Looking for suggestions regarding a research topic
In summary: If resources (equipment and/or time) are more limited, I've seem some great projects that develop new hypotheses and test them against existing data sets available for download in public repositories. True, it is often preferable to do an original experiment or make an original invention. But often constraints of time and money and safety (some departments won't let undergrads use the fun stuff: radioactive material, high voltage, high vacuum, energetic materials, blast physics, "dangerous" chemicals, etc. without faculty supervision, then they won't provide the supervision they require) greatly narrow the field on the experimental side. There is tons of data available in public repositories. You begin here by first getting a field of some
Eva
Hi everyone!
I'm looking for a reasesrch topic that is current in the world. I'd appreciate any suggestions, feedback or advice.
It's for undergraduate physics club.
Eva
Greg Bernhardt said:
Can you narrow down your requirements a bit?
Sure, it's for undergraduate physics club.
Welcome to the PF.
That doesn't help quite enough... :smile:
Is this a research project that you will propose to the club so that the club can do the research project together? Or is it an assignment from the club to each member to do a research project and present a paper/poster to the club?
What physics classes have you taken so far? What things in physics do you find interesting?
If you are looking to just do a report on an interesting and famous thing in recent Physics history, check out the Solar Neutrino Mystery and the solution...
https://www.nobelprize.org/nobel_prizes/themes/physics/bahcall/
http://www.pbs.org/wgbh/nova/neutrino/missing.html
I still remember when this was going on, and when the solution was discovered. Great stuff! :smile:
Welcome to the PF.
Hi! Thank you so much for all the information, I will definitely look into it. In the physics club we are from all levels and we are either divided into groups or all work together with our professors on a project. A while back I had seen a video of Bill Nye talking to the Google Team and he suggested to them to work on the desalination process but that talk was from some years back and I wasn't sure that if it is still a good topic. My professor today suggested for me to search online for convective flow and forces to see if I find anything interesting or a possibility for some research even if there has been much done but what went wrong and what we could look at and examine.
I had mentioned to him that I posted here so he'll be excited to hear about the suggestions. Thanks again!
https://www.physicsforums.com/insights/niches-publishable-undergraduate-research/
Have a look at the article above. Another key point in undergrad research is that you have to read the menu right to left. You cannot pick any topic you want and then figure out if you have the resources to pursue it. The brainstorming process is greatly streamlined if you first consider the available resources (equipment, mentoring expertise, lab space, group interests, computing facilities and abilities, team abilities) and then focus on the topics for which you have (or can get) the proper resources. For example, if your department has a 1 million frame per second high speed camera available to use, one area of brainstorming becomes, "What interesting and novel things can we do with a high speed camera?" If your faculty mentor is a nuclear physicist who will put most of his equipment at your disposal, you would do well to understand what that equipment is and what may be possible with it. If you have a limited amount of funding (say $2000 US), you need to work with the constraint (as well as the opportunities) of what you can do with $2k. Also, time constraints are huge. A 2 year project window opens up a lot more than a 1 year or a 1 semester project window. If the project needs to be completed by the end of the current semester, your projects will be much more limited than if you have more time.
If resources (equipment and/or time) are more limited, I've seem some great projects that develop new hypotheses and test them against existing data sets available for download in public repositories. True, it is often preferable to do an original experiment or make an original invention. But often constraints of time and money and safety (some departments won't let undergrads use the fun stuff: radioactive material, high voltage, high vacuum, energetic materials, blast physics, "dangerous" chemicals, etc. without faculty supervision, then they won't provide the supervision they require) greatly narrow the field on the experimental side. There is tons of data available in public repositories. You begin here by first getting a field of some interest (say astrophysics) then having team members research what data is available in that field. Then you float some hypotheses you might be able to test. Then you have a harder look at the available data to consider if one of your hypotheses is really testable.
Another area of low hanging fruit for undergrads is testing whether this or that specialized instrument or other product really meets its product specifications. What is the real accuracy of that spectrum analyzer, precision voltmeter, high vacuum pressure sensor, power meter, or whatever else of key equipment you can get your hands on and figure out how to assess the accuracy of in a reliable manner. Some things we have done is have students measure the breaking strength of fishing line (and compare with the specs) and the drag coefficients of bullets (manufacturers tend to exaggerate). One recent brainstorming idea (more chemistry or biomedical than physics) was testing the accuracy of things like blood glucose monitors (cheap and easy to get at Walmart) and other common and essential biomedical devices. Other (more high school than college) ideas are things like measuring the fuel efficiency of automobiles, testing the accuracy of scales in local supermarkets, and testing the accuracy of the claimed volume on local gasoline pumps. A more physics idea would be to measure if different kinds of batteries really meet their claimed storage specifications.
Likes berkeman
Thank you so much Dr. Courtney! I don't even know how to thank you enough. This is amazing. :)
Likes Dr. Courtney
Related to Looking for suggestions regarding a research topic
What is the best way to come up with a research topic?
The best way to come up with a research topic is to start by identifying your interests and areas of expertise. You can also read current literature and identify gaps in knowledge or unanswered questions. Additionally, talking to colleagues and mentors can provide valuable insights and suggestions for potential research topics.
How do I narrow down my research topic?
Narrowing down your research topic can be done by conducting a thorough literature review, discussing your ideas with others, and considering the feasibility and practicality of your proposed research. It can also be helpful to identify a specific research question or problem that you want to address, rather than a broad topic.
What are some important factors to consider when choosing a research topic?
Some important factors to consider when choosing a research topic include the relevance and significance of the topic, the availability of resources and data, the potential impact of the research, and your own interests and expertise. It is also important to consider ethical considerations and the feasibility of the research.
How can I ensure my research topic is original?
To ensure your research topic is original, it is important to conduct a thorough literature review to identify what has already been done in your chosen area of research. This will help you to identify any gaps in knowledge or unanswered questions that you can focus on in your research. You can also discuss your ideas with colleagues and mentors to get their feedback and input.
What should I do if I am having trouble coming up with a research topic?
If you are having trouble coming up with a research topic, it can be helpful to take a step back and revisit your interests and areas of expertise. You can also seek inspiration from current events, discussions with colleagues, and by reading current literature. Additionally, reaching out to your supervisor or mentor for guidance and suggestions can also be beneficial.
  • STEM Academic Advising
