- #36
Jaime Rudas
- 120
- 44
Of course, we do consider the possibility that the universe is infinite and approximately flat.davLev said:Therefore, why don’t we consider a possibility for a flat infinite universe?
We do! I have already said this in this thread, both before and after you joined it!davLev said:Therefore, why don’t we consider a possibility for a flat infinite universe?
We don't! What part of "minimum radius of curvature consistent with observation" do you not understand?davLev said:As Many independent observations indicate that the universe is in fact flat (and infinite), why do we try to limit its size to 205 Gly or even 20 trillion ly?
You must take into account that the probability of the universe being perfectly flat is practically zero.davLev said:As Many independent observations indicate that the universe is in fact flat (and infinite), why do we try to limit its size to 205 Gly or even 20 trillion ly?
Actually, if you treat the radius of curvature as a continuous parameter on which you have a probability distribution then the probability of any exact value is exactly zero, including the flat case. That's part of the problem here - our measurements exclude small radii, both positive and negative, but do not rule out a really large positive curvature universe, a really large negative curvature universe, or an infinite radius of curvature (i.e., a flat space), and if the universe is actually flat this will always be the case. All we will ever be able to do - at least within the bounds of relativity - is put ever larger lower bounds on exactly how vast the universe is. Only if it is actually non-flat (one way or the other) would we be able to rule out the other two cases.Jaime Rudas said:You must take into account that the probability of the universe being perfectly flat is practically zero.
A flat infinite universe does not imply an infinite age in and of itself, no.davLev said:As there is a possibility for a flat infinite universe, does it mean that the universe age is also infinite?
If it's flat, then it's flat; and probability theory doesn't come into the equation.Jaime Rudas said:You must take into account that the probability of the universe being perfectly flat is practically zero.
"Flat" means the spatial curvature of the universe is exactly zero. But we can never observe any continuous physical parameter to be exactly some value. There are always error bars in our measurements. The OP of this thread was basically asking how wide the error bars are.davLev said:In the article it is stated:
“Many independent observations indicate that the universe is in fact flat”
So why do we refuse to accept the fact that the universe is just flat?
Why do we insist to push the idea of nearly flat & curvature to our flat universe?
Is it just because there is no valid theory for that infinite flat universe?
The key word is indicate. This means suggest rather than prove.davLev said:In the article it is stated:
No one refuses to accept it. It's simply unproven.davLev said:So why do we refuse to accept the fact that the universe is just flat?
Because all experiments have a margin of error. The experiments so far can only show flatness to within the relevant experimental error.davLev said:Why do we insist to push the idea of nearly flat & curvature to our flat universe?
Precise flatness may be a theoretical issue, but that's not the main issue, which is allowing for experimental error.davLev said:Is it just because there is no valid theory for that infinite flat universe?
No. Our current theory covers the possibility of a flat universe just fine.davLev said:Is it just because there is no valid theory for that infinite flat universe?
For the universe to be perfectly flat, it would need to be perfectly homogeneous, and it is not.PeroK said:If it's flat, then it's flat; and probability theory doesn't come into the equation.
All of the observations described in this thread are of the average spatial curvature of the universe. Obviously its spatial curvature cannot be the same everywhere since the matter and energy in it is clumped.Jaime Rudas said:For the universe to be perfectly flat, it would need to be perfectly homogeneous
I suspect Siegel is over-reaching here, as well as what has been said above. I think the correct statement is that many independent observations are consistent with flatness and none are significantly inconsistent with it, but all are also consistent with a very large radius of curvature.davLev said:“Many independent observations indicate that the universe is in fact flat”
I agree. That's why I mentioned that the probability of the universe being perfectly flat is practically zero.PeterDonis said:All of the observations described in this thread are of the average spatial curvature of the universe.
We are not talking about the probability of the entire universe being perfectly spatially flat. We are talking about the probability of the average curvature of the universe being zero, i.e., flat. That's not the same thing.Jaime Rudas said:That's why I mentioned that the probability of the universe being perfectly flat is practically zero.
A model of a flat universe works just fine with current theory (general relativity is the underlying theory).davLev said:Why do we insist to push the idea of nearly flat & curvature to our flat universe?
Your questions have already been answered. Since you apparently have nothing further of substance to contribute, you have now been banned from further posting in this thread.davLev said:You confirm that there is a possibility for the universe to be infinite flat.
You also confirm that the current theory can cover this infinite flat universe.
Do we have any real observation that clearly proves that the universe has a curvature?
As we consider a possibility for positive and negative curvature, why can’t we also consider one more possibility for the universe to be an infinite flat without any curvature?
There's either an echo or a closed timelike curve in here...davLev said:why can’t we also consider one more possibility for the universe to be an infinite flat without any curvature?
