Knoll (knob/bump) on the plate of the capacitor
In summary, the problem involves finding the electric field at the top and base of a small hemispherical knoll on the inner surface of a flat charged capacitor using the principle of superposition. The dipole momentum of the sphere is represented by a plate with a hole or a plate with a hemisphere lying on top. The dipole field at the top is twice the original electric field, while the dipole field at the base is equal to zero.
sergiokapone
302
The inner surface of one of the plates
flat charged capacitor has a small hemispherical knoll.
Away from it the electric field in the capacitor is equal to ## E_0 ##. Using the principle of superposition find the field at the top and at the base of the knoll.
Field near metall surface ##E = \frac{\sigma}{\epsilon_0}## (SI units)
The idea is to represent plate with knoll as two different things. May be as a plate with hole with the inserted in it sphere, or as a plate with hemisphere lying thereon. Need some help.
Is this your problem?
need picture.
if the knoll protrudes from the plate then the bottom is part of the metalization and the E field there = 0.
I found solution. Let's start with the model:
Dipole momentum of the sphere
\begin{equation}
p = \frac{3}{4\pi}VE_0 = r^3 E_0\label{p}.
\end{equation}
Field of the dipole in general
\begin{equation}
\vec E = \frac{3(\vec p\vec r)}{r^5}\vec r - \frac{\vec p}{r^3}. \label{dipE}
\end{equation}
Field of the dipole at the top
\begin{equation}
\vec E_\text{dip} = \frac{2\vec p}{r^3} = 2\vec E_0. \label{dipEup}
\end{equation}
Due to supperposition principle
\begin{equation}
\vec E = \vec E_0 + \vec E_\text{dip} = 3\vec E_0.
\end{equation}
Field of the dipole at the base
\begin{equation}
\vec E = - \frac{\vec p}{r^3}. \label{dipEbase} = - \vec E_0
\end{equation}
\begin{equation}
\vec E = \vec E_0 + \vec E_\text{dip} = 0.
\end{equation}
Related to Knoll (knob/bump) on the plate of the capacitor
1. What causes a knoll or bump to form on the plate of a capacitor?
There are several possible causes for a knoll or bump to form on the plate of a capacitor. One common cause is a manufacturing defect, such as uneven application of the dielectric material or improper alignment of the plates. Another cause could be the presence of impurities or contaminants on the surface of the plates. In some cases, the knoll or bump may also be the result of physical damage to the capacitor.
2. Can a knoll or bump on the plate of a capacitor affect its performance?
Yes, a knoll or bump on the plate of a capacitor can affect its performance. The irregular shape of the plate can alter the electric field and capacitance of the capacitor, leading to changes in its overall performance. It can also cause issues with the stability and reliability of the capacitor.
3. How can a knoll or bump be detected on the plate of a capacitor?
A knoll or bump on the plate of a capacitor can be detected through visual inspection or by using specialized equipment such as a microscope or a capacitance meter. In some cases, the capacitor may also exhibit abnormal behavior or performance, which can indicate the presence of a knoll or bump on the plate.
4. Can a knoll or bump on the plate of a capacitor be repaired?
In most cases, a knoll or bump on the plate of a capacitor cannot be repaired. If the defect is due to a manufacturing issue, the capacitor may need to be replaced by the manufacturer. If the defect is caused by physical damage or contamination, the affected capacitor may need to be discarded and replaced with a new one.
5. How can knolls or bumps on the plates of capacitors be prevented?
To prevent knolls or bumps from forming on the plates of capacitors, it is important to follow proper manufacturing processes and handle the capacitors with care. This includes ensuring even application of the dielectric material, proper alignment of the plates, and avoiding physical damage or contamination during handling and storage. Regular quality control measures can also help to identify and prevent any potential issues with capacitor plates.
