Laser beam spreader optics problem
In summary: Therefore, the focal length of the second lens is equal to:f_2=\frac{4f_1*s_o_1}{\frac{1}{s_o_1}+\frac{1}{f_1}}In summary,
ice109
1,714
Two positive lens are to be used as a laserbeam expander. An axial 1mm diameter beam enteres a short focal length positive lens, which is followed by a somewhat longer focal length positive lens from which it emerges with a diameter of 8mm. Given that that first lens has a 50mm focal length determine the focal length of the second lens and the separation between them.
[tex]\frac{1}{s_o_1}+\frac{1}{s_i_1}=\frac{1}{f}[/tex]
[tex]M=\frac{-s_i_1}{s_o_1}(\frac{-s_i_2}{s_o_2})[/tex]
well if the object is at infinity, which a collimated beam, a laser, would look like, then it converges to the focus on the other side of the thins lens. But this yields a zero magnification. I can draw a ray diagram after that rays converge to the focus and continue past it they diverge again and if the point they diverge from is the focus of the second lens they will come out collimated again. The problem is that neither of those two equations really describe anything about that. So i can make the ray diagram look right but not the math.
the problem is that there's a bunch of infinities floating around and i don't know how to work with them. in another problem in the book they actually cancled an infinity over an infinity which of course makes no sense to me.
Thank you for your post. It seems like you are struggling with the concept of dealing with infinities in optics calculations. Let me try to explain it in a simpler way.
First, let's define some variables:
s_o_1 = object distance from the first lens
s_i_1 = image distance from the first lens
f_1 = focal length of the first lens
s_o_2 = object distance from the second lens
s_i_2 = image distance from the second lens
f_2 = focal length of the second lens
Now, let's look at the first lens. As you correctly stated, for a collimated beam (object at infinity), the image distance is equal to the focal length:
s_i_1 = f_1
Using this in the first equation, we get:
\frac{1}{s_o_1}+\frac{1}{f_1}=\frac{1}{f_2}
We also know that the magnification of the first lens is given by:
M_1=\frac{-s_i_1}{s_o_1}=\frac{-f_1}{s_o_1}
Now, let's move on to the second lens. We want the beam to emerge from the second lens with a diameter of 8mm. This means that the image distance from the second lens must be equal to half of the diameter, which is 4mm:
s_i_2 = 4mm
Using this in the second equation, we get:
M_2=\frac{-s_i_2}{s_o_2}=\frac{-4mm}{s_o_2}
We also know that the magnification of the entire system (both lenses) is given by:
M=M_1*M_2=\frac{-f_1}{s_o_1}*\frac{-4mm}{s_o_2}=\frac{4f_1}{s_o_1*s_o_2}
Since we want the final magnification to be 1 (meaning the beam emerges with the same diameter as it entered), we can set M=1 and solve for the object distance from the second lens:
1=\frac{4f_1}{s_o_1*s_o_2}
s_o_2=\frac{4f_1*s_o_1}{f_2}
Now, we can substitute this into our first equation and
Thank you for your question. It seems like you are on the right track in understanding the concept of beam expansion using two lenses. However, the equations you have listed are not applicable to this problem. Instead, you can use the thin lens formula, which states that 1/f = 1/s_o + 1/s_i, where f is the focal length, s_o is the object distance, and s_i is the image distance.
In this problem, the first lens has a focal length of 50mm and the second lens has an unknown focal length. The object distance for the first lens is infinity, since the beam is collimated, and the image distance is equal to the focal length of the first lens, which is 50mm. Using the thin lens formula, we can solve for the image distance of the second lens, which will also be the object distance of the second lens. This will give us the separation between the two lenses.
To find the focal length of the second lens, we can use the magnification equation, M = -s_i/s_o, where M is the magnification, s_i is the image distance, and s_o is the object distance. The magnification for a beam expander is equal to the ratio of the output beam diameter to the input beam diameter. In this case, the magnification is 8mm/1mm = 8. We know the image distance of the second lens from solving for the separation between the lenses, and we can use the known magnification to solve for the focal length of the second lens.
I hope this helps you to better understand the problem and how to approach it mathematically. Remember to always use the appropriate equations for the given situation. Best of luck with your homework!
Related to Laser beam spreader optics problem
What is a laser beam spreader?
A laser beam spreader is a device used to expand the diameter of a laser beam, typically for applications that require a larger beam size or reduced beam divergence.
Why do we need laser beam spreaders?
Laser beam spreaders are necessary for applications where a larger beam diameter is needed, such as in laser cutting, drilling, and welding. They are also used to reduce the divergence of a laser beam, which can improve the accuracy and precision of laser-based measurements.
How do laser beam spreaders work?
Laser beam spreaders use a combination of lenses, prisms, or mirrors to expand the diameter of a laser beam. These optical components are carefully designed and aligned to ensure that the expanded beam maintains a consistent and uniform intensity.
What are the common problems associated with laser beam spreaders?
One common problem with laser beam spreaders is the introduction of aberrations, which can cause distortions and reduce the quality of the expanded beam. Another issue is the loss of energy due to reflections and scattering from the optical components.
How can we overcome these problems?
To minimize aberrations, it is important to use high-quality optical components and carefully design the optical system. To reduce energy loss, anti-reflection coatings can be applied to the surfaces of the optical components. Regular maintenance and cleaning of the beam spreader can also help to maintain its performance.
  • Atomic and Condensed Matter
