Is spacetime emergent - and in which theories?
In summary, some physicists, like Nima, Ed. Witten, Gross, and others have said/suggested that space-time is doomed, or emergent from something more fundamental. What ideas would replace space-time? Something similar to a perfect material? A fluid? Geometry? Quantum field theory of some sort? Entanglement?
  • #36
As I understand it, holography and entanglement entropy suggest that classical spacetime can emerge from something more fundamental, say "spacetime atoms". In that sense classical spacetime emerges from quantum entanglement of these "atoms", like e.g. a continuous fluid description emerges from water molecules.
We don't know the details yet of these spacetime "atoms", just like Maxwell, Boltzmann and others didn't know the precise details and quantum mechanics of atoms.
  • #37
So for an idea in terms of spacetime atoms, what would you expect spacetime to be? Some analogy of a block or crystal of condensed matter?
  • #38
I emailed two researchers in this field and here are the responses:
There has been a lot of discussion of this, but I don’t know a good place where it is reviewed in print. One reason is that due to quantum effects, we don’t expect spacetime geometry to make sense at very short distances. But there are others as well."
and
If there is a quantum theory of gravity, then it describes a quantum spacetime which has the same relation to classical spacetime that the quantum states of an electron have to the classical particle trajectories. We use methods like coherent states or the WKB approximation to show how the classical particle trajectories emerge from the dynamics of quantum states. This is one sense in which we expect classical spacetime to be not fundamental, but to be emergent from a quantum state or quantum path integral description."
Maybe this will help people on their quest to understanding.
  • #39
S Beck said:
Some physicists, like Nima, Ed. Witten, Gross, and others have said/suggested that space-time is doomed, or emergent from something more fundamental. What ideas would replace space-time? Something similar to a perfect material? A fluid? Geometry? Quantum field theory of some sort? Entanglement?
Is there any evidence that space-time is emergent or is this some idea in the air? String theory and I believe LQG point to the idea of emergent space-time.
Where did you find it? I've never read about it.
  • #40
I don't know, but that wouldn't be a huge surprise; high energy physics has more ties to condensed matter physics; think e.g. Higgs mechanism.
  • #41
The essence of the emergent spacetime program of people like Carrol, Verlinde, Raamsdonk, Giddings et cetera is the Ryu-Takayanagi relation. I will focus on the Raamsdonk type of emergence because I am most familiar with it, although I can't promise I didn't get anything wrong (especially regarding how nongeometric a CFT is)...
A conformal field theory (CFT) is not a priori geometric, formally it is all operators and commutators and a spectrum of possible states. A conformal field theory (and indeed, any QFT) has a vacuum state with a very peculiar entanglement structure that prevents factorization of the Hilbert space into (spacetime) local factors. Despite this, we may classify a subset of operators on this space in terms of local regions by demanding that it respects the notion of causality carried by a Lorentzian spacetime. There is a natural definition of entropy in this framework, and since this definition makes reference to a pure vacuum state this entropy is purely due to entanglement. The main point I am trying to make here is that while we use spacetime causality as a guide for constructing the "algrebra of observables" of the quantum theory, the geometry is not explicitly a part of the operators in Hilbert space side of it all.
Raamsdonk et al in for example 1308.3716 and 1705.03026 show that: (I'd like to note that I found the latter paper really difficult, while the first is actually a really approachable, explicit proof by induction for the first order resutl)
There is a unique geometry that correctly computes the entanglement entropy of the boundary CFT to second order via the Ryu-Takayanagi relation, and this geometry satisfies the Einstein Field Equations to second order. (By unique I mean unique in the sense that the equations that determine the geometry are uniquely the Einstein field equations)
The CFT side of their computations has no a priori geometry (especially not a dynamical geometry) but it turns out that the dynamics of entanglement in the CFT are equivalent to graviational dynamics. If we see the entanglement as "more fundamental", we can see the gravitational as "emerging from the more fundamental theory". It is also important to stress that for the second order result, they need to consider a very specific class of CFT states, there are lots of CFT states whose entanglement structure can not be interpreted as describing any classical geometry. In this sense gravity emerges as a particular subspace of possible states in a larger, a priori nongeometric theory.
If you think that CFT/QFT comes equipped with too much "a priori geometry" you may appreciate the speculative part of 1809.01197 . I should also note that there are lots of reasons for why just entanglement is not enough to fully reconstruct spacetime geometry, most notably the interior of black holes. For example, the extremal surfaces used for Ryu-Takayanagi can not pass event horizons, and the eternal AdS wormhole grows in length without this being reflected in any entanglement quantity. For more on this see for example 1411.0690 and maybe the original ER=EPR paper 1306.0533.
Edit: made hyperlinks
Likes eloheim, *now* and atyy
  • #42
Archmonduu said:
(I hope linking to Arxiv numbers works well)
Can you make them actual hyperlinks?
  • #43
Haelfix said:
You are right, from that perspective it is not. But that's when I've given you the full CFT.
The 'emergent' point of view arises if you hand me a holographic CFT, and then I put it on my quantum computer to simulate. During time evolution, we literally see spacetime emerging from what would otherwise look like a mess of degrees of freedom that look nothing like gravitational physics. Moreover, you might imagine that under such a time evolution the duality would lead to something like normal ADM/Hamiltonian evolution on the gravity side, but it is known that this does not take place. Instead the reconstruction occurs far more nonlocally.
I tend to think along this lines, spacetime seems to be a phase space of all (or a subset of) degrees of freedom in a system.
  • #44
MathematicalPhysicist said:
That there's something more fundamental than space-time.
