions in the internal combustion engine.
Exactly.
Total energy of car does not increase in such process. Only its kinetic energy increases at the expense of energy evolved in the chemical reactions. Friction does no work in ordinary circumstances where the wheels roll without slipping.
From the standpoint of mechanics, the positive work done on the car is done by internal forces. Internal forces can change system's kinetic energy. Net momentum cannot be changed by internal forces, but kinetic energy can.
There are no wheels in your FBD, if you model the whole car as a particle, or one translating block. If you want to have static friction in your model, then you have to model the wheels as separate bodies, otherwise this friction model is inconsistent with the FBD diagram.
Modelling a car as a particle is not a good idea if internal forces and their work is to be understood.
Maybe, but if you decide to do so, then you have to stick to it throughout your analysis. If you then find that such coarse model doesn't provide much insight, then you introduce more level of detail.
Right.
Related to Internal Forces and External Forces
1. What are internal forces?
Internal forces are forces that act within a structure or system. These forces include tension, compression, and shear, and they help to keep the structure stable and balanced.
2. What are external forces?
External forces are forces that act on a structure or system from outside of it. These forces can include gravity, wind, and applied loads, and they can cause changes in the shape and movement of the structure.
3. How do internal and external forces interact?
Internal and external forces interact by balancing each other out. Internal forces work to keep the structure stable, while external forces try to disrupt that stability. When these forces are in equilibrium, the structure remains in a state of rest or constant motion.
4. What is the importance of understanding internal and external forces?
Understanding internal and external forces is crucial in the design and analysis of structures. It allows engineers to determine the strength and stability of a structure and make necessary modifications to ensure its safety and functionality.
5. How can we calculate and measure internal and external forces?
Internal and external forces can be calculated and measured using mathematical equations and physical measurements. Engineers may also use computer simulations and models to analyze the forces acting on a structure and predict its behavior under different conditions.
  • Other Physics Topics
  • Classical Physics
