Long distance electrical transmission
In summary, the speaker is looking for reasonable options for electrical transmission over a 1.5 km distance in Costa Rica. They currently have temporary electrical lines running to their home but are looking for a more permanent solution. They have a small solar system for lighting and essential needs, but still have to use generators for water and power tools. They are hoping for a way to reduce voltage drop and increase amperage without spending a large amount of money. They are also open to suggestions for alternative solutions. However, the topic of building a power distribution system is considered dangerous and not allowed for open discussion on the forum.
apeman
Hi everybody... I'm new and was hoping some one could suggest reasonable options for electrical transmission over 1.5 km
I live in costa rica wilderness off grid . Electrical power lines are 1.5 km away...
brief history... I have electrical lines running 1.2 km to my helpers house ... but it is typical costa rican style ... cables attached to the trees lining the road ... 4 ga. /3 conductors ... 240 vac ...hot legs insulated , neutral bare aluminum cable ... this not good but is common practice here ...and it was meant to be only temporary... until the government controlled electrical company finally brought out electricity to my neighbors and me ... well we are 8 yrs waiting... I knew when I put this cable up... there would not be much amperage at the end ... but at the time if it was enough to run a fan, lights and a refrigerator it would be sufficient ...
since installing this I have built me a garage and now a house 300 m from the end of the electrical run ... there is not enough power at our helpers house... let alone thinking of sharing... and we are still getting the runaround from ICE( gov. elect. co name ) bringing us real power... I believe it will happen if we can get our message or embarrass the right person in ICE... but that is still yrs away I believe ... so I'm trying to find a reasonable means of getting power to our house in the mean time ...
right now we have a small solar sys... small bank of batteries powering an inverter... all lighting and is 12vdc ... but we have to crank generators to pump our well water up to water tower... and charge batteries when the sun is not sufficient and to operate tools to continue building our house ...cooking , refrigeration and dryer operate on propane ... not inexpensive but only option at the moment
we are close to finishing the house and was hoping by this time electricity would have been brought out here... and we could live with some amenities ... ... now we are looking for the most reasonable means of providing electricity to at least have sufficient power to run washing machines , refrigerator , water pump ect...30 amps 120/ 240 vac probably would be sufficient ..
other expats who have installed decent solar system have paid $20,000 plus...
I have some knowledge of electricity from my yacht building days and wondered if there is any way to install some kind of transformer or several to reduce the voltage drop over the 1.5km ( approx. 5000').. i know some of step up transformers to higher voltage but feel that could be more dangerous than the existing set up ... unless installing tall polls... insulators... different cable ... not to mention cutting and maintaining all the teak trees along the route!
this is where I'm at ...and don't know what affordable options are out there for this kind of application ... i suppose larger cables would help some... but not much ...and would be very costly to get any significant improvement as cable here is pricey and the distance is not short ... I wondered if there is some kind of booster type transformer to install along the run to maintain voltage / amperage ... are there any practical options for my situation ... appreciate any input .
This is a public forum. Anyone, including children can read these posts, and can discover them years from now via search engines. We don't allow open discussions of dangerous topics. Building your own power distribution system, without licensed engineers is considered dangerous in most places.
I realize that you might have no safe options where you live. If you are lucky, a reader of your original post may start a private conversation with you. But please no open discussions on this public thread.
Likes dlgoff, BvU and berkeman
Related to Long distance electrical transmission
1. What is long distance electrical transmission?
Long distance electrical transmission is the process of delivering electricity from power plants to homes, businesses, and other locations over long distances using power lines and other transmission infrastructure.
2. How does long distance electrical transmission work?
Long distance electrical transmission works by converting electricity into high voltage alternating current (AC) at power plants, which is then sent through transmission lines to substations. At the substations, the voltage is stepped down and the electricity is distributed to homes and businesses through distribution lines.
3. What are the advantages of long distance electrical transmission?
The main advantage of long distance electrical transmission is that it allows for the efficient distribution of electricity over long distances, which is necessary for providing electricity to areas far from power plants. It also allows for the integration of renewable energy sources, such as wind and solar, into the grid.
4. What are the challenges of long distance electrical transmission?
One of the main challenges of long distance electrical transmission is line losses, which occur when electricity travels through the transmission lines and some of it is lost as heat. This can be mitigated by using high voltage transmission lines and improving the efficiency of the grid. Another challenge is the cost of building and maintaining transmission infrastructure.
5. How is long distance electrical transmission being improved?
Long distance electrical transmission is constantly being improved through advancements in technology, such as the use of high voltage direct current (HVDC) transmission lines, which have lower line losses compared to traditional AC lines. Smart grid technology is also being implemented to improve the efficiency and reliability of the grid. Additionally, research is being done to develop new materials and technologies that can further improve the efficiency of long distance electrical transmission.
  • Electrical Engineering
