- #36
Studiot
- 5,440
- 9
Hi, Jim.
The answer to this conundrum is in post#20.
When we (amplitude) modulate the maths is given as in post20.
This results in three terms, not two, in the resulting expression.
Two of these terms are the relevant transformation between the product and sum of two sinusoids.
The third is to do with the relative amplitudes of the two sinusoids.
(Note my trig formula assumes this is unity in both directions)
This is saying that there is a difference between the three black boxes labelled modulator, multiplier and adder.
If you feed two sinusoids sin(ω1t) and sin(ω2t)
into an adder you will get an identical waveform to that feeding sin(ω3t) and sin(ω4t) into a multiplier.
But you will not get the same result if you feed
Asin(ω1t) and Bsin(ω2t) into the adder and
Asin(ω3t) and Bsin(ω4t) into a multiplier
does this help?
does this help?
