Maclaurin series homework help
In summary, the Maclaurin series for g'(x) is 1 - x2/2! - x4/4! -...+ (-1)nx2n/(2n)! and g'(x) can be written as cosx. Additionally, f(x) can be expressed as (1-cosx)/x2 if x≠0 or 1/2 if x=0. Given that g(0)=3, g(x) can be written as sinx+3. To find the Maclaurin series for g'(x)=1-x2 * f(x), first substitute -x for x in the Taylor series for e^x,
syeh
the maclaurin series for f(x) is given by 1/2! - x2/4! + x4/6! - x6/8! + ... + (-1)nx2n/(2n+2)! + ...
a) Let g'(x) = 1-x2 * f(x)
Write the Maclaurin series for g'(x), showing the first three nonzero terms and the general term.
b) write g'(x) in terms of a familiar function without using series. then write f(c) in terms of the same familiar function.
c) given that g(0)=3 write g(x) in terms of a familiar function without series.
the solution is:
a) 1 - x2/2! - x4/4! -...+ (-1)nx2n/(2n)!
b) g'(x) = cosx, f(x) = { (1-cosx)/x2 if x≠0
{ 1/2 if x=0
c) g(x) = sinx+3
i tried doing part A but could not figure out how to find the maclaurin series for g'(x)=1-x2 * f(x)
first you have to find the g'(0), g''(0), g'''(0), etc., then continue to find the maclaurin series by multiplying the terms with xn and dividing by n!
but i couldn't figure out how to do it. any help will be appreciated, thanks!
Let me do a different example:
The Taylor series of ##e^x## is ##1 + x + \frac{x^2}{2} + \frac{x^3}{6} + ...##.
If we substitute in ##-x## instead of ##x##, then we get the Taylor series of ##e^{-x}##:
[tex]1 - x + \frac{x^2}{2} - \frac{x^3}{6} + ...[/tex]
Multiply by ##x## to find the Taylor series of ##x*(e^{-x})##:
[tex]xe^{-x} = x(1 - x + \frac{x^2}{2} - \frac{x^3}{6} + ... ) = x - x^2 + \frac{x^3}{2}- \frac{x^4}{6} + ...[/tex]
We can also find ##(1+x)e^{-x}##:
[tex](1+x)e^{-x} = e^{-x} + xe^{-x} = (1 - x + \frac{x^2}{2} - \frac{x^3}{6} + ...) + (x - x^2 + \frac{x^3}{2}- \frac{x^4}{6} + ...) = (1 - \frac{x^2}{2} + \frac{x^3}{3} + ...)[/tex]
Does that help you a bit?
just multiply g'(x) through, and you'll see you're mistake, and hopefully you'll see the general solution as well =]
[itex]g'(x)=(1-x^2)f(x)=\frac{1}{2!}(1-x^2) - \frac{x^2}{4!}(1-x^2)... = \frac{1-x^2}{2!} +\frac{-x^2+x^4}{4!}...[/itex]
Related to Maclaurin series homework help
What is a Maclaurin series?
A Maclaurin series is a type of infinite series that represents a function as a sum of polynomials. It is named after the Scottish mathematician Colin Maclaurin.
Why is it useful to use a Maclaurin series?
Maclaurin series are useful because they can be used to approximate the value of a function at any point, as long as the function is differentiable at that point. This makes it easier to calculate complicated functions and allows for more accurate approximations.
How do you find the Maclaurin series of a function?
To find the Maclaurin series of a function, you need to use the Taylor series formula, which involves taking derivatives of the function at a certain point and plugging them into the formula. The resulting series will be the Maclaurin series for that function.
What is the difference between a Maclaurin series and a Taylor series?
A Maclaurin series is a special case of a Taylor series, where the center of the series is at x=0. This means that all of the derivatives are evaluated at x=0, making the calculations simpler.
How accurate are Maclaurin series approximations?
The accuracy of a Maclaurin series approximation depends on the number of terms used in the series. The more terms that are included, the more accurate the approximation will be. However, this also means that longer series are more computationally intensive.
