Is it possible to fuse more than two atoms at once?
In summary: Helium-2 which consists of two fused protons is a very unstable isotype of helium with a short half life, but it has probably been observed on multiple occasions and has also been inferred from the chemical makeup of stars, which would be different if this possibility were not considered.
Anastasiagrace
I'm writing a paper for my teacher, not an assignment, just because I was interested in the topic. I've searched a lot of websites, but most only talk about fusing two atoms, and not saying if it is possible to fuse more than two at the same time.
Can you be more specific? The sun certainly fuses many atoms at the same time. Mankind had only fused atoms in H-bombs so far. (Maybe a few single ones in labs). There are surely many atoms fusing at the same time during the detonation.
Yes it is
Likes ohwilleke
I think the OP means can it possible for three or more atoms to fuse into something instead of just two.
I think that is possible but very unlikely, because the circumstances for just two atoms fusing have to be exactly right.
For the circumstances to be right so that three atoms fuse is possible I think, but is a very low probability and almost certainly not a situation which could be easily engineered.
Fusing 3 atoms is very common and vital, for some definition of "at the same time". Triple alpha. For some definition of "at the same time", because the half-life of Be-8 is in the region of 10-16 s, not in the strong interaction timescale of 10-22 s.
Likes mfb
To extend the explanation: As snorkack noted, the timescale of fusion processes is incredibly short, like 10-22 seconds. And nuclei are extremely small, of the order of 10-15 meters. The probability that three nuclei come together at the same place and the same time (within those scales) is negligible. It would require conditions that lead to rapid (2-nuclei) fusion or even disintegration of the nuclei long before three-nuclei fusion would become relevant.
The triple alpha process has relaxed conditions as the intermediate Be-8 has some reasonable lifetime, but it still needs very high temperatures and densities to occur.
Astronuc said:
The triple alpha process requires pressures or densities that we cannot achieve in manmade systems.
Two protons have never been observed to fuse either.
Helium-2 which consists of two fused protons is a very unstable isotype of helium with a short half life, but it has probably been observed on multiple occasions and has also been inferred from the chemical makeup of stars, which would be different if this possibility were not considered. While it is observed in the decays of heavier atoms, the fusion of two protons is an intermediate step in its formation.
https://en.wikipedia.org/wiki/Isotopes_of_helium#Helium-2_.28diproton.29
Related to Is it possible to fuse more than two atoms at once?
1. Can more than two atoms be fused together at once?
Yes, it is possible to fuse more than two atoms at once. This process is known as multi-nucleon transfer or multi-nucleon fusion, where several nuclei collide and fuse together to form a heavier nucleus.
2. How does multi-nucleon fusion occur?
Multi-nucleon fusion occurs through a series of nuclear reactions, where the nuclei collide with enough energy to overcome the repulsive force between them and fuse together, releasing a large amount of energy in the process.
3. What are the potential applications of multi-nucleon fusion?
Multi-nucleon fusion can potentially be used as a source of energy, as it releases a large amount of energy in the form of heat and light. It can also be used in nuclear weapons, as well as in research to study the structure and properties of nuclei.
4. Is multi-nucleon fusion a sustainable source of energy?
Currently, multi-nucleon fusion is not a viable source of energy as it requires a large amount of energy to initiate the fusion reaction. However, scientists are working on developing controlled fusion reactions that can potentially be a sustainable source of energy in the future.
5. Are there any risks associated with multi-nucleon fusion?
The main risk associated with multi-nucleon fusion is the release of harmful radiation. Additionally, the technology for controlled fusion reactions is still being developed, so there may be potential safety concerns that need to be addressed before it can be used on a larger scale.
  • Quantum Physics
  • Thermodynamics
