Minimum number of cycles in a short pulse laser
In summary, the question is about the shortest possible duration for a pulse emitted by a laser. The answer is that a single cycle is the shortest possible, as anything shorter would violate Maxwell's laws. However, there are things called half-cycle pulses which have a strong positive half-wave followed by a weaker negative tail, but the total field still integrates to zero. The conversation then delves into the possibility of a mechanical chopper producing a non-zero area EM field, but it is determined that this is not feasible due to the physics of the blade moving across the beam front. Finally, it is noted that a picture showing a propagating E&M pulse of just one half pulse is not accurate and cannot be relied upon.
Uchida
23
Hello to all,
In a short pulse laser emission setup, can a pulse be emmited with beam length shorter than one wavelenght? (can a pulse have a duration shorter than its period?)
Lets say a laser emmiter shoots a quarter cycle pulse, what would happen to this short beam?
(lets supose the existence of a very fast chopper, and a very agile laser emmiter on the setup)EDIT:
I've found another thread within this subject (couldn't find it before):
https://www.physicsforums.com/threads/how-short-can-a-pulse-be.251777/
Likes atyy
The integral of the electric field of the full pulse must be zero, otherwise it would violate Maxwell's laws (the Fourier component of frequency 0 must be zero if no charges are present). In that sense, a single cycle is the shortest one can get.
Note that there are things called half-cycle pulses, which are in fact highly asymmetric, with a strong positive half-wave followed by a long and weaker negative tail. But even then, the total field integrates to zero.
Likes Spinnor and Uchida
So, a pulse length must be integers multiples of one wavelenght?
What would happen if a mechanical chopper choped a linearly polarized laser pulse with length of 1.125 cycle?
(consider propagation from right to left)This would be feaseble with a mechanichal chopper. And it gives a non zero area EM fields.
What would happen to the wave form far from the source?
No, this is not feasible. You have to include all the physics of the blade moving across the beam front. Shutting off the light instantly is simply not possible.
How do I square the above fact with the image below where it looks like we have a propagating E&M pulse of just one half pulse? I apologize if this is obvious.
Thank you.
That picture was intended only to show qualitatively how accelerating an electric charge produces radiation. It’s not precisely and quantitatively accurate so you cannot rely on it for anything else.
When we work through all the physics of the accelerated charge, we find that the pulse in that picture is a superposition of full cycles of waves of much shorter wavelength.
Likes Spinnor
Related to Minimum number of cycles in a short pulse laser
1. What is the minimum number of cycles in a short pulse laser?
The minimum number of cycles in a short pulse laser refers to the shortest possible duration of a laser pulse, typically measured in femtoseconds (10^-15 seconds) or picoseconds (10^-12 seconds). This number can vary depending on the type of laser and its settings, but generally ranges from 1 to 10 cycles.
2. Why is the minimum number of cycles important in a short pulse laser?
The minimum number of cycles in a short pulse laser is important because it determines the temporal resolution and peak power of the laser. A shorter pulse duration allows for more precise and accurate measurements, as well as higher intensity and energy output.
3. How is the minimum number of cycles in a short pulse laser calculated?
The minimum number of cycles in a short pulse laser can be calculated by dividing the pulse duration (in seconds) by the laser's wavelength (in meters). This will give the number of cycles in one pulse. For example, a 100 femtosecond pulse at a wavelength of 800 nanometers would have approximately 125 cycles (100 x 10^-15 seconds / 800 x 10^-9 meters = 125 cycles).
4. Can the minimum number of cycles in a short pulse laser be adjusted?
Yes, the minimum number of cycles in a short pulse laser can be adjusted by changing the laser's pulse duration or wavelength. This can be done through various methods such as using different laser settings or using pulse compression techniques.
5. What are the applications of a short pulse laser with a minimum number of cycles?
A short pulse laser with a minimum number of cycles has a wide range of applications in various fields such as microscopy, spectroscopy, and material processing. It is used for ultrafast time-resolved measurements, high precision imaging, and precise material ablation. It also has potential uses in medical treatments, such as laser eye surgery and cancer therapy.
  • Quantum Physics
  • Science Fiction and Fantasy Media
15K
  • Electrical Engineering
  • Other Physics Topics
