Path dependence (Complex Analysis)
In summary: Therefore, the integrals of f(z) = (1/(z-2) + (1/(z+1) + e^(1/z) are path dependent in the domain {Rez>0}∖{2}.
Matt100
Are the integrals of the function f(z) = (1/(z-2) + (1/(z+1) + e^(1/z)
path independent in the following domain: {Rez>0}∖{2}
The domain is not simply connected
I know that path independence has 3 equivalent forms
that are
1) Integrals are independent if for every 2 points and 2 contours lying completely in the domain the integral along the first contour = the integral along the second contour
2) For every closed contour lying in the domain, the integral over that contour is 0 the integral over that contour is = 0
3) There exists a F(z) in the domain such that F'(z) = f(z) over the entire domain.
Which one of these can be used to show whether the integrals of f(z) = (1/(z-2) + (1/(z+1) + e^(1/z) are path dependent or not in the domain {Rez>0}∖{2}.
It seems like number 2 is the easiest to use but not sure how?
Matt100 said:
Are the integrals of the function f(z) = (1/(z-2) + (1/(z+1) + e^(1/z) path independent in the following domain: {Rez>0}∖{2}
No. If the integrals are path independent, the integral across the closed loop consisting of path1 up and path2 down must be 0. But the integral across any closed path that winds 1 or more times around z=2 is an integer multiple of 2πi.
Related to Path dependence (Complex Analysis)
What is path dependence in complex analysis?
Path dependence in complex analysis refers to the idea that the value of a function at a point is dependent on the path taken to reach that point. This means that the value of a function at a point can change depending on the path chosen, even if the starting and ending points are the same.
What is the significance of path dependence in complex analysis?
The concept of path dependence is important in complex analysis because it highlights the fact that the behavior of functions in the complex plane can be unpredictable and highly sensitive to the path chosen. This can lead to surprising results and is a key aspect of complex analysis.
How is path dependence different from other types of dependence?
Path dependence is unique to complex analysis and is not seen in other types of mathematics. In other areas, such as real analysis, the value of a function at a point is independent of the path taken to reach that point. However, in complex analysis, the path taken can greatly impact the value of the function at a point.
Can path dependence be avoided in complex analysis?
No, path dependence is a fundamental aspect of complex analysis and cannot be avoided. It is an inherent property of functions in the complex plane and cannot be eliminated or simplified.
How does path dependence affect the study of complex functions?
Path dependence adds an extra layer of complexity to the study of complex functions, making it more challenging and interesting. It also allows for a deeper understanding of the behavior of functions in the complex plane and has many real-world applications in physics, engineering, and other fields.
  • Topology and Analysis
