Japan Earthquake: nuclear plants - Daini (Plant 2)
In summary: The other way around. They lost 9 out of 12 generators (all at units 1 and 2), but survived due to one remaining off-site connection. The status of the EDG:s was revealed in a mid-May press conference, two months after the first inquiries were sent to NISA from foreign safety authorities. (Until May, they kept "confirming" the status of the EDGs.)
clancy688
546
There is a PCV inside / equipment inside PCV visual inspection schedule for Fukushima Daini on http://www.tepco.co.jp/nu/fukushima-np/images/handouts_120208_06-j.pdf page 27 (28/35). The visual inspection of unit 4 was performed from August to December, that of unit 1 is scheduled from December to March, and those of units 2 and 3 are not yet scheduled.
On page 15 (16/35) they say that they found nothing abnormal in units 1 and 4 during the visual inspections inside PCVs. On the same page, they say that as the temperature design value was exceeded in the suppression chambers, they need to assess the consequences (the nuclear safety commission of Japan requested it). Generally speaking, they have to check each design condition for each equipment, check if they were respected, and, if needed, assess the consequences.
On page 16 (17/35) they say they made an earthquake analysis finding that the largest strain for a reactor building was 0.11 E-3 at unit 3's 4th floor, in the south-east direction, which is smaller than the 2.0 E-3 assessment standard.
clancy688 said:
http://www.yomiuri.co.jp/dy/national/T120209007089.htm "Fukushima No. 2 plant was 'near meltdown'"
"we" already knew this; cold shutdown was reached something like a week in, iirc.
The point is that Fukushima Daini (Plant 2) was nearly in the same situation as Fukushima Daiichi (Plant 1). Had they lost power, then six units (three at FK2 and three at FK1) might have suffered catastrophic core damage rather than the three (Units 1, 2 and 3) at Fukushima Daiichi.
I think they lost off-site power too, but had working generators. Right?
From the OP - Yomiuri citation:
On March 11, a 9-meter-high tsunami struck the No. 2 plant, while the No. 1 plant was hit by a 13-meter-high tsunami. The tsunami caused the No. 2 plant's seawater pumps, used to cool reactors, to fail. Of the plant's four reactors, three were in danger of meltdown.
Luckily, one external high-voltage power line still functioned, allowing plant staff in the central control room to monitor data on internal reactor temperatures and water levels.
However, despite intense efforts by all employees, it took a long time to stabilize the reactors.
On March 11, about 2,000 employees of the No. 2 plant worked to stabilize the reactors. Some employees connected 200-meter sections of cable, each weighing more than a ton, over a distance of nine kilometers.
Masuda noted the timing of the disaster was critical in saving the plant.
No nuclear plant should be so vulnerable! Had the earthquake/tsunami been 12 or 24 hrs later . . . .
Related to Japan Earthquake: nuclear plants - Daini (Plant 2)
1. What caused the nuclear plants in Japan to be affected by the earthquake?
The nuclear plants in Japan were affected by the earthquake because they were built in an area that is prone to seismic activity. The earthquake caused a power outage and damaged the cooling system, which led to a partial meltdown of the reactors.
2. Is the radiation from the nuclear plants in Japan dangerous to humans?
The level of radiation near the nuclear plants in Japan is higher than normal, but it is not at a dangerous level for humans. The Japanese government has implemented evacuation and safety measures to protect the public from any potential harm.
3. How are the workers at the nuclear plants in Japan being protected from the radiation?
The workers at the nuclear plants in Japan are wearing protective gear and following strict safety protocols to minimize their exposure to radiation. They are also being regularly monitored for any signs of radiation exposure.
4. What is being done to contain the radiation from the nuclear plants in Japan?
The Japanese government and the plant operators are working to contain the radiation from the nuclear plants by using measures such as seawater injections and nitrogen injections to cool and stabilize the reactors. They are also working to repair the damaged cooling system.
5. Are there any long-term effects of the nuclear plants in Japan being affected by the earthquake?
The long-term effects of the nuclear plants in Japan being affected by the earthquake are still unknown. The Japanese government and international organizations are conducting extensive studies to assess the impact and to develop strategies for future disasters. The health and safety of the public remains a top priority in these efforts.
  • Nuclear Engineering
51
419K
14K
4M
17K
  • Earth Sciences
259K
19K
