- #36
Nugatory
Mentor
- 14,831
- 9,338
You don't need any rule to choose a reference frame, because you don't need a reference frame, nor coordinates.Jufa said:I don't know which is the rule to choose the local reference frame at a certain point of the curve.
Go back to @A.T. example of the tank with a turret-mounted gun and treads. Changes of direction are found in a completely coordinate-independent way just by comparing the speed of the tracks on each side - equal means following a geodesic across the surface, not equal means deviating from the geodesic towards one side or the other. We don't need any coordinates or reference frames for this, we just need a rev counter on the drive shafts on each side. Now we turn the turret back and forth according to the difference between the two track speeds; again we don't need any coordinates or reference frames, we just need to turn the turret to the left when the left-hand track is running faster and to the right when the right-hand track is running faster. The exact ratio of turret motion to track deviation will depend on the curvature of the surface we're moving over - but once we know that quantity everything else can be calculated from the directly observable and local properties of the machinery on the tank.
Parallel transport is about calculating where the gun will point after following various paths across the surface.
