Max voltage of an air capacitor
The maximum voltage of the parallel plate capacitor filled with air is calculated to be 30 kV, derived from the breakdown field (3 × 10^6 V/m) and the plate separation (0.01 m). The capacitance of the capacitor is determined to be approximately 0.0885 pF using the formula C = εA/d. The maximum charge the capacitor can hold is calculated as 2.655 nC, using the relationship Q = CV. There was a clarification regarding the notation of charge, ensuring it was correctly expressed in nanocoulombs. The calculations confirm the capacitor's specifications and the values align with the expected physics principles.
HelloCthulhu
(a) A parallel plate capacitor has area A = 1 cm2, a plate separation of d = 0.01m, and is filled with air. If the breakdown field is E0 = 3 × 106V/m, calculate the maximum voltage and charge the capacitor can hold.
dielectric constant of air = 1
Q=CV
Vmax = E0 x d
The breakdown field is the minimum electric field at which a material ionizes; in air, this means a sparkforms.Maximum voltage:$$V{max}=\varepsilon_0\times d =(3\times10^6\times0.01) =(3\times10^4)V = 30kV$$To find the maximum charge corresponding to V = 30kV, we need the capacitance of the parallel platecapacitor,$$\frac{(8.85×10^{-12})\times(0.0001)}{0.01}=\frac{(8.85×10^-16)}{0.01}=8.85×10^{-14}F=0.0885pF$$$$V{max}=(3\times10^4 )\times(0.0885\times10^{-12}) =(3\times10^4)V=30kV$$The charge is determined from C = Q/V :$$Q=CV=(3\times10^4 )\times(0.0885\times10^{-12}) =2.655\times10^9C=2.655nC$$
##Q=CV=(3\times10^4 )\times(0.0885\times10^{-12}) =2.655\times10^9C=2.655nC##
Why two different values for the capacitance?
I might not understand what you mean by "two different values for the capacitance", but I'll try to clarify.
To find the maximum charge for the capacitor, I first have to find the capacitance:
This is the maximum charge:
No problem, my mistake. I looked at the powers of 10 not noticing that you shifted the decimal over. It looks fine except that 109C should be 10-9C, but I know what you mean because you have nC in the end.
Oops! Thank you for catching that!
Maximum charge:
$$Q=CV=(3\times10^4 )\times(0.0885\times10^{-12}) =2.655\times10^-9C=2.655nC$$
  • · Replies 21 ·
  • · Replies 31 ·
