Parallel transport on sphere
In summary, a vector field traveling along a circle of constant latitude is not parallel transported by said path, as the path itself is not a geodesic. This can be seen through the concept of holonomy, where if a closed loop is completed along the path, the vector field will end up slightly rotated, with the amount of rotation equal to the area enclosed by the loop. Additionally, the tangent vector of the path itself is not parallel transported, meaning that any vector that is parallel transported will not maintain a constant angle with respect to it. This is similar to how Foucault's pendulum works, with the direction of the pendulum's swing being parallel transported as the Earth rotates.
RedX
970
If you walk at constant latitude with your arm always sticking towards the North pole, is that parallel transport of your arm?
The equations don't seem to say it is.
The vector field would be [itex]\vec{V}=V(\theta)e_\theta [/itex]. The component of the vector only depends on theta, but at constant latitude theta is constant so the component of V doesn't change as you circle the earth. [tex]e_\theta=(cos \theta cos \phi, cos \theta sin \phi, -sin \theta) [/tex]
[tex]\partial_\phi e_\theta=cos \theta(-sin \phi, cos \phi, 0) [/tex]
So [itex]D\vec{V}=V(\theta)cos(\theta) (-sin \phi, cos \phi, 0) d\phi[/itex]. This is only zero at the equator. So is the vector field [itex]\vec{V}=V(\theta)e_\theta [/itex] not parallel transported at constant latitude?
I understand that you can integrate the above equation to get:
[itex]\vec{V}(\phi_2,\theta)-\vec{V}(\phi_1,\theta)=V(\theta)cos(\theta) [(cos \phi_2, sin \phi_2, cos \theta)-(cos \phi_1, sin \phi_1, cos \theta)][/itex].
Geometrically [itex]V(\theta)cos \theta[/itex] is the projection of your arm perpendicular to the z-axis (or parallel to the z=0 plane), and the difference [itex]\vec{V}(\phi_2,\theta)-\vec{V}(\phi_1,\theta)[/itex] can be attributed to the fact that the vector field rotates around in a circle about the z-axis.
But wasn't parallel transport [itex]D\vec{V}=0 [/itex]
Without going into the maths, the answer is no. If you are following a line of latitude (but not on the equator), your arm is constantly rotating relative to the path you are following or your heading. Bill K touched on this in post #21 in a similar thread here: https://www.physicsforums.com/showthread.php?t=514004&page=2
At a latitude near the North pole the rotation rate of the vector is almost zero and at the equator it is exactly zero. Anyone care to work out at which latitude the rotation rate of the vector (per circumnavigation) is the greatest. It appears to be somewhere near the Equator.
Then your 'vector' is gong to rotate, parallel in this case doesn't mean keep the same angle with geodesic, but really parallel in cartesian coordinates.
It's not so much that your arm is rotating relative to the path, but that the path itself isn't straight. A geodesic parallel transports itself, but a line of constant lattitude isn't a geodesic.
Thus, a vector pointing along the path of a line of constant lattitude isn't parallel transported by said path.
If you are traveling in a circle on a circle of latitude, and always pointing your arm North, then doesn't your arm always make the same angle with respect to your path (90 degrees)? Isn't that the pictorial definition of parallel transport?
The parallel transport equation is [itex]DV^i=0 [/itex] along a path for each coordinate i.
This should be the same as saying [itex] u^k V^{i}_{;k}=0[/itex] all along the path, where u is the tangent vector of the path.
As was pointed out in one of the links, there seems to be only one field that is parallel transported on circles of latitude based on the two more mathematical descriptions of parallel transport above, and it's a weird one, as it involves a field that rotates at a different azimuthal period from 2pi. In general, how many different types of vector fields are parallel transported by a given closed curve?
I would agree that if your arm is pointing north, and you're traveling due east, your arm is maintaining a right angle to your path.
It's also obvious that a circle of constant latitude is not a geodesic.
Before I say more, I want to re-do some of the calculations for myself, not sure when I'll get the time...
As others have said, the key point is that a circle of constant latitude is not a geodesic. So, the path taken rotates with respect to a local orthonormal frame. Parallel transport really computes parallel transport, not "constant-angle-with-respect-to-my-heading" transport. So, since the tangent vector along the path is not itself being parallel transported, any vector that IS being parallel transported can't be expected to maintain a constant angle with respect to it.
This is the same principle by which Foucault's pendulum works...the direction in which the pendulum swings is parallel transported around a line of constant latitude as the Earth rotates, causing the pendulum to slowly change direction.
Incidentally, if you complete a closed loop, you will find that the parallel-transported vector does not return to itself, but ends up slightly rotated. The amount by which is it rotated turns out to be equal to the area, measured in steradians, enclosed by the loop. This is called "holonomy".
When you say that a (nongeodesic) path rotates with respect to a local orthonormal frame, do you mean that you parallel transport the tangent vector 'u' of the path from point A of the old frame to the orthonormal frame of the new point B via adding: [itex] -\Gamma^{i}_{jk}u^j dx^k [/itex], and compare this result to actual tangent vector u' at point B, then the difference is a rotation, i.e., the quantity [tex]u'^{i}-(u^i-\Gamma^{i}_{jk}u^j dx^k)=DU^i[/tex] along the actual path between A and B is a measure of the rotation with respect to a local orthonormal frame (I'm assuming you mean the local frame at point B, after the value at A has been parallel transported to B for comparison)? So you're calling the covariant derivative a rotation?