I don't see it either.
Without reference to any proposed theory I can think of a couple of ways that space-time can be emergent:
1) starting with a single point (e.g. big bang) and bud new points off it and others as they form. (These new points are connected to their parents and other closely related points. Imagine lines draw these points together to create a network.) These points are where particles can be positioned. As you gain more and more points space is expanding but the topology of how those points connect will determine the shape of space-time. The simplest version is a single point breaks into two and remains connected to those points either side and to each other and as this continues creates a growing circle (1d line) more complex network topologies such as lattices and diamond like tetrahedral connections give 3d bulk space, etc. Those points don't have to have a real position in anything and just gets one from the relationship to its neighbours only.
2) the other way which is less realistic is if space and time do not exist at all but every particle or wave packet has "coordinates" (maybe just as distances from all other particles) the laws of physics could then be enough to give the impression that a type of space-time exists and that would emergent from the particle interactions and the laws.
These are obviously toy models but should give you an idea of how emergence could work.
Paul Cooper
  • #45
Paul Cooper
As for your 1) I don't see how all of the richness of the universe can pop out of a point.
A point cannot contain in it spheres,planets, humans etc. which are comprised of infinite number of points.
So you actually say that from one point we can have infinite number of points?
How exactly?
I never quite understood the big bang theory, maybe next year I'll take a course in cosmology and the lecturer will explain it (I am not sure it will be explained there).
Or do you mean mathematically we can look at a graph instead of a Lorentzian manifold?
I wasn't referring to the mathematical structure, but to the notion of spatial distances and temporal intervals that is in the experimental way of doing physics which is basically fundamental.
Instead of some structure with properties from analysis we take some structure from combinatorics, namely a graph; but then how do you do analysis on graphs?
I read a few weeks ago a paper about PDEs and graph theory and the interconnections between them (more skimmed over it) perhaps it could work.
But the question is will it solve problems that the analysis construct didn't?
Here's the paper I looked at:
https://arxiv.org/pdf/1505.00185.pdf
  • #46
My published research with Suresh G. Advani in Physics of Fluids on the Saffman-Taylor Instability (on the radial domain) suggests to me that this low-energy quantum process is one of self-ordering (self-ordered criticality). I saw that someone above spoke of a source as being a single location or point. In my relational philosophy as an offshoot of expanding-universe/fluid-droplet thought, nothing can exist without relationship, meaning a change in the universe of between at least two locations or magnitudes. Both what we sample as space and what we sample as time are CHANGES and therefore, to us, exist explicitly. Are they, as David Bohm suggests, implicit to our universe? More soon.
  • #47
LQG basically says that space-time consists of points and connections between points (often three per point). The number of space-time dimensions in emergent from the network of connections between points, and so is locality, which is imperfect since points could have a connection to another point which doesn't have a lot of other connections in common with it, creating a Planck scale non-locality. Smoothness in LQG is just an illusion in what is fundamentally a discrete structure of space-time that is so fine grained that it cannot be experimentally distinguished from a smooth space-time. In LQG and kindred theories the points and connections, or the equivalent, are axiomatic, but not the topological features of space-time.
To understand how dimensionality could be emergent, try using the definition of a fractal dimension or a generalization of that. In LQG, very simple small scale systems could be functionally two dimensional, for example, even though they become four dimensional as the network of connections self-organized (in something a bit like a spontaneous symmetry violation).
LQG also has an elaboration in which matter is basically just a tightly bundled cluster of connected points.
While this is hard to observe, this means that none of the usual axioms relied upon for real analysis or complex analysis in almost every circumstance that intuitively seem like they must be true (like smoothness and continuity) hold, which kicks you out of glorified calculus and into the world of discrete mathematics.
I'm oversimplifying, but that is the basic idea in a nutshell.
An emergent space-time makes a lot less sense in many versions of string theory because those theories often include the number of space-time dimensions as an axiom of the theory, and because some versions of it have both a 10 or 11 dimensional space-time (which phenomenologically explains why gravity is so weak) and a 4 or 5 dimensional brane to which interactions except gravity are confined, with the branes also being axiomatic.
  • #48
What I highlighted is true of so many fields in science and technology, if you decided on being an academic scholar and being good at that you are bound to read quite a lot of papers and books.
So true. I grok what you're saying. But I came by my interests and activities naturally by experimenting (really all my life). I was able to publish my research on the self-organization of a low-energy quantum physical behavior, that shows that our universe of normal space and time behaves like an unstable (Saffman-Taylor Instability) expanding boundary (about 100 years of reference materials (actual experiments)) to go through helped out a lot).
  • #49
How exactly?
I thought it was obvious that 1) was referring to a universe where space-time is granular. If it is not then that type of model isn't applicable for that exact reason. But given that the granularity, if it exists, would likely be on the Planck scale so the theories we have which we describe with differentiable manifolds could just be approximations in the same way gas laws are statistical approximations of the behaviour of particles in a gas.
These models are not meant to be taken with any seriousness there is no mathematics or theory behind them, more just didactic examples of the concept of emergence in regards to space-time. This subject is an active area of research so there is no "answer" yet.
That should be interesting but if my Gravitation and Cosmology module I did (~25years ago) is anything to go by it will be heavy on the Maths. I also doubt it will cover the emergent spacetime topic.
Unfortunately there is no reason to believe spatial distances and temporal intervals are fundamental.
Looks interesting I will dive into that later.
This essay I found might be of interest to you: http://guava.physics.uiuc.edu/~nigel/courses/569/Essays_Spring2018/Files/gupta.pdf
  • Beyond the Standard Models
