Newton Mechanics vs Special Relativity Problem
In summary, the conversation discusses the comparison of the actual momentum of a bus moving at .99c according to relativity, which is p = gamma*mv, and the momentum it would have if classical mechanics were valid, which is p = mv. The equations for both scenarios are provided and the question asks for the value of gamma.
Kaleb
49
According to Newtonian mechanics the momentum of the bus in the preceding problem is p= mv. According to relativity, p = gamma*mv. How does the actual momentum of the bus moving at .99c compare with the momentum it would have if classical mechanics were valid?
*Note*
The previous problem only states a bus and has nothing to do with the question
Classical
p = mv
Special
p=gamma*mv
For classical I came up with 99%cX with x = mass
For special I came up with 70.2%cX with x = mass
What did you get for gamma?
Your attempted solution is not correct. The correct comparison would be:
Classical: p = 0.99m
Special: p = 7.02m
This means that according to special relativity, the momentum of the bus moving at 0.99c would be 7.02 times greater than the momentum predicted by classical mechanics. This is due to the fact that special relativity takes into account the effects of high speeds and time dilation, while classical mechanics does not. At speeds close to the speed of light, the difference in momentum becomes significant and cannot be ignored. This is one of the key differences between Newtonian mechanics and special relativity.
Related to Newton Mechanics vs Special Relativity Problem
1. What is the difference between Newtonian mechanics and special relativity?
Newtonian mechanics is a set of physical laws developed by Sir Isaac Newton that describe the motion of objects in terms of forces acting on them. Special relativity is a theory developed by Albert Einstein that describes the behavior of objects moving at high speeds or in strong gravitational fields.
2. Which theory is more accurate in describing the behavior of objects?
Special relativity is considered more accurate at describing the behavior of objects, particularly at high speeds or in strong gravitational fields. Newtonian mechanics is still applicable and accurate for most everyday situations.
3. Can both theories be used at the same time?
Yes, both theories can be used at the same time, but they may provide different results. Special relativity takes into account the effects of high speeds and gravity, while Newtonian mechanics does not.
4. How do these theories affect our understanding of the universe?
The development of special relativity greatly changed our understanding of the universe, particularly in regards to the behavior of objects at high speeds and the concept of time. It also led to the development of the famous equation, E=mc^2, which describes the relationship between mass and energy.
5. Are there any practical applications for these theories?
Yes, both Newtonian mechanics and special relativity have many practical applications in fields such as engineering, astrophysics, and GPS technology. They allow us to accurately predict and understand the behavior of objects in various situations.
