Mass Continuity and Torricelli's Law
In summary, the law of mass continuity states that when a pipe narrows, the speed of the fluid increases. However, when draining a tank, the speed of the fluid only depends on the height of water above and not on the size of the hole. This is because Torricelli's law, which gives a speed independent of area, is just a first approximation and assumes that the top surface of the water has zero speed. Therefore, the ratio between the area of the hole and the area of the tank is usually very small and has little influence on the exit velocity.
UMath1
361
Based on the law of mass continuity, when a pipe narrows then the speed of the fluid increases. Then why is it that when draining a tank the speed of the fluid only depends on the height of water above and not on the size of the hole? Wouldn't a narrower hole mean that that the speed must be greater to provide the same flow rate?
The key point is that when the pipe narrows the speed increases relative to where the pipe is wider in that particular pipe. It tells you nothing about the actual flow rate compared to if the entire pipe was narrower.
Yes but the case of the tank drainage, the hole's area is smaller than the cross sectional area of the tank. As per the mass continuity principle, the ratio of these two areas should influence the relative speed of the water exiting the hole. However, in all the example problems I have seen, the areas seem to have no bearing on the velocity of the exiting fluid.
A change in cross sectional area does result in different velocities in different parts of a system. But that has little to do with the exit velocity, which is based on height (hydraulic head).
The speed depends on the area. The formula that gives a speed independent of area (Toricelli's law) is just the first approximation.
It relies on the fact that the ratio between the area of the hole and the area of the big tank is usually very small. The elementary derivation of the formula assumes that the top surface of the water has zero speed.
Related to Mass Continuity and Torricelli's Law
1. What is the concept of mass continuity?
The concept of mass continuity states that the mass of a fluid remains constant as it flows through a system. This means that the amount of fluid entering a system must be equal to the amount of fluid leaving the system.
2. How is mass continuity related to Torricelli's law?
Mass continuity is closely related to Torricelli's law, which states that the velocity of a fluid flowing through a narrow opening is directly proportional to the square root of the height of the fluid above the opening. This means that the mass flow rate through the opening remains constant, as the velocity and cross-sectional area of the fluid change.
3. What are some real-world applications of mass continuity and Torricelli's law?
Mass continuity and Torricelli's law are important principles in fields such as fluid mechanics, hydraulics, and aerodynamics. They are used to analyze and design systems such as pipelines, pumps, and aircraft wings.
4. How do changes in fluid density affect mass continuity and Torricelli's law?
Changes in fluid density can affect the mass flow rate and velocity of a fluid, which in turn can impact mass continuity and Torricelli's law. For example, a decrease in density can result in an increase in velocity through a narrow opening, while an increase in density can result in a decrease in velocity.
5. What are the limitations of Torricelli's law?
While Torricelli's law is a useful approximation for predicting fluid flow through a small opening, it has limitations. It assumes ideal conditions, such as no energy losses due to friction, which may not be true in real-world situations. Additionally, it only applies to incompressible fluids, so it cannot be used for gases or highly compressible liquids.
  • Other Physics Topics
  • Classical Physics
