Nature: "A massive white-dwarf merger product before final collapse"
In summary, the conversation discusses the discovery of a white dwarf merger remnant and the possible outcomes of such a merger. The abstract of the paper mentions the potential for a type Ia supernova or the formation of a neutron star, and the question is raised about what determines the outcome. It is explained that white dwarfs are unable to regulate temperature and can undergo runaway fusion reactions, similar to hitting a cue ball at different angles in a game of billiards. The axis of rotation, magnetic field, mass, composition, and temperature of the stars can all affect the outcome of the merger. The type Ia supernova is a result of a runaway reaction caused by the cooling of the star and the addition of mass.
tovisonnenberg
Hey guys! I read this fascinating paper about the discovery of a white dwarf merger remnant: https://www.nature.com/articles/s41586-019-1216-1
To quote the abstract: "For white dwarfs, the mass of the merger product may exceed the Chandrasekhar limit, leading either to a thermonuclear explosion as a type Ia supernova or to a collapse forming a neutron star. The latter case is expected to result in a hydrogen- and helium-free circumstellar nebula and a hot, luminous, rapidly rotating and highly magnetized central star with a lifetime of about 10,000 years." My question is: why are two outcomes to the merger possible and what determines the outcome? As I understood it, degeneracy pressure is independent of temperature; white dwarfs are unable to regulate temperature in the manner of normal stars, so they undergo runaway fusion reactions.
Astronomy news on Phys.org
If we are playing with billiards we can hit a cue ball at slightly different angles. The impacts can knock the target ball into different pockets. That is two different outcomes.
Merging stars are going to spiral down rather than direct impact in almost all cases. However, the axis of rotation can be adjusted 360 degree for each star. If both are rotating prograde the merger will occur much slower than if they are both rotating retrograde. That is enough to at least consider the possibility of outcome diversity. We could also consider the magnetic field, the mass of the white dwarfs, the ratio of masses, the internal composition, and the temperature of each.
The type 1a supernova is a runaway reaction. That can happen because the star cools down and then mass is added. If your material is hot enough for carbon burning it would ignite as the pressure rises.
Related to Nature: "A massive white-dwarf merger product before final collapse"
1. What is a white dwarf merger product?
A white dwarf merger product is a result of two white dwarf stars colliding and merging together. This process can occur when two stars are in a binary system and their orbits decay due to gravitational radiation, causing them to merge.
2. How does a white dwarf merger product differ from a regular white dwarf?
A white dwarf merger product is much more massive than a regular white dwarf. This is because it is formed from the merger of two stars, each of which already had a mass similar to that of our sun. As a result, the white dwarf merger product has a much higher mass and density than a regular white dwarf.
3. What happens to a white dwarf merger product before its final collapse?
Before its final collapse, a white dwarf merger product goes through a phase of rapid cooling. This is because the energy generated by the merger is dissipated through radiation, causing the temperature of the star to decrease. This cooling phase can last for millions of years before the star eventually collapses.
4. What is the significance of studying white dwarf merger products?
Studying white dwarf merger products can provide important insights into the evolution and death of stars. It can also help us understand the processes that occur in extreme environments, such as the high temperatures and pressures in the cores of these stars.
5. Could a white dwarf merger product eventually become a supernova?
Yes, it is possible for a white dwarf merger product to eventually become a supernova. This can happen if the mass of the star exceeds the Chandrasekhar limit (approximately 1.4 times the mass of our sun). At this point, the star will collapse and explode in a supernova event.
  • Astronomy and Astrophysics
