Is the gravitational constant actually a variable?
In summary, the conversation discusses the possibility that the unexplained phenomena of dark matter and dark energy could be explained by G, the gravitational constant, being a variable dependent on a scalar field that is itself dependent on the amount of matter surrounding a certain point. However, this theory has been largely disproven by experiments, as the variations in the scalar field would be too small to explain the observed phenomena.
Luis Ochoa
Hi, as an engineer i don't have much formal training in theoretical physics so bare with me.
As most of you know, we can only understand 4% of our universe with the current models we have. The rest of the 96% is dark matter and dark energy (23% and 73%, respectively). Could these unexplained phenomena be a consequence of G, gravitational constant, not being a constant at all, but a variable dependent on a scalar field that it itself is dependent on the amount of matter surrounding a certain point?
As mentioned, this variable would increase if there is a large matter density surrounding it, thus in the context of a galaxy it would explain dark matter. And become negative in the space between galaxies where the matter density surrounding it is extremely low, thusly explaining dark energy.
I know the math behind this might be very simplistic and that in theory dark energy actually expands space itself, but i would very much appreciate it if someone with deeper knowledge on this issue gave it a thought!
Thanks before hand to all of you!
There is a theory of gravity in which G is a scalar field variable: it's called Brans-Dicke theory. This theory has not been ruled out, but experiments have shown that, if it is true, the variation of the scalar field in space and time must be extremely small--much too small for effective variation in G to explain the phenomena we associate with dark matter and dark energy.
Related to Is the gravitational constant actually a variable?
1. What is the gravitational constant?
The gravitational constant, denoted by G, is a fundamental physical constant that quantifies the strength of the gravitational force between two objects with mass. It plays a crucial role in Newton's law of universal gravitation and in Einstein's theory of general relativity.
2. Is the gravitational constant really a constant?
Yes, the gravitational constant is considered a constant in classical physics and is used in many calculations involving gravity. However, in some theories, such as string theory, the gravitational constant is believed to vary in different dimensions or at different energy scales.
3. How is the gravitational constant measured?
The gravitational constant is usually measured by performing experiments that involve measuring the gravitational force between two masses. One of the most famous experiments is the Cavendish experiment, which was conducted by Henry Cavendish in 1798 using a torsion balance.
4. Why do some scientists believe that the gravitational constant is a variable?
Some theories, such as string theory, propose that the gravitational constant may be a variable due to its connection with other fundamental constants and the idea of a unified theory of physics. However, there is currently no experimental evidence to support this idea.
5. How would a varying gravitational constant affect our understanding of gravity?
If the gravitational constant were to be proven as a variable, it would drastically change our understanding of gravity and the laws that govern it. It would require a fundamental shift in our current understanding of the universe and could potentially lead to new theories and discoveries.
  • Astronomy and Astrophysics
  • Cosmology
