Just need to clarify something (FRICTION)
  • Thread starter asteg123
  • Tags
    Friction
In summary, the coefficients of static and kinetic frictions, along with the weight of the package, can be used to calculate the maximum static friction and the force needed to start the package's motion. To slide the package at a constant velocity, a force equal to the kinetic friction is required.
asteg123
QUESTION: If a 60kg package rests on a level floor with coefficients of static and kinetic frictions 0.56 and 0.37 respectively, what horizontal force is required to start the package's motion? how much force is needed to slide the package across the floor at constant velocity?
using the formulas f(static*max*)=mu * N
where mu(static) = 0.56 and N=m*g = 60*9.8 = 588N
so the maximum static friction would be 329.28N... so the force needed to start the package's motion would be any value GREATER than 329.28N
and that means that the kinetic friction is
f(kinetic) = mu * N
where mu(kinetic) = 0.37
so f(kinetic) = 217.56N
and it takes 217.56N of force to slide the package across the floor at constant velocity..
__________________________________
I was just wondering if what i did was correct... and if the force needed to move an object at a constant velocity less than the force needed to move it from rest...
THX>>>>
Your answers look good to me :smile: and welcome to PF.
They are? CooL... heheheh
Thanks for the welcome... ^^
Related to Just need to clarify something (FRICTION)
What is friction?
Friction is the force that resists the motion of two surfaces in contact with each other.
What are the different types of friction?
There are four main types of friction: static, kinetic, rolling, and fluid. Static friction occurs when two objects are not moving relative to each other, kinetic friction occurs when two objects are moving against each other, rolling friction occurs between a rolling object and the surface it is rolling on, and fluid friction occurs when an object moves through a fluid, such as air or water.
What factors affect friction?
The amount of friction between two surfaces is affected by the types of surfaces, the force pressing the surfaces together, and the roughness of the surfaces.
How is friction measured?
Friction is typically measured using a unit called the coefficient of friction, which is the ratio of the force needed to overcome friction to the force pressing the surfaces together.
How is friction useful?
Friction has many practical applications, such as allowing us to walk without slipping, making tires grip the road, and allowing us to write with a pen or pencil. It also helps to slow down moving objects, making them easier to control and stop.
