MATLAB Probability at Party function.
In summary: P < q
SherlockOhms
310
So, you're asked to write a function that computes the probability of two people at a party having the same birthday. The probability function itself is
P(n) = 0, n = 1
P(n) = 1 - (capital pi from k = 1 to k = n - 1)(1 - k/365), 2 <=n <= 365
P(n) = 1, n >= 366
The function is used to calculate the minimum value of m (your chosen n) for which P(m) >= q. Where q (0, 1], i.e. an arbitrary probability entered by the user. The function should accept q as an input and return m as an output.
Code:
function [m] = Prob(q)
m = 0;
P = 0;
while P < q
    m = m + 1;
    if m == 1
        P = 0;
    elseif m >= 2 && m <= 365
        S = 1;
        for k = 1: m - 1
            S = S * (1 - k/365);
        end
        P = 1 - S;
    else
        P = 1;
    end
end
Essentially, I want the program to accept a value of q and the to run until the value of P is greater than or equal to q. Once the the value of P is returned, m will have it's minimum value for which P >= q due to m being incremented during each iteration of the while loop. However, for some reason the value of "m"s being returned is too low and I can't seem to see why that is. For example, when I enter a value of 1 into the function, m is returned as 153 an not 366. Can anyone spot why this may be? I've looked through the code a few times now and can't seem to spot why. Is the incrementation being skipped or is there a problem with the nested for loop which calculates the value of P that involves the product of 1 - k/365 from k = 1, to k = m - 1? Thanks for any possible comments in advance. (Sorry, had to use underscores for indenting)
Plot the value of S(m), i.e.,
S(m) = \prod_{k=1}^{m-1} \left( 1 - \frac{k}{365} \right)
as a function of m on a logarithmic plot, and then look up machine epsilon.
Basically, ##P = 1 - S(m) \approx 1## for ##m \ge 153##.
Right. So, it's basically just rounding P to 1 at m = 153, so the while loop's condition is met. Is there anyway in which I can alter the condition in the while loop to avoid this rounding problem? Thanks!
MATLAB won't work on my computer just now, so I can't test this, but my guess is to transform the test from
P(m) = 1- S(m) < q
to
S(m) > 1 - q
which would look something like
Code:
  m = 1;
  if q > 0
    S = 1
    while S > 1-q && m <= 365
      m = m + 1;
      S = S * (1 - (m - 1)/365);
    end
  end
end
(Note: please use the CODE tags when posting code. It preserves the spacing and makes it easier to copy and paste.)
Thanks for that. So, I guess I could test for q being equal to 0 that I could then say m = 366.
Also, I have an alternate program written out that actually works correctly it goes like this:
Code:
function m = Prob (q)
if (q <=0) || (q >1)
error ('Input q out of bounds : q must lie in (0 ,1]. ')
end
if q==1
 m =366;
else
 m = 1;
 S = 1;
 while 1- S < q
  S = S * (1-S /365) ;
  m = m+1;
 end
end
Why is it that 1 - S is not rounded to 1, causing the condition to be met early, in this case as S → eps? Thanks.
I guess you mean q = 1.
SherlockOhms said:
Code:
end
I didn't mention it previously, but checking parameters is a very good (you could say necessary) practice.
SherlockOhms said:
Code:
 while 1- S < q
This will give you the same problems of rounding due to the machine epsilon. If S gets too small, then 1-S = 0 and the condition is met. But you have put in an extra condition, testing for q = 1. So the biggest value of q≠1 you can input is ##q = 1 - \epsilon##, such that you are comparing ##1-S < q## up to ##S=\epsilon##, hence it works.
SherlockOhms said:
Code:
  m = m+1;
I imagine that this is a typo and that you have
Code:
  S = S * (1 - m/365) ;
  m = m+1;
Got it! Apologies for the typos. Thanks for the help.
Could you explain the role of eps? Is it that it's the smallest gap possible between two floating point numbers therefore it's impossible to perform arithmetic with any number less than eps? Is this in anyway correct or have I just convinced myself of something totally wrong?
That sounds correct. To understand exactly how it works in a computer, we would have to look are floating points numbers are handled, but you would get the same with a calculator. If your calculator can display 8 digits (and no rounding is ever performed), then ε = 10-7
1.0000000 + 10-7 =
Code:
  1.0000000
+ 0.0000001
= 1.0000001
whereas
1.0000000 + 9 × 10-8 =
Code:
  1.0000000
+ 0.00000009
= 1.0000000
When considering calculations in a program, the value of ε is of relative, in the sense that it will vary depending on the exponent,
1 × 105 + 10-7 =
Code:
  1.0000000 E 5
+ 0.000000000001 E 5
= 1.0000000 E 5
You have to consider instead (1 + ε) × 105, i.e., consider only the mantissa.
Brilliant! Thanks for all the help!
Related to MATLAB Probability at Party function.
1. What is the purpose of the MATLAB Probability at Party function?
The MATLAB Probability at Party function is designed to calculate the probability of a specific event occurring at a party. This can be useful in predicting the likelihood of various situations or outcomes at a social gathering.
2. How does the MATLAB Probability at Party function work?
The function uses mathematical algorithms and probability theory to analyze data and calculate the likelihood of a specific event occurring at a party. It takes into account various factors such as number of guests, time of the party, and other variables to make its calculations.
3. Can the MATLAB Probability at Party function be used for any type of party?
Yes, the function is designed to be versatile and can be used for any type of party or social gathering, as long as the necessary data is inputted accurately.
4. Are there any limitations to the MATLAB Probability at Party function?
Like any other mathematical model, the function has its limitations and may not always accurately predict the outcome of a party. Factors such as human behavior and unexpected events can affect the accuracy of the calculations.
5. How can the results of the MATLAB Probability at Party function be applied?
The results of the function can be used to plan and prepare for a party, by predicting the likelihood of certain events or outcomes. It can also be used for research purposes, such as studying social dynamics or analyzing party trends.
