'Mathematical' frequencies and photons
In summary: It is technically possible to achieve a bandwidth/frequency ratio of around 10:1 in microwave and radiowaves.
Jarl
It is known that any non-sinusoidal wave can be regarded as a combination of sinusoidal waves of different frecuencies, with the ‘weight’ of the different frecuencies given by the function called Fourier transform. On the other hand, if we have an electromagnetic wave, we know that it is the combined result of many photons of different energies, and it is generally assumed that the interval of the Fourier space where Fourier transform is not zero gives us the energies of the photons in the beam, through the famous relation E=h·f where f is the frecuency and h the Plank constant.
But if we have a short pulse of radio waves rising and falling abruptly, although the main frecuency is in the radio region, the Fourier transform may have also very high frecuencies, physically impossible to assign as photon energies.
Or think in a continuous (cuasi)monocromatic wave source, a detector, and a shutter between them, which allow us to switch the wave on and off. For the source, the radiation have only one frecuency, but after the shutter, the Fourier transform of the wave has also other frecuencies. However photons should have the same energy!
So ¿in which cases or under which conditions can we relate the ‘matematical’ frecuencies given by Fourier analysis with photons energies?
We can always relate the mathematical frequencies in a classical wave to the corresponding free-field photons.
The case of the rectangular time window is an idealisation, and every physically realisable "shutter" will have a far smoother transition than a perfect heaviside function, and as such, seriously limit the bandwidth.
Concerning your monochromatic source + shutter, clearly the shutter interacts with the monochromatic beam, and this interaction will be written down as creation and destruction operators, eliminating "monochromatic" photons, and creating others. So the photons after the shutter are not simply a "subsample" of photons before the shutter. Photons aren't bullets, they are states of excitation of the electromagnetic field.
Let me know if I understand what you say,
Suppose some effect that can happen in the detector only above some photon energy, like the production of an electron-hole pair. Supposse that the monochromatic wave before the shutter do not have enough frecuency(energy) to produce this effect. With a fast mechanical shutter we can get a wider bandwidth (it is not necessary a perfect rectangular time window). Do you mean that we could increase the probability of the effect only with the shutter?
Sure (in principle). This energy will come from the interaction of the EM field with the shutter.
However, I should add that in practice, a mechanical shutter will give you such a small bandwidth increase, that for all practical purposes this will be entirely neglegible whenever quantum effects (such as pair creation) are to be considered.
Are you sure it couldn't be observed in lab conditions?
What is the order of magnitude of the maximum bandwidth that we can got technically (by any means) in microwaves or radiowaves?. Or more generally, in which region of the spectrum is it possible to achieve the higher quotient bandwidth/frecuency?
Thanks
Related to 'Mathematical' frequencies and photons
1. What are 'mathematical' frequencies and photons?
'Mathematical' frequencies and photons refer to the mathematical representation of electromagnetic radiation, which includes visible light, ultraviolet light, and infrared radiation. Photons are the basic unit of electromagnetic radiation, and they have both wave-like and particle-like properties. Frequencies are a measure of how many wave cycles occur per unit of time.
2. How are frequencies and photons related?
Frequencies and photons are related because photons have a specific frequency that corresponds to their energy. The higher the frequency, the higher the energy of the photon. The relationship between frequency and energy is described by the equation E=hf, where E is energy, h is Planck's constant, and f is frequency.
3. How are mathematical frequencies and photons used in science?
Mathematical frequencies and photons are used in various fields of science, including physics, chemistry, and astronomy. In physics, they are used to study the properties of electromagnetic radiation and its interaction with matter. In chemistry, they are used to analyze the composition of materials and identify unknown substances. In astronomy, they are used to study the properties and behavior of celestial objects.
4. Can mathematical frequencies and photons be observed?
While photons cannot be directly observed, they can be detected and measured using specialized equipment. However, the effects of photons, such as the color of light or the heating of objects, can be observed. Frequencies, on the other hand, can be observed indirectly through the behavior of waves, such as interference patterns and diffraction.
5. What is the significance of mathematical frequencies and photons in everyday life?
Mathematical frequencies and photons play a crucial role in our everyday lives. Without them, we would not be able to see, as the visible spectrum of light is made up of different frequencies of photons. They also allow us to communicate using radio waves, microwave, and infrared radiation. In addition, they are used in medical imaging, such as X-rays and MRI scans, and in technologies like solar panels and lasers.
  • Classical Physics
  • Quantum Physics
  • Other Physics Topics
