Perimeter of Smallest Rectangle
In summary, the perimeter of the smallest rectangle that can be formed using 24 squares 1cm2 of area each can be optimized by using calculus techniques such as finding the objective function and constraint, or by using Lagrange multipliers.
prasadini
The perimeter of the smallest rectangle that can be formed using 24 squares 1cm2 of area each is
Re: area
Have you learned any calculus yet?
I am assuming the perimeter is the objective function (the function we wish to optimize (minimize in this case)), so let's give that in terms of the width $x$ and height $y$:
\(\displaystyle P(x,y)=2(x+y)\)
Our constraint is on the area $A$, and so we have:
\(\displaystyle A=xy\)
Now, we can solve the constraint for either variable $x$ or $y$, and then write the perimeter function in one variable, and use Calc I techniques of minimization, or we can use the Calc III technique of Lagrange multipliers.
Can you proceed?
Related to Perimeter of Smallest Rectangle
1. What is the definition of perimeter of a rectangle?
The perimeter of a rectangle is the distance around the outside of the rectangle. It is calculated by adding the lengths of all four sides of the rectangle.
2. How do you find the perimeter of the smallest rectangle?
To find the perimeter of the smallest rectangle, you need to know the length and width of the rectangle. The perimeter is then calculated by multiplying the length by 2 and the width by 2, and adding those two numbers together.
3. Can the perimeter of the smallest rectangle be negative?
No, the perimeter of a rectangle cannot be negative. It is a measure of distance and distance cannot be negative.
4. What is the formula for calculating the perimeter of the smallest rectangle?
The formula for calculating the perimeter of the smallest rectangle is 2 x length + 2 x width, or simply 2(l + w), where l is the length and w is the width.
5. How is the perimeter of the smallest rectangle related to its area?
The perimeter and area of a rectangle are related by the formula A = l x w, where A is the area, l is the length, and w is the width. The perimeter is the sum of all four sides, which can also be written as P = 2l + 2w. Therefore, the perimeter and area are both dependent on the length and width of the rectangle.
  • General Math
  • Calculus
  • Topology and Analysis
