Oscilloscope, Proper Shutdown?
In summary: Don't worry. 100 milliHertz is only one cycle every 10 seconds. You won't get in trouble for limiting your oscilloscope to that sampling frequency.
mishima
570
36
I recently purchased my first oscilloscope, a Rigol 1054Z. I have been using it for a few days with one of ARRL's educational boards and always feel awkward when I simply power it off after use. It didn't come with much of a manual and I was just wondering if there is a better way to power it down than just hitting the power button. Maybe a silly question, it just feels a bit like an egg in my hands, I suppose.
Look at the producer webpage.
If it is a smart oscilloscope it must have a proper shutdown internal procedure already implemented. The power on-off button is a switch or a push button?
Push button, and thanks, found the actual user's guide.
Yeah, just shut it off -- no special shutdown procedure needed.
You're probably used to dealing with HAM rigs that have a big 12V output power supply that feeds a 12V input radio. Then, there is a sequence to power-up and power-down... :smile:
In days of analog scopes it was always prudent to turn down the intensity.
Before embedded computers it was possible to burn the phosphor off the inside of the screen by powering up with sweep sped set slow and intensity high.
There's a concept named "Writing Speed"
in the time it takes dot to go across the screen, how many electrons have hit the screen ? Enough to hurt it ?
Remember current is Coulombs per second.
At sweep speed of 1 msec/cm, a second's worth of beam current illuminates 10 meters worth of screen
At sweep speed of 1 sec/cm, a second's worth of beam current illuminates only 1 cm of screen. The phosphors don't get to cool off between sweeps.
That's writing speed, how many cm per second of trace are to be lit. Obviously low writing speed requires less current in the electron beam that makes the dot..
So we were taught to form the habit of setting intensity knob all the way down when shutting off the scope.
Many Tektronix scopes had their power switch on the intensity knob like a radio volume control, forcing you to think about writing speed when you turned the scope on..
My old Heathkit scopes do this as well. Looks like a lot of these have their power switches as part of the intensity control also.
Likes jim hardy
Mishima - I was looking at that one - are you considering the hack to get it up to 100mHz ?
Yes, but I'm not sure of the legality of that.
Don't worry. 100 milliHertz is only one cycle every 10 seconds. You won't get in trouble for limiting your oscilloscope to that sampling frequency. :wink:
Likes Windadct, mishima and dlgoff
Related to Oscilloscope, Proper Shutdown?
1. What is an oscilloscope and why is it important to properly shut it down?
An oscilloscope is a scientific instrument used to measure and graph electrical signals. It is important to properly shut down an oscilloscope to protect it from damage and ensure accurate readings.
2. How do I properly shut down an oscilloscope?
To properly shut down an oscilloscope, turn off the power switch and unplug the power cord. Wait for the screen to turn off completely before unplugging any probes or other devices.
3. What are the potential consequences of not properly shutting down an oscilloscope?
If an oscilloscope is not properly shut down, it can cause damage to the internal components and affect the accuracy of future readings. It can also lead to data loss and potentially create safety hazards.
4. Can I just turn off the power strip or surge protector instead of unplugging the oscilloscope?
No, it is important to unplug the oscilloscope directly from the power outlet to ensure a proper shutdown. Turning off a power strip or surge protector may not completely cut off power to the instrument and can still cause damage.
5. Is it necessary to properly shut down an oscilloscope every time it is used?
Yes, it is necessary to properly shut down an oscilloscope every time it is used to ensure its longevity and accuracy. It only takes a few extra seconds to shut down the instrument, but it can save time and money in the long run.
  • Electrical Engineering
