- #36
- 3,135
- 7,834
Why didn't you write it this way:jbriggs444 said:But if one goes tracing a definition for the pound force in this system, one is likely to find it specified in terms of the avoirdupois pound (mass) and, thus, the kilogram together with an arbitrary number corresponding to one of the standard accelerations of gravity.
«But if one goes tracing a definition for the pound force in this system, one is likely to find it specified in terms of one the standard accelerations of gravity together with an arbitrary number corresponding to the avoirdupois pound (mass) and, thus, the kilogram»
The point was that with this system, the force is considered a "fundamental" unit (whatever that means), and the mass unit (slug) is derived from it. There is no "pound-mass". That is from another system (English Engineering Units) and, yes, if in that other system you defined ##1\ lb_m = \frac{1\ lb_f}{g_o}## then ##1\ slug = 32.1740\ lb_m##. And if you defined another system (SI units), where you have established that ##1\ lb_m = 0.45359237\ kg## when comparing those two other systems of units, then ##1\ slug = 14.59390\ kg##. But that is completely irrelevant to this system as a whole.
Nobody has created a block of material and declared: "This shall be a slug." They did however create a force and declared «This shall be a pound.» The fact that they used a certain mass at a certain distance from another mass (Earth) to define it is irrelevant. That is 3 variables: The small mass is not more "official" than the other two. Another mass at another distance from another planet could still be the definition of a pound. A specific spring under a certain displacement can also be defined as a pound.
A mass should really be a specific number of protons, neutrons, and/or electrons. That is basically what we are counting. Like 1 kg corresponds to 5.978637407×10²⁶ "protons" or something. But we round it up to an arbitrary number by specifying an arbitrary volume of an arbitrarily selected material.
