- #36
Danger
- 253
It might not work in this application, but I've had pretty good luck cleaning stuff with nitro-powder solvent (made for cleaning gun bores).
Which reminds me, Rach...have you tried exploding an A-bomb under your frying pan? I imagine that'll separate all the burnt-oil molecules from the pan! If it doesn't work, it's not my fault - I asked this nuclear engineer friend of mine, and this was his idea.Danger said:It might not work in this application, but I've had pretty good luck cleaning stuff with nitro-powder ...
Gokul43201 said:Which reminds me, Rach...have you tried exploding an A-bomb under your frying pan? I imagine that'll separate all the burnt-oil molecules from the pan! If it doesn't work, it's not my fault - I asked this nuclear engineer friend of mine, and this was his idea.
Lest we forget... "A unique method for defrosting frozen soda"Moonbear said:Just remember, if you try the Coke or mapp torches, don't set the Coke bottle down on your carpet if you've applied the torch to it!
Ouabache said:using a swab of Naval Jelly (active ingredient phosphoric acid)
The reasons that we ever washed our steel or cast-iron pans are rare, but reasonable. It is best to keep low-temperature cooking and complex sauces to other pots. Our big cast-iron frying pan has not been washed in a long time; the smaller ones may have been washed in the last couple of years, and the wok has been washed more recently since we have cooked things hot and fast, then added sauces to make one-dish meals.Schrodinger's Dog said:Allow me to interject, if you have a wok or any pan that you use to stir fry, never ever wash it; it's the secret of good tasting food; now if your cooking something where bacteria may linger: wash it, but if it's stir frying the worst possible thing you can ever do is wash your pan.
Dya think that x hundred degrees C makes any difference washed or unwashed to bacteria, and so what do you keep in that pan(flavour) Clean of the muck maybe: you are all young but I as a sensei will teach you: the Chinese never wash there pans if used for stir fry, and if you prepare food that way neither should you, it's the secret of good stir fry. Wok= never wash. You do and you lose all the flavour, the best Chinese meals are prepared in a pan that has absorbed the flavour of countless generations.
Grasshopper you are keen and I appreciate that but you lack wisdom, I am the master of stirfry
Obvious but true.
