Modeling a wingsuit base jumper's speed
In summary, the gravitational force is greater than the frictional force. The velocity changes based on time.
v42Waeger
Model a base jumper based of a video in which is clear he has three phases the first is a free fall for 7 seconds, then he opens the wings of his suit which causes more fricition and continues to 'fly' for a whole minute at 125mph speed and at last he opens his parachute till he reaches the ground.
any formulas related to gravity and fricition which are needed to model the movement in the program.
Fgravity = m*g
Ffriction = k*A*v^2
Ftotal = Fgravity - Ffriction
a = Ftotal/m
v = v+a*dt
if t<7 then Fgravity>Ffriction
if 7<t<67 then v =55,88 (meters per second)
if t>67 then A = 45 (square meter)
if t>67 then Fgravity<Ffriction
the t defines the seconds the first 7 seconds are the free fall (phase 1) then till 67 seconds into the movement he 'flies' and after that he opens his parachute. This is not the exact way i put it in the program but the way i translated it to english.
unfortunately reality is more complicated. During both the wing suit portion and the parachute portion (unless it’s an ancient dumb parachute) he really is flying. By flying I mean that the wing suit and parachute generate a force which is in a significantly different direction than just opposed to the direction of motion through the air. In this case you need to think more like an airplane rather than just free fall with drag.
You know the force of gravity. You don’t have any power, so there is no thrust. That leaves the force generated by the flow of the relative wind over the airfoil and body. In analyzing flight, the force of the wings (and fuselage, or in this case body) is generally broken into two pieces: one component in the direction opposite the direction of motion through the air called drag, and a component perpendicular to the motion called lift. The amount of drag and lift depend on the speed of the body through the air, the angle of attack (how the body or wing is angled relative to the relative wind) and, of course, the shape of the body and/or wing. It takes a lot of analysis to relate the relative wind speed and the angle of attack to lift and drag. For a simulation you would need tables relating these. The shape can also cause torques. This is how you fly. The pilot alters the shape creating an imbalance of force about the center of gravity resulting in torques that allow him to roll, pitch, and yaw. Again, careful analysis or measurement are required to relate shape changes to torques, and these must be determined over the full range of speed and angle of attack parameters.
Anyhow, if you can determine the lift and drag and torque for a variety of shape configurations, relative wind speeds, and angles of attack, (not easy) then it is a relatively simple matter to calculate linear and angular accelerations and continue in small steps through time.
Related to Modeling a wingsuit base jumper's speed
1. What factors affect the speed of a wingsuit base jumper?
The speed of a wingsuit base jumper is affected by several factors, including the angle of the jumper's body, the type and size of the wingsuit, the altitude of the jump, and the air density. These factors all contribute to the amount of lift and drag experienced by the jumper, which ultimately determines their speed.
2. How can the speed of a wingsuit base jumper be modeled?
The speed of a wingsuit base jumper can be modeled using mathematical equations and computer simulations. These models take into account the various factors that affect speed and use principles of physics, such as Newton's laws of motion, to calculate the jumper's velocity at different points during the jump.
3. Can the speed of a wingsuit base jumper be accurately predicted?
While mathematical models and simulations can provide a good estimate of a wingsuit base jumper's speed, there are many variables that can affect the actual speed experienced during a jump. Therefore, it is difficult to accurately predict the exact speed of a wingsuit base jumper in real-world scenarios.
4. How does the speed of a wingsuit base jumper compare to other extreme sports?
The speed of a wingsuit base jumper can vary significantly depending on the factors mentioned earlier. However, on average, a wingsuit base jumper can reach speeds of up to 120 miles per hour. This is comparable to the speeds reached by skydivers and other extreme sports enthusiasts.
5. Are there any safety concerns related to the speed of a wingsuit base jumper?
Yes, there are safety concerns related to the speed of a wingsuit base jumper. High speeds can increase the risk of accidents and injuries, especially if the jumper is not properly trained or does not have the necessary equipment. It is important for wingsuit base jumpers to follow safety protocols and receive proper training to minimize the risks associated with high speeds.
