Maximization problem using Euler Lagrange
In summary, the conversation discusses a problem involving maximizing an integral with a constraint and the use of calculus of variations. The problem resembles a typical calculus of variations problem but with an unknown boundary. There is also a discussion about the constraint on the function and the upper bound on the integral. Suggestions are made for approaching the problem, such as using piecewise linear functions.
petterson
Hi,
I'm trying to solve the following problem
##\max_{f(x)} \int_{f^{-1}(0)}^0 (kx- \int_0^x f(u)du) f'(x) dx##.
I have only little experience with calculus of variations - the problem resembles something like
## I(x) = \int_0^1 F(t, x(t), x'(t),x''(t))dt##
but I don't know about the boundary ## f^{-1}(0) ##.
Is this there a way to solve this with a Euler Lagrange equation?
Thanks very much for your help!
petterson said:
Hi,
If this comes from an applied math problem, is there a reason to think that integral has an upper bound?
Must a solution have ##f^{-1}(0) < 0## or do we also consider the case ##f^{-1}(0) > 0 ##?
Can you solve the problem with the constraint that ## f^{-1}(0)## is equal to a given constant ##C## ?
Let ##f_C## be a solution to Maximize ##I_C(f) = \int_{f^{-1}(0)=C}^ 0 [ (kx - \int_0^x f(u)du) f'(x) ] dx## then the set of solutions is a family of functions parameterized by ##C##. You might be able to solve the further problem of maximizing ##I_C(f_C)## with respect to ##C##.
Likes petterson
We consider only the case ##f^{-1}(0) > 0 ##. Typically, the solution would be such that ##f'(x) < 0##. The problem is also such that ##k## is always an upper bound on the integral.
If I choose ## f^{-1}(0)## equal to a given constant ##C## , I think I can find a stationary point with the Lagrange equation. It gives me ## f'(x) = 0 ##, which I know should be part of a valid solution, but I can't find out anything about the constant ##C## then, because the integrand is zero.
In that case, it's easier for me to visualize the problem as:
##I(f) = \int_0^{f^{-1}0} [ \int_0^x f(u)du - kx) f'(x)] dx ##
Find ##M =##max##_f \ I(f)##
Are we insisting on the constraint ##f'(x) < 0##? ##\ ## If not, I don't understand why there is any upperbound on ##I(f)##. To make ##I(f)## big, use a function ##f## that is big at ##x = 0## and increases more steeply than the graph of ##y = kx##.
Edit: No, the above idea isn't correct. ##f## must eventually cross the positive x-axis in order for ##f^{-1}(0)## to be positive. So ##f## can't increase indefinitely.
Likes petterson
Sorry I wasn't quite clear with ##f'(x)## and the upper bound - from the setup of the problem it is a given that ## k ## is an upper bound on the integral. Typically we find ## f'(x) < 0## (in related problems) - it would be nicer not to impose it as a constraints but we may easily do so if it makes it mathematically more tractable.
It would probably be fine to write the problem as
##I(f) = \int_0^{f^{-1}0} [ kx - \int_0^x f(u)du )|f'(x)|] dx ##
Do you mean ##I(f) \le k##? - or is k a bound for ##\int_0^x f(u)du## ?
In that case, do we use the constraint ##f(x) \ge 0##?
Yes I mean ##I(f) \le k##. In the original problem ## x## is between 0 and 1. The boundary ## f^{-1}(0) ## comes from a substitution. We also restrict to ##f(x) \ge 0##. I'm sorry for all the confusion (I thought there might be more of a standard technique that could help me) . Below is the original problem with all constraints :
Assuming ## x \in [0,1], a \in [0,1], k > 0 ##
$$\max_{f} I(f) = \int_{0}^{f(0)} (k f^{-1}(a) - \int_0^{f^{-1}(a)} f(t)dt) da \\
\text{s.t. } f(x) \geq 0, f'(x) \leq 0$$
I don't see how to formulate that problem as a typical Calculus Of Variations problem.
