Particle density operator
In summary, the conversation discusses the definition of the current density operator and its relation to the particle density operator. The use of the delta function in the equation for the particle density operator is questioned and it is explained that it represents the expectation value of the particle density operator. The difference between an average value and an element of a density matrix is also clarified.
aaaa202
1,169
There is something I do not understand. One way to define the current density operator is through the particle density operator Ï(r). From the fundamental interpretation of the wavefunction we have:
Ï(r)= lψ(r)l2
But my book takes this a step further by rewriting the equality above:
lψ(r)l2 = ∫dr' ψ*(r')δ(r-r')ψ(r')
And thus identifies the particle density operator as the delta function above. How does this make sense in any way?
We have <r|Ï|r> = ∫dr' ψ*(r')δ(r-r')ψ(r')
where do you see a possible identification?
|ψ(r)|² is found on the diagonal of rho not on delta.
In general, we write expectation of operator A as ##\displaystyle \langle \psi |A|\psi \rangle = \int \psi^*(r') A \psi(r') dr'##. Substituting ##A = \delta(r-r')## gives you the correct expression for expectation of ##\rho(r)##. So what's the problem?
Yes but
<r|ψ><ψ|r'> = <r|Ï|r'> is not identified to δ(r-r') like aaa202 said.
it is not here an average value but an element of a density matrix.
Related to Particle density operator
1. What is a particle density operator?
A particle density operator is a mathematical operator used in quantum mechanics to describe the probability of finding a particle in a specific location. It is represented by the symbol ρ and is used to calculate the average number of particles per unit volume.
2. How is the particle density operator different from the position operator?
The particle density operator is different from the position operator in that it describes the overall distribution of particles in a given system, rather than the position of a single particle. The position operator only gives information about the location of a single particle, while the density operator gives information about the entire system.
3. What is the physical significance of the particle density operator?
The particle density operator is physically significant as it allows us to calculate the expectation value of the number of particles in a given system. It also helps us understand the spatial distribution of particles and their behavior in quantum systems.
4. How is the particle density operator related to the wave function?
The particle density operator is related to the wave function through the Born rule, which states that the square of the wave function gives the probability density of finding a particle at a specific position. The particle density operator can be calculated using the wave function and is used to determine the average number of particles per unit volume.
5. What are some real-world applications of the particle density operator?
The particle density operator has many real-world applications, including in materials science, where it is used to analyze the distribution of particles in materials and predict their properties. It is also used in chemistry to study the arrangement of atoms and molecules in a system. In addition, the particle density operator is essential in quantum computing and quantum information theory.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
