Pauli Matrices in the Basis of Y?
In summary: The first "sub" term is the y basis, and the 2nd "sub" term is the corresponding... in the x basis?In summary, the pauli matrices are cyclic in the z-basis, but not in the other bases. The book says they are cyclic, via the relations XY=iZ, but this doesn't seem to apply when I use this to find the basis states. The idea is simply that x,y,z have a certain order. You know that in the Z basis the order is ##z,x,y## and this maps to ##1,2,3##.
Destroxia
204
[/B]
I know the pauli matrices in terms of the z-basis, but can't find them in terms of the other bases. I would like to know what they are.
I understand the idea of changing basis, I just need to see what the pauli matrices are in the Y basis so I can finally confirm it. I have looked through books, and webpages, and they only give them in the standard basis for Z.
I have been looking at this forever... if in the X basis the Z matrix is just the same as the X matrix in the Z basis, doesn't that just leave the Y matrix in the X basis the same as in the Z basis?
And if that's true, where does that leave the X matrix and Z matrix in the Y basis?
You can do this either by appealing to symmetry, or as an exercise you could find a change of basis matrix - from Z to Y - and apply that to the three matrices.
First, from symmetry, what is ##\sigma_y## in the Y basis?
I'm not sure what the matrix is for Z to Y, I can't figure it out and the textbook doesn't list anything besides X to Z.
and I believe that ##\sigma_y## in the Y basis is the same as ##\sigma_z## in the Z basis.
## \sigma_y = \left(\begin{array}{cc}1&0\\0&-1\end{array}\right)## in the Y basis.
Yes, exactly. Now, you need to work out the correct order for the other two. The key is the base permutation ##x,y,z##.
PS you also might want to figure some notation for this. First, perhaps, use ##\sigma_1, \sigma_2, \sigma_3## for the underlying Pauli matrices. Then something like ##\sigma_{Z,x}## for the x-matrix in the Z basis.
I read in the book a cyclic relation, is this what you mean by base permutation? ## XY=iZ ##, ## ZX=iY ##, ## YZ=iX ##... Does this mean that I can simply equate them so that ## \sigma_y = \left(\begin{array}{cc}0&-i\\i&0\end{array}\right) ## in the X basis, and ## \sigma_y = \left(\begin{array}{cc}0&1\\1&0\end{array}\right) ## in the Z basis?
Also, I apologize I got your note on notation after I submitted that.
You should already know that the three matrices in the Z-basis, so that last statement is wrong. In fact, they are both wrong.
So, in the X basis the order is ##x,y,z## and that, by symmetry, must equate to ##1,2,3##.
In general, going from Z to X, replace z by x, x by y and y by z.
Does that make sense?
PS that's what is meant by a cyclic relation. The order is always x, y, z whichever one you start with. It's never x, z, y, which is the opposite cycle.
PPS in physical terms this relates to the orientation of the axes. The opposite cycle would apply if we had the z-axis pointing down.
So if I understand you correctly...
## \sigma_{y,y} = \left(\begin{array}{cc}1&0\\0&-1\end{array}\right) ##, ## \sigma_{y,z} = \left(\begin{array}{cc}0&1\\1&0\end{array}\right) ##, ## \sigma_{y,x} = \left(\begin{array}{cc}0&-i\\i&0\end{array}\right) ##
In which the first "sub" term is the y basis, and the 2nd "sub" term is the corresponding matrix?
Yes, that's it.
Related to Pauli Matrices in the Basis of Y?
1. What are Pauli matrices in the basis of Y?
Pauli matrices in the basis of Y are a set of three 2x2 matrices named after the physicist Wolfgang Pauli. They are used in quantum mechanics to represent spin states of particles and are commonly denoted by the symbols σx, σy, and σz.
2. How are Pauli matrices related to the basis of Y?
The basis of Y, also known as the spherical basis, is one of the three possible bases used to express spin states. In this basis, the spin states are represented by the three Pauli matrices, with σx and σy being complex and σz being real.
3. What is the significance of using Pauli matrices in the basis of Y?
Using Pauli matrices in the basis of Y allows for a more intuitive understanding of the spin states of particles. The matrices correspond to the x, y, and z components of the spin, making it easier to visualize and analyze spin states.
4. Are there any other bases in which Pauli matrices can be used?
Yes, Pauli matrices can also be used in the basis of X and the basis of Z. In the basis of X, the spin states are represented by σy and σz, while in the basis of Z, they are represented by σx and σy. These bases are useful for different types of calculations and analyses.
5. Can Pauli matrices in the basis of Y be used for all types of particles?
No, Pauli matrices in the basis of Y are specifically used to represent the spin states of spin-1/2 particles, such as electrons, protons, and neutrons. For particles with different spin values, different matrices and bases may be used.
  • Linear and Abstract Algebra