I have some vague thoughts about approaching it in the spirit of the Calculus Of Variations (- or perhaps "dynamic programming").
Suppose we only consider functions that are piecewise linear. Let [0,1] on the x-axis be partition into given intervals so that on ##[x_i, x_{i+1}]## , ##f(x) = A_i x + B_i ##. Assume ##f_m(x)## is a particular function that maximizes ##I(f)##. Can we develop simultaneous equations that would allow us to solve for the ##f_m(x_i)## ?
We get some equations by requiring that each linear segment of the graph of ##f_m## meets the next linear segment at a common point: ##A_i x_{i+1} + B_i = A_{i+1} x_{i+1} + B_{i+1}##. ( Each of the ##A_i## and ##B_i## can be expressed in terms of values of ##f_m##.)
It seems possible to get other equations by using the idea that the value of ##f_m## at the point ##x_{i+1}## must be the optimum value given we knew the values of ##f_m## at all other ##x_j##.
Momentarily take the viewpoint that the ##f(x_j) ## are known except that we don't know ##f( x_{i+1})## (i.e. We don't know that to do about ##f_m## between ##(x_i,f(x_i))## and ##(x_{i+2} f( x_{i+2})## ). Solve the problem of maximizing ##I(f_m)## with respect to chosing ##f_m(x_{i+1})##.
We can consider ##I(f)## as the difference of two integrals. They will be evaluated as finite sums.
Pretending we know ordered pairs ##(x_j, f_m(x_j))## of ##f_m## implies we also know ordered pairs ##(f_m(x_j),x_j)## of ##f_m^{-1}##.
For ##I_1(f) = \int_0^{f(0}{k f^{-1}(a)} da## , the formula for ##I_1(f)## will be a summation of areas of trapezoids. We are pretending these areas are known except for the two trapezoids with common vertex ##(x_{i+1}, f_m(x_{i+1}))##
For ##I_2(f) = \int_0^{f(0)}\ [ \int_0^{f^{-1}(a)} f(t)dt ]\ da ## , thinking about it makes my head spin!
My intuition is that ##I_2(f)## can be expressed as a function of the unknown ##f_m(x_{i+1})## and the other known ##f_m(x_j)## in an explicit manner.
Assuming it can, solving the 1-variable optimization problem
Max##_{f_m(x_i+1)} (I_1(f_m) - I_2(f_m)) ##
should give an equation relating ##f_m(x_{i+1})## to the other values of ##f_m##.
Thanks very much for this idea, Stephen - I'll have to think about this for a little bit.
Related to Maximization problem using Euler Lagrange
1. What is the Euler Lagrange equation?
The Euler Lagrange equation is a mathematical expression used to solve optimization problems, specifically, the maximization problem. It is derived from the Euler-Lagrange equation of calculus of variations and is used to find the maximum value of a function subject to certain constraints.
2. How is the Euler Lagrange equation used in optimization problems?
The Euler Lagrange equation is used to find the optimal value of a function, which maximizes or minimizes the function subject to certain constraints. It is typically used in physics, engineering, and economics to solve complex optimization problems.
3. What is the difference between a maximization problem and a minimization problem?
A maximization problem involves finding the largest possible value of a function, while a minimization problem involves finding the smallest possible value of a function. Both types of problems can be solved using the Euler Lagrange equation.
4. When should the Euler Lagrange equation be used in problem-solving?
The Euler Lagrange equation should be used when trying to optimize a function with multiple variables and constraints. It is a powerful tool for solving complex optimization problems and can provide a precise solution to the problem at hand.
5. Are there any limitations to the use of the Euler Lagrange equation?
While the Euler Lagrange equation is a powerful tool for solving optimization problems, it does have its limitations. It may not always provide a unique solution, and it can be challenging to apply in certain situations. Additionally, it may not be suitable for solving problems with discontinuous or non-differentiable functions.
  • Calculus
