Photonuclear activation of ground
In summary: Further research, such as plotting photon-reaction cross-sections, may be necessary to determine the exact isotopes and energies that would significantly activate ground and buildings. In summary, the most sensitive stable isotopes for photonuclear reactions that could potentially produce radioactive isotopes in ground and buildings are Be-9, D, d, N-14, and O-16.
snorkack
2,190
477
Which energy gamma rays would significantly activate ground and buildings?
The most sensitive stable isotopes for photonuclear reactions are Be-9 and D. The reactions are
Be-9+hnu->2*alpha+n, threshold 1,67 MeV, followed in air by
N-14+n->C-14+p
where C-14 is radioactive, and
d+hnu->p+n, threshold 2,23 MeV, followed by same C-14 in air.
Dry air has lowest photonuclear reaction
N-14+hnu->N-13+n, threshold 10,5 MeV, where N-13 is radioactive and n likewise produces C-14
O-16 has activation threshold 16,6 MeV
So how about irradiation of ground? Between the common isotopes of common elements in ground and buildings
Si, O, Al, Mg, Ca, Fe
which have lowest threshold for photonuclear reactions whereby radioactive isotopes are produced?
I did not encounter such search before, but I think a way to approach the answer is: plotting the photon-reaction cross-sections of common isotopes found in ground* and noticing what are the most probable reactions to take place. By that, you will have the isotopes that have highest probability of activation and you will get the energy of the photon that would cause such activation.
*https://www-nds.iaea.org/
The most significant energy gamma rays that could activate ground and buildings would be those with energies above the activation thresholds of the stable isotopes mentioned above. This includes gamma rays with energies of 1.67 MeV or higher for Be-9 and D, 2.23 MeV or higher for d, and 10.5 MeV or higher for N-14. For O-16, gamma rays with energies of 16.6 MeV or higher could activate the ground and buildings. However, it is important to note that the likelihood of these reactions occurring and producing radioactive isotopes depends on the specific composition and density of the ground and buildings in question.
Related to Photonuclear activation of ground
1. What is photonuclear activation of ground?
Photonuclear activation of ground is a process in which a photon, or a particle of light, interacts with the nucleus of an atom, causing it to become excited and potentially leading to the emission of gamma rays or the creation of a new element.
2. How does photonuclear activation of ground occur?
Photonuclear activation of ground occurs when a high-energy photon, such as a gamma ray, interacts with the nucleus of an atom. This interaction can cause the nucleus to gain energy and potentially undergo radioactive decay.
3. What is the purpose of studying photonuclear activation of ground?
Studying photonuclear activation of ground can provide valuable information about the structure and properties of atomic nuclei. It can also be used in various applications, such as nuclear medicine and nuclear power production.
4. How is photonuclear activation of ground different from other types of nuclear reactions?
Photonuclear activation of ground is different from other types of nuclear reactions because it is initiated by a photon instead of a particle, such as a neutron or proton. It also usually involves the excitation of the nucleus to a higher energy state, rather than the formation of a new element.
5. Are there any risks associated with photonuclear activation of ground?
Like any nuclear reaction, there are potential risks associated with photonuclear activation of ground. These risks include radiation exposure and the potential release of radioactive materials. However, proper safety protocols and precautions can minimize these risks.
  • Nuclear Engineering
11K