Keeping your arm or vector at the same angle to the path is not the pictorial definition of parallel transport (although it happens to be true only if you are following a great circle or geodesic). This was covered to some degree in this other thread: https://www.physicsforums.com/showthread.php?t=514004
Although a vector is not parallel transported along a line of constant latitude by the path itself, would you agree that it is possible to parallel transport a vector along a line of constant latitude? If so, would you also agree that if a vector is parallel transported along such a path, that the vector would rotate relative to the path? For reference see section 2.1 (parallel transport can always be achieved) of this paper http://www.ocf.berkeley.edu/~adriand/classes/files/m140/17.pdf. i.e parallel transport of a vector along a path does not only apply to geodesics. However, a vector can only remain parallel to a given path if and only if the path is a geodesic.
This is interesting but I am a little bit confused because the closed loop around the equator would enclose a larger area than a loop at any other constant latitude and yet the vector has zero rotation at the equator. How does that work out? Is it because at the equator the vector is considered to rotate through an angle that is a multiple of 360 degrees? Also, I would still be interested if anyone knows how to answer the question below that I posed in an earlier post:
The angular area enclosed by the equator is [itex]2\pi[/itex].
It depends what you mean by "largest angle", because of course any angle greater than [itex]\pi[/itex] is smaller than [itex]\pi[/itex] when measured in the other direction.
That's what I wanted to calculate for myself. And, I get the same answer everyone else did. Actually - I didn't check the magnitude for the amount of the rotation that others gavie, I just found that it was non-zero, as it was a very quick calculation.
The covariant derivative of the metric preserves the dot product of two vectors, so if you have a set of orthogonal vectors, they remain orthogonal after the parallel transport.
Obviously, "north" is orthogonal to "east".
When you parallel transport these basis vectors along the non-geodesic path, what you get is that your new basis vectors are rotated. So you have some new basis vector that is no longer pointing along your curve, it started out pointing "east" but got rotated (you can imagine it picks up a bit of a South component, though this depends on which direction you're going.). And similarly, your "North" vector, after being parallel transported, gets an East component. But your new vector pair is guaranteed to be orthogonal after the parallel tranpsort if it was orthogonal before the parallel transport.
So the simple method of defining parallel transport as "keeping the angle constant" which was popularized by Baez (as I recall), works if you are following a geodesic path (which is what he mentioned, I'm pretty sure), but doesn't really serve as a general definition of parallel transport.
I tend to think of Parallel transport as being defined by Schild's ladder. But that demands that you use straight measuring rods (geodesics). The idea is rather similar to those drafting instruments one sees to draw parallel lines, it's based on the principle that if you draw a parallelogram where the opposite sides have equal length, the resulting lines are parallel. If you apply the same principle to a curved space-time, you'll also define parallel transport, where the "rigid rods" of your drafting instrument are mathematically defined by the length along a geodesic path.
About the only reference I've ever seen that discusses Schild's ladder is a few usenet posts, and MTW"s gravitation. It's a shame, it's a rather interesting geometric construction. It actually doesn't need a metric space (though I"ve presented it that way by talking about the lengths of sides of parallelograms) - it will work in an affine geometry.
[add]
YOu might ask - how does Schild's ladder define parallel transport along a non-geodesic path, like the example? The answer is pretty simple. You find a geodesic, that goes through the same point in the same direction, as your non-geodesic path. For the case at hand, you find a great circle that is locally the same as your line of constant latitude.
The deviations of said geodesic from your path will be second order. So you just parallel transport over a small distance using the geodesic, ignoring the second order difference, and take the limit for small distances. The second order terms dissapear.
So, the geodesic great-circle path will be close to the line of constant lattitude with only delta^2 discrepancies, but it will give you in the limit the "rate of rotation" defined relative to the n/s/e/w vector field that we normally use on a sphere for the non-geodesic path, which you take in the limiting case as a large number of different nearly-geodesic segments stitched together.
