Numerical aperture of a Keplerian telescope
In summary, the Keplerian telescope uses two lenses to dilate a bundle of optical rays. If the lenses are chosen to be equal, both of them can be considered as aperture stops. However, if the first lens is the aperture stop, the Lagrange invariant becomes ##H=\frac{L}{6}##, while if the second one is chosen it changes to ##H=\frac{L}{12}##. From this, the numerical aperture should be derived from ##H=NA \frac{L}{2}##, but, since the solution is ##NA=0.25##, none of these are right.
Michele Conni
[/B]
Design an afocal Keplerian telescope to imagine an object of ##L = 5\, mm## with a resolution of ##R = 2\, \mu m## and a magnification of ##M=-2##; assume that the wavelength is ##\lambda = 500\, nm##.
Don't use lenses faster than ##F/1##.
Using the optical invariant, what is the numerical aperture ##NA## of the objective lens?
Calculating ##NA## directly from resolution, what should the ##NA## be?
A definition of the Lagrange (or optical) invariant can be found in Wikipedia (https://en.wikipedia.org/wiki/Lagrange_invariant); to report it here, it can be derived in every position of the optical axis of a system from the marginal and the chief ray (which are defined by the aperture and the field stop positions respectively):
$$H=n(u\bar{y}-\bar{u}y)$$
Here, ##u## and ##\bar{u}## indicate the angles of the marginal and the chief ray, respectively, while ##y## and ##\bar{y}## indicate their distances from the optical axis; ##n##is the index of refraction of the material of propagation.
At the object ##y=0## and ##\bar{u} = 0##, therefore (considering the paraxial case and assuming that the aperture of the system is circular and the object with the center in the optical axis):
$$H=nu\bar{y}=NA\frac{L}{2}=0.6\frac{\lambda}{r_0}\frac{L}{2}$$
Finally, the numerical aperture is defined as ##NA=n\sin{\theta}##; in air and under the paraxial approximation (i.e. small angles and big distances between the optical elements) ##NA\simeq \theta##.
The Keplerian telescope uses two convex lenses to dilate a bundle of optical rays (http://electron9.phys.utk.edu/optics421/modules/m3/telescopes.htm, first picture), and it can be easily derived that the focal lengths of the two lenses are related by the equation ##f_2 = \abs{M}f_1## (in this case ##\abs{M}=2##).
Since it is not specified, I suppose that the object is at infinite distance form the first lens, and I place it with its center on the optical axis, so that (if the optical axis is defined on the axis ##z##) it goes from ##x=-2.5\, mm## to ##x=+2.5\, mm##.
If I use the fastest lens possible, i.e. ##F/1##, the relationship between diameter and focal length of the first lens is ##f_1=D_1##, and ##D_2=f_2=2f_1=2D_1##.
I solved the second question: if I force the resolution of the system to be equal to the diameter of the Airy disk of a circular aperture (https://en.wikipedia.org/wiki/Airy_disk), I get:
$$R=2r_0=2(0.6 \frac{\lambda}{NA})$$
from which:
$$NA=1.2\frac{\lambda}{R}=0.3$$
and the answer is right.
However, I am not able to solve the first question: there is nothing that forces you to choose a different f-number for your lenses, and if you choose them to be equal, both of them can be considered as aperture stops (since the marginal rays are parallel to the optical axis, because they come from ##-\infty##. Nonetheless, if you decide that the first lens is the aperture stop, it can be easily derived that the Lagrange invariant becomes ##H=\frac{L}{6}##, while if the second one is chosen it changes to ##H=\frac{L}{12}##. From this, the numerical aperture should be derived from ##H=NA \frac{L}{2}##, but, since the solution is ##NA=0.25##, none of these are right.
How do I solve this? Where am I wrong?
Hey, did you get the solution for first question? I am stuck on that problem.If you did get, kindly help me.
Related to Numerical aperture of a Keplerian telescope
1. What is the numerical aperture of a Keplerian telescope?
The numerical aperture of a Keplerian telescope is a measure of its ability to gather light and resolve fine details in an image. It is calculated by dividing the diameter of the objective lens by the focal length.
2. How does the numerical aperture affect the image quality of a telescope?
A higher numerical aperture means that the telescope can gather more light and produce a sharper image with more detail. This is important for observing faint objects or fine details in celestial objects.
3. Can the numerical aperture be changed in a Keplerian telescope?
Yes, the numerical aperture can be changed by adjusting the size of the objective lens or the focal length. However, this may require modifications to the telescope and can affect its overall performance.
4. What is the relationship between numerical aperture and magnification in a Keplerian telescope?
The numerical aperture and magnification are inversely related in a Keplerian telescope. This means that as the magnification increases, the numerical aperture decreases and vice versa.
5. How does the numerical aperture of a Keplerian telescope compare to other types of telescopes?
The numerical aperture of a Keplerian telescope is typically higher than other types of telescopes, such as Galilean or Newtonian telescopes. This is because Keplerian telescopes use larger objective lenses, which allows for a higher numerical aperture and better image quality.
  • Other Physics Topics
