Light Speed In Forward and Backward Directions
In summary, the conversation discusses a thought experiment involving a moving frame and the discrepancy in the speed of light for forward and backward light beams as viewed from a stationary frame. The experiment shows that the time taken for the beams to reach the end points is different in the moving frame compared to the stationary frame. This is due to the relativity of simultaneity and can be explained using the Lorentz transforms. The speed of light is found to be consistent at 300,000 km/s in both frames. This experiment is a basic concept in special relativity and can be easily understood by competent physics students.
  • #36
PeroK said:
It is impossible to teach anyone anything they do not want to learn. If you are not interested in learning SR, then there is no point to the discussion.
I'm interested in you getting 0.5 and 0.5 from 0.87 and 0.29 using a single SR factor.
  • #37
AlienGrey said:
Show how to get 0.5 and 0.5 from 0.87 and 0.29 using the same SR factor. We both know you can't, isn't that right?
We've already told you how to do it. In the time you've been arguing here you could have solved your problem about half a dozen times...
  • #38
No you're not! You're only interested in trolling us. Admit it!
  • #39
Yeah but I want to see YOU do it. I already did it, now it's your turn.
  • Love
Likes malawi_glenn
  • #40
Just keep dancing.
  • Love
Likes malawi_glenn
  • #41
And if we thought it was impossible why would we be repeatedly stressing how easy it is? Wouldn't we be sucking our teeth and muttering about it being too difficult, like a mechanic trying to up the price on a repair job?
This is a trivial piece of book work that everyone here except you has done many times.
  • #42
AlienGrey said:
so the onus is on you to show how I'm wrong.
I don't think that's how it works.
Likes russ_watters
  • #43
As a stall tactic because you know you can't actually do it, I would assume.
  • Love
  • Haha
Likes malawi_glenn and Motore
  • #44
AlienGrey said:
I already did it
Then show it to us.
Likes russ_watters
  • #45
Or because it actually is that easy. Which it is.
  • #46
And if you really believe that, call our bluff. Do the maths we're lying about being the right thing (not your post #1 maths which neglects at least one important factor) and prove us wrong.
  • #47
weirdoguy said:
Then show it to us.
I did it in my head and it didn't work so I now I need you do it and show that it does work. You're the one who claims it will work so why aren't you just showing me how it works so great?
  • Love
  • Haha
  • Sad
Likes Dale, malawi_glenn and weirdoguy
  • #48
You're the one who claims this magic formula of yours will work so please demonstrate, I'm all eyes.
  • Love
  • Haha
Likes malawi_glenn and weirdoguy
  • #49
AlienGrey said:
Is this the homework section? No, so you doubting it being homework seems irrelevant.
Very frequently we get members who post homework questions in technical forum sections such as this one, so your argument is very flawed.
  • #51
Since the Alien has gotten into his spaceship and left us, this thread will remain closed. Thanks for trying to help him out while he was briefly with us. :wink:
  • Haha
Likes Vanadium 50, russ_watters, malawi_glenn and 3 others
  • #52
I am late to the party but just thought that I would add this to make it abundantly clear how easy this stuff is. Just go to https://en.wikipedia.org/wiki/Lorentz_transformation#Proper_transformations to get the Lorentz transform matrix. For ##v=(c/2,0,0)## we get$$\Lambda =
\left(
\begin{array}{cccc}
\frac{2}{\sqrt{3}} & \frac{1}{\sqrt{3}} & 0 & 0 \\
\frac{1}{\sqrt{3}} & \frac{2}{\sqrt{3}} & 0 & 0 \\
0 & 0 & 1 & 0 \\
0 & 0 & 0 & 1 \\
\end{array}
\right)$$ Then we simply use that transformation matrix to determine events ##(ct,x,y,z)## in the ground frame. $$\Lambda \cdot \left(0,0,0,0\right)=\left(0,0,0,0\right)$$$$\Lambda \cdot \left(\frac{c}{2} ,\frac{c}{2} ,0 ,0 \right) = \left( \frac{\sqrt{3}c}{2},\frac{\sqrt{3}c}{2},0,0 \right)$$$$\Lambda \cdot \left(1 c ,0 ,0 ,0 \right) = \left(\frac{2 c}{\sqrt{3}},\frac{c}{\sqrt{3}},0,0 \right)$$ You can do the subtraction and evaluate the numbers to see that the time is 0.87 for the forward and 0.29 for the reverse.
As long as they can do matrix multiplication, it is indeed high school level. The reluctance to do this for the lazy alien was due to our usual approach of encouraging the OP to learn for themselves, not because this was in any way challenging to do
Likes Ibix, PeroK, weirdoguy and 1 other person