So, the metric on the unit sphere is:
[tex]ds^2 = d\theta^2 + \sin(\theta)^2 d\phi^2[/tex]
The path, x, around a latitude line parameterized by longitude is given by
[tex]\mathbf{x} = (\theta_0, \phi)[/tex]
We will parallel transport an arbitrary vector, v, along the path, x
[tex]\mathbf{v}(\phi) = (v^{\theta}(\phi), v^{\phi}(\phi))[/tex]
Applying the parallel transport equation we get the following system of differential equations:
[tex]v^{ \phi } ( \phi ) \sin ( \theta ) \cos ( \theta )= \partial_{\phi}v^{ \theta } ( \phi )[/tex]
[tex]v^{ \theta } ( \phi ) \cot ( \theta )+ \partial_{\phi} v^{ \phi } ( \phi ) = 0[/tex]
Solving those differential equations gives
[tex]\mathbf{v}(\phi)=\left(c_1 \cos (\phi \cos (\theta ))+c_2 \sin (\theta ) \sin (\phi \cos (\theta
)),c_2 \cos (\phi \cos (\theta ))-c_1 \csc (\theta ) \sin (\phi \cos (\theta
))\right)[/tex]
For parallel transport completely around the line of latitude we start with phi=0 and end with phi = 2 pi
[tex]\mathbf{v}(0)=\left(c_1,c_2\right)[/tex]
[tex]\mathbf{v}(2\pi)=\left(c_1 \cos (2 \pi \cos (\theta ))+c_2 \sin (\theta ) \sin (2 \pi \cos (\theta
)),c_2 \cos (2 \pi \cos (\theta ))-c_1 \csc (\theta ) \sin (2 \pi \cos (\theta
))\right)[/tex]
So the cosine of the angle between v(0) and v(2pi) is given by
[tex]\frac{g_{\mu\nu} v(0)^{\mu} v(2\pi)^{\nu}}{\sqrt{g_{\mu\nu} v(0)^{\mu} v(0)^{\nu}} \sqrt{g_{\mu\nu} v(2\pi)^{\mu} v(2\pi)^{\nu}}} = \cos (2 \pi \cos (\theta ))[/tex]
Which is equal to -1 for [itex]\pi/3[/itex] and, as you say, equal to 1 for 0 and [itex]\pi/2[/itex]
Thanks for that excellent and skilful analysis Dalespam. Cheers :D
pervect said:
It turns out wiki does have an article on Schild's ladder now:
http://en.wikipedia.org/w/index.php?title=Schild's_ladder&oldid=430529110
It's a nice geometrical way of describing parallel transport, as long as you have at least an affine geometry, the ability to measure out equal distances along a curve. A metric space is more than is needed.
As I understand it, Schild's ladder is an approximation of parallel transport that gets more accurate in the infinitesimal limit. I have a similar approximation that seems to work for a sphere and is perhaps more visual. First draw a point on a curve. Place a small disk that is tangential to the surface at that point and draw a vector on the disk. Now imagine a plane that passes through the centre of the sphere that the vector lies on. Draw a second point on the curve that you want to parallel transport the vector to. Another small tangential disk is centred on that second point. A copy of the original plane is moved so that it passes through the second point while remaining parallel to the original plane. This copied plane does not pass through the centre of the sphere. Where this plane intersects the second tangential disk is the position of the parallel transported vector. To continue the process the second plane is rotated using the second vector as an axis of rotation until it passes through the centre of the sphere. A further copy of this reorientated plane is then moved in such a way that it remains parallel to the first copy until it intersects the next point on the curve and so on. The smaller the steps the more accurate this approximation becomes.
Yes, Schild's ladder is an approximation.
One important difference between Schild's ladder and your construction, assuming I've understood it without a diagram, and assuming it works, is that your diagram makes reference to places that are not on the surface of the sphere (i.e. the center of the sphere).
This is in my view an important difference, because when we are envisioning curved geometry, we usually want to take the role of a flatlander, exploring the geometry around himself and finding out that it's curved, without making any references to "extra-dimensional spaces" that it might or might not be embedded in.
In short, we are exploring the geometry from a viewpoint within the geometry, without necessarily imaging there is something outside the geometry. (We can imagine such things if we like, but we'd prefer not to rely on them for calculations). So when we analyze curved space-time, we'd like to think about how to determine it's curvature with measurements we can actually make, measurements that don't require us to stand "outside" of space-time.Also, it's not clear how you would define "the center of the sphere" in the case of a general curved surface which might not be a sphere. Schild's ladder will serve as a suitable geometric construction on any curved surface, and it will be constructed entirely within said curved surface.
Related to Parallel transport on sphere
1. What is parallel transport on a sphere?
Parallel transport on a sphere is a concept in differential geometry that describes the movement of a vector along a curve on a sphere while keeping the vector parallel to itself at all times. It is used to define the notion of a "straight line" on a curved surface.
2. How is parallel transport different from regular transport?
Parallel transport differs from regular transport in that it only considers the rotation of the vector, while regular transport considers both rotation and translation. This means that parallel transport preserves the direction of the vector, but not necessarily its magnitude or position.
3. Why is parallel transport important?
Parallel transport is important because it helps us understand how objects move on curved surfaces, such as spheres, and allows us to define the concept of a "straight line" in these spaces. It is also used in various fields, including physics and computer graphics, to calculate quantities such as curvature and geodesics.
4. What is the parallel transport equation?
The parallel transport equation is a mathematical equation that describes how a vector changes as it is transported along a curve on a sphere. It involves the use of the Christoffel symbols, which represent the curvature of the surface, and can be used to calculate the change in the vector's direction at any point along the curve.
5. Can parallel transport be generalized to other surfaces?
Yes, parallel transport can be generalized to any curved surface, not just spheres. In fact, it is a fundamental concept in differential geometry and is used to study the geometry of various surfaces, including cylinders, cones, and more complex shapes. However, the specific equations and calculations may differ depending on the surface being studied.
  • Mechanics
